Axle Wrap
Discussion in 'Suspension' started by supremetaco2, Aug 26, 2009.
  1. Aug 26, 2009 at 11:06 PM
    supremetaco2
    supremetaco2 [OP] Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    What exactly is this? Could someone please explain this to me.. does it have to do with the leafs? I've been reading a lotta information that blocks may tend to cause this. Damn't I wish the shop I went through would inform me about this. He asked AAL's or blocks in the rear and told me some of the positives and negatives of both, but nothing about axle wrap... Had I known this, I would have gone with the AALs... shouldve done more research before hand.. damnt. Any help would be appreciated :)
  2. Aug 26, 2009 at 11:20 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    when the leafs get flat (from aging, and blocks tend to make them flatter faster) they let the axle rotate back and forth, letting the axle wrap itself in the springs, causing the back tires to hop. it's very annoying and rough on the truck, i don't know if the AAL would solve it, someone else will have to chime in here.
  3. Aug 27, 2009 at 4:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Search google and you'll find all sorts of info about it.
    If you already got blocks, don't worry about it. Just drive. When you start driving the vehicle, you may get wheel hop. When you come to a stop, you may get a thumping feel. If it starts to annoy you - then do some more google research on how you can prevent it.
    If you go offroad (since you have blocks), be careful not to get on the gas too much. I've seen a couple sets of blocks break and fly out while wheeling & using too much gas in certain situations.
  4. Aug 27, 2009 at 4:49 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
