AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Oct 29, 2014 at 12:53 PM
    Aw9d
    Aw9d That one guy
    Plexi would work too. More expensive than sheet metal though. And yes the hot glue holds. You really are only using it to create a small seal and hold it in place. Once you put the deadener over it it own't move.
    Can it be removed - yes. Cut off deadener, pull panel off. It's only hot glue so if you want heat gun it for a few seconds and it will slide right off.
    Package 2 is $230 or so from Raam. That package give you enough deadener to cover the back wall twice, and all vertical walls and floor down with deadener, plus you get to cover it with Ensolite foam. I had left overs after I was done with my Tacoma.
    I ended up ordered 2 of those package 2 for my civic since the trunk will be double layered. I'm also planning on doing the roof and pulling the dash out and doing back there. I should have enough leftovers to do 2-4 doors after that.
  2. Oct 29, 2014 at 12:54 PM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    I just need to do the rear wall behind the back seats. Im taking out allot the cubbys back there so it should be fine. I trust colby decision on this stuff
  3. Oct 29, 2014 at 1:00 PM
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    So the guy that bought Alex's truck works for the same company as me just got a picture of his truck sent to me by a co worker in the parking lot haha
  4. Oct 29, 2014 at 1:01 PM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    That's good to know less than 60 sq ft filled your truck. If I have 80 it'll be plenty for Sam's and my truck.
    Thanks for the info and help! I appreciate it. I'll be doing the sheet metal too. Sounds easier.
    Nice! And I don't blame you. I was going to go the Raammat when I was first going to deaden my previous car, but was short on funds, didn't know how much it would cover and saw a good deal.
  5. Oct 29, 2014 at 1:04 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Aka Pats Gf haha
  6. Oct 29, 2014 at 1:05 PM
    Aw9d
    Aw9d That one guy
    Do yourself a favor and double layer the back wall.
    If you are feeling froggy you could do one of the following:
    Fiber glass the back wall, then put a layer of deadener over it.
    or
    Bed line the back wall, then deaden.
    Honestly anything you can think of to make that rear wall more rigid and stiff is good. That metal is pepsi can thin. I just went with 2 layers and I think it did a good job. My audio in my truck is pretty solid IMO.
  7. Oct 29, 2014 at 1:13 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    It's erics buddy. He is taking it to glamis this weekend. He had to fix a few things on it. Some of the lbj bolts were bent and some missing.
  8. Oct 29, 2014 at 1:15 PM
    snowtank
    Andrew
    Arizona
    Yeah funds are short but I have a mod thats been waiting to be installed for months now so its time to drop the coin
    Ok 2 layers it is. And im going to be painting it black so then maybe I will do bed line all the mat after that
  9. Oct 29, 2014 at 1:17 PM
    JTS2016TACO
    Jamie
    Chandler, AZ
    I knew that because of instagram a few days ago but I didnt know he worked with me
  10. Oct 29, 2014 at 1:19 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    for my backwall.. I did Raam mat when i did my install.. one layer.. then a layer of ensolite.. and I dont have the cubby's back there anymore either.. the i have ensolite and sound deadener showing.. not a big deal.. dont really care if it looks pretty behind the seats that no one will ever see. lol
  11. Oct 29, 2014 at 1:41 PM
    snowtank
    Andrew
    Arizona
  12. Oct 29, 2014 at 2:26 PM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Who is the best insane GOW boss fight of the entire series
    :D
  13. Oct 29, 2014 at 2:28 PM
    Aw9d
    Aw9d That one guy
    Bed liner would go on metal then deadener on top of that. Not sure how well deadener would hold paint or bed liner.
  14. Oct 29, 2014 at 2:34 PM
    snowtank
    Andrew
    Arizona
    The deadener mat would stick fine to the bed liner?
  15. Oct 29, 2014 at 3:06 PM
    thebeeler
    thebeeler part of the problem
    Daniel
    Yuma
    Your sister
    Total Chaos, Plate bumpers, e-locker, etc
  16. Oct 29, 2014 at 3:33 PM
    Aw9d
    Aw9d That one guy
    Yes it would. I use a roller when I install and it's sticky as hell.
  17. Oct 29, 2014 at 3:37 PM
    snowtank
    Andrew
    Arizona
    Ok sweet! Thanks for the info
  18. Oct 29, 2014 at 4:22 PM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    What do you think of 50mil thick fatmat? Seems like a good price.
    Debating between that and 70mil... I have no idea what to do lol
  19. Oct 29, 2014 at 4:30 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :woot:
    this..
    yep.. like Colby said.. its a tar like product on the back.. really sticky.
    I think I went with 80mil.. wanted the thickest shiz possible.
  20. Oct 29, 2014 at 4:43 PM
    TACO 12B
    TACO 12B Team Hoyt
    Brody
    Flagstaff, AZ
    2017 DCLB TRD Offroad 4x4
    Just saw a White DCSB with a RTT @ 102nd Pl and McDowell Mountain Ranch turning left. Was it any of you guys? I live right up the road and was in the pyrite mica dcsb.
    Badass truck. It had high clearance rear bumper and what looked like a lift on stock offroad wheels?
Thread Status:
