Axle upgrade for towing
Discussion in 'Technical Chat' started by 4WheelSpin, Jan 28, 2021.
  1. Jan 28, 2021 at 4:07 AM
    4WheelSpin
    4WheelSpin [OP] Member
    Ray
    the Piedmont
    2nd Taco Grande - rolled the first up a mountain. 2011 Pre-runner
    just some window vents and a tonneau cover - for now...
    Can anyone out there tell me what stock axles (that can be found at a junkyard) will fit a 2011 Taco double cab that are also good for towing?
    In particular, I don't have much money - so the dreamt about Dana 60 won't fit my budget! and I'm looking to upgrade my towing so I can purchase a (heavily used) fifth wheel. I am aware that I will also need a brake upgrade; but am open to any other upgrades/mods you think are necessary for increasing my towing ability.
  2. Jan 28, 2021 at 4:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    The axle has very little to do with tow capacity. The gear set would though. But you have bigger problems.
    The suspension, brakes, engine and transmission are all inadequate for that load.
    And you want to put a 5th wheel in a composite bed?
    Seems you'd be better off using a truck actually built to handle such a load.
  3. Jan 28, 2021 at 6:19 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I think you need to invest in a larger truck if you wana tow a 5th wheel, I've seen a few Tacoma's with goosneck hitches in them and I thought that was crazy.
    It's just not a big enough truck for towing that kind of trailer even if you could beef up the suspension to handle it, not only is it unsafe because the truck is so light there's just not enough engine and braking power there for that kind of a load.
  4. Jan 28, 2021 at 6:22 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeahhhhh, don't tow a 5th wheel with a tacoma.
    crashngiggles likes this.
  5. Jan 28, 2021 at 6:32 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The only 5th wheel a Tacoma will be towing is a Scamp and you don't need any fancy upgrades for that. If you want to tow a 5th wheel that most people think of you need a truck actually built for towing. No amount of upgrading a Tacoma will get you there.
    Dm93 likes this.
  6. Jan 28, 2021 at 10:05 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    This post is a joke right? Just an attempt at humor, correct? A Taco pulling a 5th wheeler, that’s definitely humorous. You don’t have much money and can’t afford a Dana 60 axel but can I guess afford a 5th wheeler. Yep you’ll definitely need a brake upgrade. In fact you’ll need a whole truck upgrade. Perhaps you can find junk yard parts to upgrade your Taco to a Ford F-250. Let us know how this project progresses and post pictures. Definitely want to see a 5th wheeler hooked up to a Taco.
    Sorry if you think I’m being harsh but the post is bizarre.
  7. Jan 28, 2021 at 3:52 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    how many miles
    what engine & transmission on 2004 taco
    4X4 or NOT
    no stack axles to do what U want
    a steel plate attached directly to frame for the 5th wheel
    what U want aint gonna be cheap
  8. Jan 28, 2021 at 4:27 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The real problem is the Tacoma`s short wheel base!!
    The second problem is lack of budget .
    Anything can be designed and built with enough budget.
    Till you were finished you would have a Tacoma Cab and Bed mounted on a full size drive train so many fabricated parts one failure would stop you till the new part was built
    It is a interesting thought buying any of the big 3 Automakers Full size Trucks would be cheaper.
  9. Jan 29, 2021 at 2:18 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Composite doesn’t matter lol. Even on full-size duallies the gooseneck receiver gets bolted through the bed and to the frame lol.
    You have a point with the rest tho
    6 gearT444E likes this.
  10. Jan 29, 2021 at 2:21 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    The biggest cheapest axle to put under the Tacoma is probably an FJ80, you’d just need to weld on new spring perches. That won’t help you tow anything better, it will just increase the unsprung weight.
    If you want a fifth wheel get a full size truck. Leave the mid size pickups to picking up a few sheets of plywood.
  11. Jan 29, 2021 at 2:30 PM
    02hilux
    Planet: EARTH
    IT'S FRIDAY!
    Just because a vehicle has a hitch doesn’t mean it can tow whatever is attached to the ball, regardless of how monstrous the stock or modified engine’s torque and horsepower numbers are. The same applies to towing with a gooseneck or fifth-wheel setup.
  12. Jan 29, 2021 at 2:35 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    get a real truck if you want to tow a 5th wheel sunny boi
  13. Jan 29, 2021 at 3:41 PM
    Clearwater Bill
    Billy
    Largo Florida
    Understood. But a sandwiched sheetmetal bed (between gooseneck and frame) would seem to be more durable than composite.
    Even though the gooseneck is bolted to the frame the bed floor does bear some load even with the stellar strength of the Tacoma frame.
  14. Jan 29, 2021 at 5:40 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    the bed doesn’t take any weight from a good 5th wheel setup such as B&W. If it were me I’d get a gooseneck hitch and then something like this, not that I’d get that setup for a Tacoma but talking for a truck with a real leaf springs and tow rating.
  15. Jan 29, 2021 at 6:00 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    So like a Honda ridge line.
  16. Jan 29, 2021 at 6:15 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    He’s trolling. Nobody is this stupid.
    Sprig likes this.
  17. Jan 29, 2021 at 6:57 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Precisely
  18. Jan 29, 2021 at 9:07 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I like your optimism but I warn that you are being quite naive.
    Wyoming09 likes this.
  19. Jan 29, 2021 at 9:11 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    You could probably retrofit a 14bolt pretty easily. I bought a 2010 14b for $300 at a junk yard
  20. Jan 29, 2021 at 9:18 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    that would be something, but then you’d be stuck with an 8 lug rear and need an adapter, or have to buy custom hubs, unless you bought the 6 lug semi float 14 bolt.
