AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Jan 3, 2014 at 8:48 AM
    TheRedHorseman
    TheRedHorseman Well-Known Member
    Subsystem genocide
  2. Jan 3, 2014 at 8:51 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Welcome to the club. Have had zero traction nannies for 2 years now. :cool:
    ABS killswitch tricks the 4wd ECU into thinking its locked in the rear, which turns off trac, abs, and vsc. Throws those lights on in the cluster, but you get used to it.
  3. Jan 3, 2014 at 8:55 AM
    Kyouto42
    Kyouto42 [OP] Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Agreed with mechanical LSD... auto-LSD though is just hurting the brakes and not getting you spinning tires. It will help launch though... so not completely useless.
  4. Jan 3, 2014 at 9:00 AM
    TheRedHorseman
    Real trophy truck builders use an entire spool of flux core per diff.
  5. Jan 3, 2014 at 9:14 AM
    Kyouto42
    Jake
    Ahwatukee, AZ
    This clunk on launch of my truck is driving me nuts. I can't identify what the hell it is. All I do know is, it's worse if I'm turned slightly right. Trans mount looks ok, motor mounts look ok (Granted, this is just visual and trying to shake by hand). The exhaust is deffinatly a source of noise but, I doubt enough. I think I'm going to pull armor this morning and drive without the armor.... and tighten the exhaust. Anyone bored today?
  6. Jan 3, 2014 at 9:15 AM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Good question, I don't have it either or ABS......:cool:
    This coming from an engineer......
    Super broken race truck.....:cool:
  7. Jan 3, 2014 at 9:28 AM
    Kyouto42
    Jake
    Ahwatukee, AZ
    I can't even get my truck to drive streets without breaking ;)
  8. Jan 3, 2014 at 9:31 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Cant tell if happy or sad about this fact?:confused:
  9. Jan 3, 2014 at 9:32 AM
    Kyouto42
    Jake
    Ahwatukee, AZ
    It's sad. But I try to be happy about it.... lol. After all, LT trucks have broken on speed bumps... just means I'm at their level!
  10. Jan 3, 2014 at 9:35 AM
    TheRedHorseman
    I'm a chemist, I can flux core if I want.
  11. Jan 3, 2014 at 9:38 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    You do it up sexy, where you been btw? Finals have been over for ever ago
    LULZ
  12. Jan 3, 2014 at 9:43 AM
    TheRedHorseman
    Utah taking care of the grandparent's estate and other assorted BS.
  13. Jan 3, 2014 at 9:43 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Lower heim on your coilovers have play?
  14. Jan 3, 2014 at 9:45 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    ugghhhh mormon ville......:(
  15. Jan 3, 2014 at 9:57 AM
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    REAL race trucks use rocket engines.. None of this silly internal combustion bullshit.
  16. Jan 3, 2014 at 10:01 AM
    TheRedHorseman
    The land where women skip 30 all together and immediately look like a haggard 50 year old. Probably has something to do with having 12 kids or the lingering effects of being downwind from the Dugway proving ground.
  17. Jan 3, 2014 at 10:03 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    LMAO, fuck that land!
  18. Jan 3, 2014 at 10:12 AM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    I had the same clunk a few weeks ago, we tightened my body mounts under the cab, all of my bed mounts and my shackle bolts were loose as well. Problem solved after that.
  19. Jan 3, 2014 at 10:17 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    That's why his complaint sounded familiar, yeah check those Jakeypoo;)
  20. Jan 3, 2014 at 10:58 AM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Some of the people at VIP..
Thread Status:
