AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Jun 12, 2013 at 9:53 PM
    03aztaco
    03aztaco Well-Known Member
    adam
    lake havasu,mesa
    03 prerunner
    tc lt kit, king shocks, deavers, tc hangers,tc 12" shackels, king double bypasses, cab caged, beefed taco carrier bearing drop bracket, soild motor mounts,some more to lazy haha
    Mig
  2. Jun 12, 2013 at 9:53 PM
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    Mig i am no pro welder lollol
  3. Jun 12, 2013 at 10:38 PM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    I know you're using mig lol. U runnin single shield, dual shield, or flux core wire?
  4. Jun 13, 2013 at 5:49 AM
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    Single shield
  5. Jun 13, 2013 at 7:11 AM
    esbyota
    esbyota Well-Known Member
    B-Rad
    AZ
    05 4x4 Taco
    Dual Shield? LOLZ come on now.
  6. Jun 13, 2013 at 9:43 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    is the single shield straight Co2 or is it a 75/25 Co2 argon mix?
  7. Jun 13, 2013 at 9:59 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    C25, dual runs Co2 only
  8. Jun 13, 2013 at 10:00 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    You never know, didn knows if he was going above and beyond the call. Lots of betties so it had me wondering
  9. Jun 13, 2013 at 10:12 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Betties? I call them dingleberries
  10. Jun 13, 2013 at 10:36 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Mesicans call them betties, at least the ones I was working with.
  11. Jun 13, 2013 at 11:15 AM
    esbyota
    B-Rad
    AZ
    05 4x4 Taco
    Dual is a complete waste of gas and money. Flux core wire and gas? Flux core wire is designed to sheild itself.
  12. Jun 13, 2013 at 11:37 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Not in commercial application, Co2 gets it hotter with less applied heat but will not clean out the weld without the additional help of flux. Hence dual should application. At least that is what I grew to understand.
  13. Jun 13, 2013 at 1:29 PM
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    argon mix
  14. Jun 13, 2013 at 1:53 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Helium mix on stainless lays the prettiest welds. Fuckin rainbows
  15. Jun 13, 2013 at 2:36 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    I run straight co2 on my little 135 mig. But doesn't matter because my welds are ugly as hell anyways because I don't practice
  16. Jun 13, 2013 at 2:48 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    They will lay better if you switch to a C25 mix
  17. Jun 13, 2013 at 2:54 PM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    And you will get less splatter to clean up.
  18. Jun 13, 2013 at 2:58 PM
    Aw9d
    Aw9d That one guy
    Building a new box for the type-r 12 shallow for behind the seats,
    Building another box to fit a full size Sub (undecided) which can be removed quickly so my truck can seat 4. With it in it will seat 3. Right now I have a 12 in a box just to see what it sounds like so I'm running with it.
    Removing the Type-R rear door speakers (Josh has dibbs) and leaving them out for now.
    Going to ditch my 4channel T400.4 and get a T400.2. This will allow me to push 120 watts to each of my front speakers vs. the 80watts I push now.
    Most likely ditch the Alpine PDX600 mono amp as well and get a Rockford BD1000.1 to power everything.
    Removing the 4g wire and running my Phoenix Gold 0g wire for power to the amps.
    Deep cycle battery
    I THINK that's all... Maybe a new HU since I'm at it :)
  19. Jun 13, 2013 at 3:23 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Anyone here looking to get into downhill bikes?
  20. Jun 13, 2013 at 4:11 PM
    FBGW01
    FBGW01 Well-Known Member
    Kaleb
    East Mesa AZ
    check my build
    use to bmx (not dirt racing, freestyle stuff) a lot, but ive always though some extreme downhill stuff would be fun. like full suspension bikes. But damm are those things pricey:eek:
    and little update... found a cool little kicker down the street from my house:D
Thread Status:
