Axle Swap E-Locker 96 Tacoma.
Discussion in '1st Gen. Tacomas (1995-2004)' started by goomba, Jan 23, 2011.
  1. Jan 23, 2011 at 6:43 PM
    goomba
    goomba [OP] It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    What axle swap can I do for my truck to get a locker. Will a newer truck axle with E-locker work on my truck? Thanks!
  2. Jan 23, 2011 at 6:45 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    have you considered an ARB air locker?
  3. Jan 23, 2011 at 6:48 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    Ya you can do a axle swap but its spendy! I don't know about the e locker, but you could do a arb air locker also. You can get a axle from a 80-85 toyota I think. You could also cut up a dana 44. That's what I would do.
  4. Jan 23, 2011 at 6:52 PM
    goomba
    Josh
    San Antonio Fl
    I herd that it is easier and cheaper to buy a used axle with the locker all ready in it.
  5. Jan 23, 2011 at 6:54 PM
    tacovic
    tacovic Well-Known Member
    MN/WI
    00 4x4 TRD
    stock for now
    It is. Look around at some junkyards. I pulled a rear axle with a diff lock out of a 01 Tacoma trd and got it for 250. Way cheaper than the arb.
  6. Jan 23, 2011 at 6:56 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Do some research....despite what you "heard", it's easiest and cheaper to do ARB air locker.
  7. Jan 23, 2011 at 6:58 PM
    NegroTundra
    Land of Enchantment
    Also, quit mudding up the forum with multiple threads for the same shit....people like you make the search function worthless
  8. Jan 23, 2011 at 7:25 PM
    goomba
    Josh
    San Antonio Fl
    Thanks! but will a new axle(from a newer Tacoma) fit on my truck?:confused:
  9. Jan 24, 2011 at 3:07 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Like the 2nd gen's? No.
  10. Jan 24, 2011 at 3:49 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    2002 TRD prerunner,SR5, doublecab
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    Not sure where your getting your information.
    I have seen complete trd rears with e locked 3rds go for $300-$400.
    And it should bolt right up minus splicing the electronics for engaging the system.
    Also I would guess that your average driveway mechanic could do this in a day.
    An Arb itself will cost you twice that + a compressor + a shop to install.
    Your looking at maybe $1600
    How is that cheaper?
  11. Jan 24, 2011 at 6:18 AM
    goomba
    Josh
    San Antonio Fl
    No, i was not talking that new, but like in the 98 - 04 range. Thanks though. :cool:
  12. Jan 24, 2011 at 9:30 AM
    tacovic
    MN/WI
    00 4x4 TRD
    stock for now
    Yes. Any rear axle from 98-04 will bolt right up. Look around at some junkyards. Just make sure its a true trd axle. And it will be much cheaper to find a used elocked axle than an arb.
  13. Jan 24, 2011 at 9:45 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You can't just slap a TRD OR axle in without checking a few things first. 1st, do the gears match (front and "new" rear diff)? If they don't, you'll have to address that or 4x4 will be worthless. Second, 95.5-97 taco's had PU leaf springs (IIRC). I'm not 100% certain if that will affect the mounting point of the axle as the PU leaves were shorter in length.
  14. Jan 24, 2011 at 10:42 AM
    Stuardoslls
    Stuardoslls Well-Known Member
    Stuart
    Hawthorne, CA
    2012 Double Cab 4x4 TRD Offroad Package
    Just Rims and Tires: FJ Cruiser 16" wheels w/ 265/75/16 BFG KO2's
    Are the rear ends different on a 4 banger and V6's..?
  15. Jan 24, 2011 at 10:45 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    3rd members are different in some configurations. TRD vs REG axles are different but only to accomodate the 3rd member.
  16. Jan 24, 2011 at 2:23 PM
    NegroTundra
    Land of Enchantment
    Well in that case, I stand corrected.....I have never seen a complete TRD axle for less than $1000, but maybe I'm not looking hard enough. I put in a ARB + compressor in my old 03 Tundra for right at $750, I did the install.
    OP-If you do get a TRD axle from a junkyard or something, I might pull the cover to make sure everything is in good shape. Would suck to go through all the labor of installing only to find the teeth severely worn. Good luck
  17. Jan 25, 2011 at 8:45 AM
    goomba
    Josh
    San Antonio Fl
    Thanks everyone. I have 4.10s in my truck now. Do all TRD trucks have 4.10s stock or will they be different?
  18. Jan 25, 2011 at 4:05 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Why are you wanting to do a swap anyway? Just add a Powertrax Lockrite.. I can't tell you enough how much I love mine.. $175. No swap shit intended, no need to worry about gears, and it's easy to install.
    And no not all trucks have the 4.10s.
  19. Jan 25, 2011 at 5:50 PM
    goomba
    Josh
    San Antonio Fl
    Where did you get your locker. The only ones i have seen are like $300. And is it a continuous lock, or does it lock automatically? Thanks.
  20. Jan 26, 2011 at 9:13 AM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
