AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Aug 12, 2013 at 6:37 PM
    Jonesn13
    Jonesn13 Nifty
    Tempe, AZ
    '16 T4R Trail Premium, 08 AC 4x4 6spd(Sold)
    Some, Suspension and stuff, tires, maybeh some armor.
  2. Aug 12, 2013 at 6:40 PM
    Jonesn13
    Jonesn13 Nifty
    Tempe, AZ
  3. Aug 12, 2013 at 6:41 PM
    Kyouto42
    Kyouto42 [OP] Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
  4. Aug 12, 2013 at 6:45 PM
    Jonesn13
    Jonesn13 Nifty
    Tempe, AZ
  5. Aug 12, 2013 at 6:48 PM
    Kyouto42
    Jake
    Ahwatukee, AZ
  6. Aug 12, 2013 at 6:55 PM
    Jonesn13
    Jonesn13 Nifty
    Tempe, AZ
    Still want to see that!
  7. Aug 12, 2013 at 6:56 PM
    JerryTaco
    JerryTaco Well-Known Member
    Looks like your hard line is not secured properly via c-clip or something of the like, causing it to move when the suspension droops.. Further, because of the spindle lift, it looks like the hard line might actually be a little too short the way that it is currently routed through the tab on the spindle... Either way, DO NOT drive it until you put a new hard line on the truck... Cheap part, and no sense in trying to bandaid something that is a pretty easy fix..
  8. Aug 12, 2013 at 7:41 PM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Neither is his speed sensor, who the fuck put on your spindles nick?
  9. Aug 12, 2013 at 7:47 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    did you go see this yet? i liked it :D
  10. Aug 12, 2013 at 8:28 PM
    JerryTaco
    ^^ this too... Aren't these spindles supposed to come with longer hard lines too?
  11. Aug 12, 2013 at 8:36 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I saw it, it's awesome
  12. Aug 12, 2013 at 8:38 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    what is it?
  13. Aug 12, 2013 at 8:39 PM
    PLC721
    Patrick
    Chandler, Az
    Elysium
  14. Aug 12, 2013 at 8:39 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ah
    i think i should see it
  15. Aug 12, 2013 at 8:41 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Did them myself lol.
  16. Aug 12, 2013 at 8:45 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Welp that explains it. Did you not get extended brake lines?
  17. Aug 12, 2013 at 8:56 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    Yup, they got cut in half. The ones on their now have plenty of slack though.
  18. Aug 12, 2013 at 8:57 PM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    :popcorn:
  19. Aug 12, 2013 at 10:13 PM
    JerryTaco
    Perhaps the rubber lines have plenty of slack, but the hard lines do not.. In factory form they should have a nice "z" shape to them, with the bends starting a good inch before the fitting that screws into the caliper.. And they should be firmly secured with a c-clip.. Hard lines should not move at all.. If need be, I have all the tools to make you a custom set... But your hard lines are definitely the problem, not your flex lines or anything else in the system from what I can tell..
  20. Aug 12, 2013 at 10:20 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    Yeah it probably is the hard lines. Im trying to buy new ones and maybe if you would like we can solve the problem.
Thread Status:
