axle shims
Discussion in 'Suspension' started by PPD934, Jul 13, 2009.
  1. Jul 15, 2009 at 3:58 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    that could be an issue if the springs are flattening out and allowing the pinion to come up too high, combined w/ axle wrap
  2. Jul 16, 2009 at 4:20 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    mytoytaco, I know I have'nt been on here a while, but after looking at those pictures, I think your leafs are starting to show some sag. After some extremley light detective work, looks like you jump your truck (sig), tow some stuff, and it's an 05. Maybe this is a good excuse to treat yourself to a new leaf pack?:)
  3. Jul 16, 2009 at 4:24 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    yeah you're probably right lol
  4. Jul 16, 2009 at 5:23 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Right on man :cheers: While I have someone's attention, what's the deal with everyone having the same profile pic? I went on leave for a week and when I came back I see the same picture all over the place on here.
  5. Jul 17, 2009 at 7:58 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
  6. Jul 17, 2009 at 9:09 AM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Got it. Thanks.
  7. May 26, 2010 at 5:08 AM
    frankybones
    frankybones Well-Known Member
    Frank
    Summerville SC
    2017 TRD PRO - CEMENT
    is this an easy install? would you recomend a non mechaninc install?
  8. May 26, 2010 at 8:49 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    It's pretty simple:
    1) Jack up rear of truck
    2) Put frame on jackstands
    3) Place jack under rear dif to support axle
    4) Lift axle a little, not enough to lift truck off jack stands
    5) loosen U-bolts
    6) Lower axle just enough to slide shims in
    7) Lift axle back up
    8) re-tighten U-bolts, lower truck
    Someone let me know if I missed a step in there..
    GreenBean394 and 05Taco4x4 like this.
  9. May 26, 2010 at 9:58 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    are the u-bolts long enough? stock u-bolts, with AAL eats up a good bit of thread..shims i assume will take up even more. input?
  10. May 26, 2010 at 10:00 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I did have to get longer U-bolts. I got extra long ones and just cut the excess off.
  11. May 26, 2010 at 12:49 PM
    aficianado
    back to bone stock.
    thanks for the info.
  12. May 26, 2010 at 6:52 PM
    frankybones
    Frank
    Summerville SC
    Ill have to double check. I have a 1.5 aal so who knows. Thanks for the info gents. Very helpful. Would I follow the same steps if I had to replace the U bolts? What would I use to cut?
  13. May 26, 2010 at 9:24 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I used a grinder with a cut off wheel
  14. May 26, 2010 at 9:55 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Get 3* shims. Only buy 2 longer U-bolts for the rear where the shim/wedge is thicker.
  15. May 26, 2010 at 10:34 PM
    #35
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Lol. Why didn't I think to only buy 2 longer ones? Good advice.
  16. Sep 2, 2013 at 1:52 PM
    #36
    StreetTaco4Me
    StreetTaco4Me Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
    where do you get these shims from...So as I am understanding I should not have to remove the leaf spring centering pins?
  17. Sep 2, 2013 at 1:59 PM
    #37
    Kaboom90
    Kaboom90 Well-Known Member
    Austin
    Alabama
    2017 TRD OR 4X4
    Stock-ish
  18. Jul 7, 2019 at 6:31 PM
    #38
    Tacomeat2019
    Tacomeat2019 Well-Known Member
    2001 4x4 / 2013 4x4 dcsb trd or
    I am having vibes at 40mph slightly and more noticeable at 60mph. I can hear it more than i can feel it. It sounds like it's coming from the front so I replaced the clamshell needle bearing with the ecgs bushing because I've heard the bearing commonly causes vibes. No luck though. Also replaced the ps CV axle, also no luck. I'm wondering if the vibes are actually in the rear? Any suggestions? I recently put 5100s all the way around lifting the front about 2.5" with a 1.5" aal in the rear
  19. Jul 11, 2019 at 10:53 AM
    #39
    frankybones
    Frank
    Summerville SC
    Did you install the dif drop? This along with the shims is what resolved my issues. I had the same setup on my 05 Tacoma.
  20. Jul 14, 2019 at 1:58 PM
    #40
    Tacomeat2019
    Yeah I put in the diff drop with no luck. I can still try the shims but it really sounds like it's coming from the front end. Any idea what size shims I should try?
