Ay benifit with a pedal monster AND tune?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JDKred, Jun 21, 2025 at 10:54 AM.
  1. Jun 21, 2025 at 10:54 AM
    JDKred
    JDKred [OP] Well-Known Member
    JD
    16 MT KDMax Tuned
    As title says, and benefit?
    I have a 6MT with a tune already.
    Pros?
    Cons?
    Thoughts?
    Benefits?
  2. Jun 21, 2025 at 10:58 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I already know you are going to buy one regardless of what I say. Send it.
    musicisevil likes this.
  3. Jun 21, 2025 at 11:26 AM
    eurowner
    eurowner Duke Sky
    Scoty
    The PM allows you to "adjust" the physical pedal movement to the throttle body flap movement. Dial up the PM, and you use little physical pedal movement to open the TBF.
    And since it's through the OBDII connector, it is the safest and no bullshit situations that the PC causes.
    JDKred[OP] likes this.
  4. Jun 21, 2025 at 11:35 AM
    gudujarlson
    Minnesota
    Or just work on your ankle range of motion.
    soundman98 and JDKred[OP] like this.
  5. Jun 21, 2025 at 1:00 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Pedal Monster would be redundant. When you got the tune, there are usually 3-5 options on gas pedal sensitivity that you could pick from. If you are happy with your choice at the time, then there's no benefit with a separate throttle controller, just more points of failure. If you aren't happy with your choice at the time, get with your tuner and flash a more aggressive tune.
  6. Jun 21, 2025 at 5:47 PM
    JDKred
    JD
    16 MT KDMax Tuned
    Nope, not at all.. Hence why I am getting feedback
  7. Jun 21, 2025 at 5:54 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
  8. Jun 21, 2025 at 6:21 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I'm not a big fan of either, but Mazel Tov for thinking outside the box brother!
