AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Sep 17, 2013 at 7:33 AM
    Cbass38
    Cbass38 Well-Known Member
    sebastian
    scottsdale
    07 pre runner
    projector hids,wheels,small lift,flowmaster
    drive shaft binding? Maybe t case or maybe something in the diff
  2. Sep 17, 2013 at 7:34 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Is the loud noise coming from the rear diff?
  3. Sep 17, 2013 at 7:35 AM
    Kyouto42
    Kyouto42 [OP] Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Sounds like the front driver
  4. Sep 17, 2013 at 7:37 AM
    Cbass38
    sebastian
    scottsdale
    07 pre runner
    wheel bearing , front diff , front axle shaft
  5. Sep 17, 2013 at 7:39 AM
    PLC721
    Patrick
    Chandler, Az
    Well if it rolls in neutral and not in D, I think that would mean it might be a T-Case issue?
  6. Sep 17, 2013 at 7:39 AM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Half shafts binding? You did the bearings recently right?
  7. Sep 17, 2013 at 7:41 AM
    Kyouto42
    Jake
    Ahwatukee, AZ
    Not sure. When in 4 hi it reduces the effect like it's more lined up
  8. Sep 17, 2013 at 7:43 AM
    PLC721
    Patrick
    Chandler, Az
    Hmm, if I didn't have to work this morning I'd totally come help you. Is your truck still under warranty?
  9. Sep 17, 2013 at 7:44 AM
    Aw9d
    Aw9d That one guy
    Thanks.. I think she is doing AMP in 2 weeks. I'll have to ask her.
  10. Sep 17, 2013 at 7:45 AM
    Kyouto42
    Jake
    Ahwatukee, AZ
    Not even remotely. Pretty much fucked atm. Getting her towed home and not sure what to do other than start stripping armor and such
  11. Sep 17, 2013 at 7:45 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    You need a ride? As for that issue being better I would assume that is because the 4wd is helping the binding parts move easier instead of the rear end pushing through it. Call a tow truck before it gets worse from fuckibg with it
  12. Sep 17, 2013 at 7:48 AM
    PLC721
    Patrick
    Chandler, Az
    I'm pretty free this weekend Jake if you need a hand with anything
  13. Sep 17, 2013 at 7:51 AM
    Kyouto42
    Jake
    Ahwatukee, AZ
    Oh tow is in route already. Thanks. I'm just trying to troubleshoot ideas since I'm sitting here anyway. Only inched forward and back a couple of times
  14. Sep 17, 2013 at 7:53 AM
    PLC721
    Patrick
    Chandler, Az
    What were you doing when it happened?
  15. Sep 17, 2013 at 7:54 AM
    Kyouto42
    Jake
    Ahwatukee, AZ
    Getting bagles. Just turned on 48th st north to turn. Maybe 15mph
  16. Sep 17, 2013 at 8:12 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Right after a turn? Possible that the halfshaft popped out? When you get to work on it get all four up in air and stsrt checkin all four corners.
  17. Sep 17, 2013 at 8:38 AM
    Kyouto42
    Jake
    Ahwatukee, AZ
    So, just got it towed home. It appears I'm wrong, it is something in the rear (or at least, seems that way). Had the tow guy look at it, and the rear leaf hopped like mad when it did it's binding gig. So.. going to start there... and hopefully it's something stupid I'm just not seeing yet.
  18. Sep 17, 2013 at 8:43 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    You check u joint and center bearing? Pop the shaft off and rotate rear hubs to rule in/out axle.
  19. Sep 17, 2013 at 8:44 AM
    Kyouto42
    Jake
    Ahwatukee, AZ
    Well, I'm pretty sure the transfer case granaded....
    I can rotate the driveshaft by hand a bit (primary rear), which... there's always been a bit of slop there. Howerver, it binds and catches, then releases while I'm turning it by hand at the transfer case. So... yeaa....
  20. Sep 17, 2013 at 9:05 AM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
Thread Status:
