AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Sep 3, 2013 at 5:59 PM
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    yeah its on the sheet they gave me
  2. Sep 3, 2013 at 6:15 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    I guarantee you its from your aftermarket intake.
  3. Sep 3, 2013 at 6:17 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    well... that's not good lol
  4. Sep 3, 2013 at 6:22 PM
    Jonesn13
    Jonesn13 Nifty
    Tempe, AZ
    '16 T4R Trail Premium, 08 AC 4x4 6spd(Sold)
    Some, Suspension and stuff, tires, maybeh some armor.
    Here is a good start for information...
    http://www.toyotanation.com/forum/7...905-error-p0171-system-too-lean-bank-1-a.html
    Other websites mention loose vacuum hoses, gas caps, dirty fuel/fuel filter and possible dirty injectors.
    I would suggest trouble shooting with the cheap stuff first. :D
    EDIT:
    If you have an after market intake the fuel/air mix is probably off.
  5. Sep 3, 2013 at 6:23 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
  6. Sep 3, 2013 at 6:25 PM
    Kyouto42
    Kyouto42 [OP] Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Because om nom nom.
  7. Sep 3, 2013 at 6:27 PM
    Kyouto42
    Jake
    Ahwatukee, AZ
    Yea what everyone said. Just give her a quick tune up and reset the battery (disconnect for about 20min)
    - Plugs (proper gap, inspect old plugs. Run Denso, not NGK)
    - Clean MAF (I just use the stuff from autozone that says do not use on TOYOTA maf's... works great lol :D )
    - Clean intake, ensure it's actually still connected too... (don't ask how I know that one lol)
    Then I'd start digging into O2 sensors after all that probably...
  8. Sep 3, 2013 at 6:30 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    ill finish watching the dictator first
  9. Sep 3, 2013 at 6:34 PM
    Kyouto42
    Jake
    Ahwatukee, AZ
    That movie so amazing.
  10. Sep 3, 2013 at 6:35 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    lol the double who gets shot
  11. Sep 3, 2013 at 6:37 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    how long should all of this take?
  12. Sep 3, 2013 at 6:59 PM
    Kyouto42
    Jake
    Ahwatukee, AZ
    Depends how fast you are with plugs, I'd book an afternoon (or morning rather, it's fucking hot out there). Maf clean is about 20min (more to let it dry). Filter... well that'll take a few hours, again for drying. (assuming you have a cleanable aftermarket from what I caught).
  13. Sep 3, 2013 at 7:01 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Yeah I've got the cleanable intake. Heat isn't an issue, knowing how is:(
  14. Sep 3, 2013 at 7:13 PM
    Kyouto42
    Jake
    Ahwatukee, AZ
    It's all pretty easy and straight forward. Plenty of youtube videos out there how to do stuffz (might not be exact to the truck but... well every vehicle is nearly the same procedure)
  15. Sep 3, 2013 at 7:15 PM
    Infamous Coating
    Infamous Coating Well-Known Member
    Avondale, AZ
    2012 Tacoma prerunner
    4" Maxtrac spindles and a 2" block on the rear
    Any suggestions on a place or somebody to help me install my Icons and Camburg UCA's. They should be here in a few days. Right now I am running the maxtrac spindles and just want the Icons set to 1/2 -1" of lift. I would love to do it here at my house but I'm lacking all the tools.
    Thanks Chris
  16. Sep 3, 2013 at 7:21 PM
    Kyouto42
    Jake
    Ahwatukee, AZ
    I'm going to have a kinda hectic weekend and it's hot as fuck otherwise I'd say do it here... heh. Shouldn't take too long minus getting the damned stock UCA bolt out is a pita the first time.
  17. Sep 3, 2013 at 7:45 PM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    We didnt have too much trouble with my UCA bolt, just bent the metal on the passenger side and used a punch and hammer. The driver side is the same thing only you will want to remove the battery. 2 person job for sure though..
    good luck
  18. Sep 3, 2013 at 7:47 PM
    Kyouto42
    Jake
    Ahwatukee, AZ
    Yea it's not that bad, most of it was figuring out how the hell they intended it to be done the first time on a $30,000 truck that had like 15k on it.... lol
  19. Sep 3, 2013 at 7:48 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    Installing the new shocks up front would probably take me half hour to do. Super easy. Never done UCA's though.
  20. Sep 3, 2013 at 7:58 PM
    2ndGenJonny
    Jon
    Gilbert, AZ
    They definitely didnt seem to consider the aftermarket. That body pinch seems to be done after the rolling chassis is assembled in the factory. Chris4x4 has a good write up on the UCA install but he has you reverse the UCA bolt. I went into my install thinking that was the way to go until Jason brought up a very good point. If you lose the nut with the bolt reversed, gravity will back that bolt out.
    Just take your time and use the right tools. Have someone at the bolt tapping it out and have someone else under the hood with a pry bar to guide it out and back in when you are done.
    Phil and Jesse did the UCA swap in under an hour with air tools.
Thread Status:
