Axle weight, GVWR, Curb Weight etc....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Swamp Donkey, Mar 3, 2013.
  1. Mar 3, 2013 at 9:16 PM
    Swamp Donkey
    Swamp Donkey [OP] Well-Known Member
    Fort St John B.C
    2011 4cyl SR5 auto 4x4
    Hey,
    I want to know what the front axle weight of a 2011 access cab 4 cyl 4x4 Sr5. I am trying to figure out if my overall weight of my truck is being transferred to the front axle.
    My info I gathered.......
    My trucks GVWR on the door sticker is 2426 kg 5337 Lbs
    My truck on the scales with canopy tools etc weighed in at 2460 Kg. 5412 lbs
    Sticker for front axle says 1249 kg 2747 lbs
    Scale says 1160 kg 2552 lbs
    Sticker for rear axle says 1410 kg 3102 lbs
    Scale said 1300 kg 2860 lbs
    The reason I am asking is I am trying to figure out what front springs to get in an ironman lift kit.
    I use my truck for work in the oilpatch in Northern British Columbia and it sees a lot of rough muddy snowy roads. The stock suspension is not quite up to continuous duty at max rating! :D:eek:
    A little more info is my curb weight looks to be a hair under 4,000 lbs. But it does not break it down to front and rear axles.
    Truck in question is the truck in my sig.
    2011 Tacoma Specs <---- Click there if you care.
  2. Mar 3, 2013 at 11:10 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would go with what the scales are telling you. The weights listed on the sticker(s) are not working for me and they are no longer accurate as you have added the canopy and tools. If that is how you will be loaded the majority of the time that is what you should use.
  3. Mar 5, 2013 at 8:40 PM
    BradyT88
    BradyT88 Well-Known Member
    Yeah I would just put it on a scale to figure this stuff out. My rig weighed like 500lbs over curb weight when I put it on a scale and that was pretty much bone stock then.
