AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Feb 23, 2015 at 7:41 AM
    Harders1
    Harders1 I live Dangerously - I color outside the lines
    Scott
    AZ
    Lifted 2013 Sport Double Cab 4x4 Debadged
    3-inch Lift - Fabtech (Bilstein Shocks) with Add a leaf in back Differential Drop Total Chaos Upper Control Arms Cat Back MagnaFlow Exhaust Moto Metal wheels 285/70/17's - Open Country AT2's 30"inch light bar - installed in grille. Hitch - 6,000 lb rating Limo Tint Back-up camera Touch Screen Radio w/ USB and AUX connections AGR Vent Visors Shorty Antenna Sliders (weld on) (Avid) Raptor Mod - because why not
    I believe it is a OME/ToyTec Complete Suspension / lift kit for 05-14 Tacoma. not sure if that helps.
  2. Feb 23, 2015 at 7:44 AM
    Aw9d
    Aw9d That one guy
    Take out the AAL?
  3. Feb 23, 2015 at 7:48 AM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    So I assume that the billies cannot be pre loaded a bit more to get the front height to match the rear?
    Who else has this lift?
  4. Feb 23, 2015 at 7:54 AM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    That's awesome. If I'm able to find any free time I'll let you know.
  5. Feb 23, 2015 at 7:54 AM
    RPS1030
    RPS1030 Well-Known Member
    What size tires and what wheels? Where is it rubbing?
    My first thought was possibly pulling the AAL also.
  6. Feb 23, 2015 at 7:54 AM
    Harders1
    Scott
    AZ
    As far as I am aware and if I remember correctly when I had it looked at, If I pre-load the billies any more or try and go higher - The angle on the CV joints would be to much and I would need to install a different drop kit.
    Right now I have coilovers on the billestiens which is considered a level lift kit?
  7. Feb 23, 2015 at 7:55 AM
    Harders1
    Scott
    AZ
    285/70/17s
  8. Feb 23, 2015 at 7:58 AM
    2ndGenJonny
    Jon
    Gilbert, AZ
    Post pics of your CV angles please
  9. Feb 23, 2015 at 8:00 AM
    Harders1
    Scott
    AZ
    I will have to tomorrow.
  10. Feb 23, 2015 at 8:05 AM
    2ndGenJonny
    Jon
    Gilbert, AZ
    Ok, thanks.
  11. Feb 23, 2015 at 8:12 AM
    Harders1
    Scott
    AZ
    You say you are a former 6" lift, there a reason why you no longer at 6?
    End of the day I would like to go slightly higher and get my truck level. Just this lift right now, is annoying the crap out of me and the rubbing. I feel as if the rubbing is above normal.
    I had an 03 Tacoma pre-runner with a Fabtech 3inch with 285/75/16's and only rubbed when I was fully flexed with wheels fully turned. On this Tacoma however I can get rubbing just by turning my wheels.
  12. Feb 23, 2015 at 8:21 AM
    ProZach
    ProZach Well-Known Member
    Arizona
    03 Prerunner
    5100s on mid setting, allpro leaf springs
    he just bought a new truck
  13. Feb 23, 2015 at 8:23 AM
    Harders1
    Scott
    AZ
    Ahh, sorry I am at work. Only enough time to write a response and send. You can be sure I will be researching a lot more tonight lol
  14. Feb 23, 2015 at 8:32 AM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
  15. Feb 23, 2015 at 8:48 AM
    2ndGenJonny
    Jon
    Gilbert, AZ
    Lots of reasons I went away from the 6" and got a new truck. We can discuss those later. You run a big tire, are they MTRs?
    Regardless a 3" lift will have some issues with that size tire. A CMC and some pinch weld pounding will be needed.
    We just need to see the angles of the CV and how much pre load you have. I would also like to see the leaf pack.
  16. Feb 23, 2015 at 8:49 AM
    Harders1
    Scott
    AZ
    Open Country AT2's
  17. Feb 23, 2015 at 9:00 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Lol I remember when this place used to be fun, now its more like the AZ drama/butthurt thread
  18. Feb 23, 2015 at 9:05 AM
    Jonesn13
    Jonesn13 Nifty
    Tempe, AZ
    '16 T4R Trail Premium, 08 AC 4x4 6spd(Sold)
    Some, Suspension and stuff, tires, maybeh some armor.
    #I'llmakeyourbutthurtthread
  19. Feb 23, 2015 at 9:08 AM
    2ndGenJonny
    Jon
    Gilbert, AZ
    Good choice, post up some pics when you can. I don't see any reason why you cannot keep what you have and just do a little tweaking. Going to a 6" is a costly jump.
  20. Feb 23, 2015 at 9:08 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    you can easily get your truck level, and be able to clear 33's with 3" of lift.. while also maintaining decent CV angles.. trust me.
    either..
    1) pull the AAl
    2) preload fronts more (should do this regardless if you want to clear your 33's and level your truck, though, you will still have rubbing, but can be fixed, comes with the 33" tire territory)
    once you get to that 3" lift mark.. it is recommended you get new aftermarket UCA's to get into alignment spec.
    1.5" of lift in the rear + 3" up front will sit you about dead level.
    im roughly at the above set up. 1.5"-2" in the rear.. and 3"+ up front. no CV binding or issues, alignment is good. etc
Thread Status:
