AZ 2A classifieds without the politics
Discussion in 'Arizona' started by 2ndGenJonny, Feb 12, 2021.
  1. Nov 6, 2024 at 8:52 AM
    #1761
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    That's the reason for my sale, ha. I grabbed an MOS to replace the regular 43X. Glock Store claims a 10 day turn around if you send your slide to them for milling now.
    Do you mean the metal mag release? Didn't realize those were being sold in stores now.
    I tried the Trijicon on one pistol a while back. Couldn't believe that optic cost more than the pistol is was mounted on. Sold it and went with Holosun. Really like their SCS on the full frames. I have the 507K on my 43X MOS and Micro Dagger. The 407K has a bigger dot though. Its 6MOA where the others are just 2MOA but have the 32MOA ring. Vortex makes their CCW Defender in 3 and 6MOA dots. I don't like the battery life or the auto shutoff time.
    asuchemist likes this.
  2. Nov 6, 2024 at 8:59 AM
    #1762
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Magazine release, yes. The S15 metal magazine kills the plastic magazine release. But then the metal magazine release can damage plastic magazines as well. Scheels carries the ShieldArms kit with the metal magazine release and an S15 magazine.
    Yeah ... 507k with multi-reticle small-dot/ring vs the large-dot of the 407k is the choice. Hmmm ...
  3. Nov 6, 2024 at 9:00 AM
    #1763
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
    Having a holosun on my sub compact trijicon rmr on my 19x and Leupold DPP on a fullsize I can say say the rmr is overrated a bit yes it's super rugged and will take a beating but the window size is small compared to the bigger delta point it's more comparable to my 507k holosun which is a sub compact optic and has better reticle options
    If I had to do it again would have two Leupold DPP and keep the holosun on the subcompact
  4. Nov 6, 2024 at 9:28 AM
    #1764
    Phessor
    Phessor Well-Known Member
    I just sold my 43X...
    Then purchased a 43X MOS :D
    asuchemist, TailHook and Twitch57 like this.
  5. Nov 6, 2024 at 10:27 AM
    #1765
    RichochetRabbit
    Cost difference between MOS and non-MOS is lower than the cost for Glock to machine-in the MOS-slot. And some people will use only iron-night-sights because they cannot adapt to the reticle-sights. I expect the transition to reticle-sights to be more than one box of range 9mm.
  6. Nov 6, 2024 at 10:37 AM
    #1766
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    how much does Glock charge to mill the slide?
  7. Nov 6, 2024 at 10:44 AM
    #1767
    Twitch57
    Twitch57 Well-Known Member
    N AZ
    2021 DCSB SR 4x4
    I just went through the same transition from irons to optics.
    Snap caps are the way. A lot cheaper and after a couple hours of practicing your presentation and sight picture youll be ready to hit the range.
  8. Nov 6, 2024 at 10:47 AM
    #1768
    Twitch57
    N AZ
    2021 DCSB SR 4x4
  9. Nov 6, 2024 at 11:15 AM
    #1769
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    shit.. I need to start milling slides...
  10. Nov 6, 2024 at 11:50 AM
    #1770
    RichochetRabbit
    Thanks. Saved the link data. My G45 is still non-MOS ... when I bought it in 2020 I thought I was being brilliant by choosing the G17/G19 combination despite not knowing guns before. But I may not need to as the G43x with an S15 magazine makes it almost as capable as the G45.
    There is some information I have seen in TW for how to self-modify an MOS-G43x to use Holosun 407/507 without a $50 baseplate. Maybe someone else will repeat that information about which posts to to file-down.
    Twitch57[QUOTED] likes this.
  11. Nov 6, 2024 at 12:18 PM
    #1771
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    43X MOS with the Shield Arms mag/catch is the way...
    Using a Hex Wasp that was on my old Hellcat...no baseplate required...if it ever dies, will likely run a Holosun
    Phessor and Twitch57 like this.
  12. Nov 6, 2024 at 12:21 PM
    #1772
    4runnersr569
    4runnersr569 Well-Known Member
    West Valley, AZ
    4Runner
    I was just gonna say where you at with starting slide milling
  13. Nov 6, 2024 at 12:32 PM
    #1773
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Helped a coworker with theirs. Just file down the lugs not needed. Been a while so I cant remember if it was front or rear. Super easy though..
    Just too busy with normal work unfortunately. Every once an awhile I'll be able to sneak a side project in.. but most of the time I'm trying to do my own mods to my own shit when I get those opportunities... lol
    4runnersr569[QUOTED] likes this.
  14. Nov 6, 2024 at 12:41 PM
    #1774
    RichochetRabbit
    There is something else, about not damaging the ejector components. It will come back to me, or another will say what the concern is ...
  15. Nov 6, 2024 at 1:47 PM
    #1775
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Not that I remember.. Its literally just griding down 2 posts flush.
  16. Nov 6, 2024 at 1:50 PM
    #1776
    prise
    prise AZ's Toaster Strudel Low T Andrew
    Prise
    Rally Runner 04 GX470
    Probably like a 15-20 min job tops
    XPOTRPR[QUOTED] likes this.
  17. Nov 6, 2024 at 1:52 PM
    #1777
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I need to just slap some programs together for all the different footprints. Load and Go.
  18. Nov 6, 2024 at 1:55 PM
    #1778
    prise
    Prise
    I say you most certainly should! Work on a badass little flash drive of files
    XPOTRPR likes this.
  19. Nov 6, 2024 at 2:25 PM
    #1779
    shaggy135
    I just did it on mine. Front posts all the way down and rear posts most of the way down. My 507K sits perfectly flush now.
    And the screw on the right side (if looking down the sights) needs to be shorter so it won't run into the extractor. M4 x 0.7 should be the correct size.
    Phessor and XPOTRPR like this.
  20. Nov 6, 2024 at 2:27 PM
    #1780
    shaggy135
    Yep, the screw on the right side needs to be shorter so it won't hit the extractor. M4x0.7 will fit both spot perfectly.
