Axle wrap mod??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nick929rr, Aug 7, 2019.
  1. Aug 7, 2019 at 10:48 PM
    Nick929rr
    Nick929rr [OP] Member
    Nick
    NH
    2010 Black Tacoma TRD Sport DCSB
    many to come....
    I've got a 2010 DCSB Sport which I am thinking has quite soft suspension in the rear. I was looking into the Axle Wrap Mod and if anyone has done it, does it stiffen or raise the rear at all?
  2. Aug 8, 2019 at 4:56 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    What makes you think that you are experiencing axle wrap? What do you mean by soft suspension? Could be worn leaf springs or shocks.
  3. Aug 8, 2019 at 5:44 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    What axle wrap mod?
  4. Aug 8, 2019 at 6:07 AM
    Nick929rr
    Nick
    NH
    many to come....
    I get the thump when taking off. I mostly notice it when switching directions. I've had other Tacomas in which I installed a Toytec lift. This truck is not lifted. So I don't have the added strength to the rear suspension yet. I am eventually going to lift this one, but in the meantime, $30 isn't much to eliminate the minor thump.
  5. Aug 8, 2019 at 6:08 AM
    Nick929rr
    Nick
    NH
    many to come....
  6. Aug 8, 2019 at 9:38 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    The only thing the mod does is prevent movement of the leaf pack and won't affect the lift or ride quality of your current setup. I would check your U-bolts torque prior to investing in the mod. Torque should be 73 ft/lbs.
