AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. May 29, 2015 at 10:33 PM
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    So this is what I'm working with. You guys think it's best to just run it full length of the truck an put the switch inside? Also would like them hooked up to the reverse lights as well.
  2. May 29, 2015 at 10:37 PM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    I would personally. I would hate not to have that on a switch
  3. May 29, 2015 at 10:39 PM
    StOrMyThEtAcO
    Cody
    CO
    All of them
    yeahh i was just trying to make it easy on myself an not try an wire it to the cab "thats what i want" but I've never done anything like that so i was just trying to go the easy route but ill try an tackle it.
    what would be the best way to run the wires then? along the frame?
  4. May 29, 2015 at 10:47 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yes. I ran mine up inside the frame rail as best I could. there will be a few places you will have to deviate from that path due to harnesses, gas tank, etc, but for the most part the frame. when you get to under your driver seat you will see a grommet under the cab. you can use this to enter into the cab if you want. this is where I ran my CB Coax through. just silicone afterwards. 3 years and not an issue here.
    snowtank likes this.
  5. May 29, 2015 at 10:47 PM
    snowtank
    Andrew
    Arizona
    I went along my frame tucking it as much as possible then right under the driver seat is a spot where you see wires with a rubber bushinggoing into the cab. You can pull it up there under tthe carpet and run it to where ever you want. Its rather simple just takes a little time.
  6. May 29, 2015 at 10:48 PM
    snowtank
    Andrew
    Arizona
    Damn josh beat me
  7. May 29, 2015 at 10:50 PM
    StOrMyThEtAcO
    Cody
    CO
    All of them
    Do you think it would be better for me to run it all the way under to the engine bay for power then back through the firewall to the switch? or under the seat through the fire wall an back?
  8. May 29, 2015 at 11:11 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    damn.. great minds.. :cheers:
    since you're doing a switch. run it into the cab.. you will make your connections there, and continue on to the battery/fuse block, for power.
    I believe.. i cant remember.. guess I could go look out at the truck..
    I've also been drinking, sooo...
    snowtank[QUOTED] likes this.
  9. May 29, 2015 at 11:12 PM
    snowtank
    Andrew
    Arizona
    Ground goes straight to frame.
    power you can run into the engine bay then you need to run power to your switch.
    then you need to run ground from switch in the cab. All depends on which way you want to do it. What works for you and your truck. If you go straight to the battery make sure you tuck it and zip tie it good. Dont want a stray rock snagging it or whatever fucked up could happen. You gotthis tho :thumbsup:
  10. May 29, 2015 at 11:14 PM
    snowtank
    Andrew
    Arizona
    :cheers: josh good man!
  11. May 29, 2015 at 11:15 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :cheers: :rasta:
    what are you doin still up?
  12. May 29, 2015 at 11:21 PM
    StOrMyThEtAcO
    Cody
    CO
    All of them
    thanks fellas!
    i may try an start this tomorrow till work. otherwise sunday funday project!
  13. May 29, 2015 at 11:24 PM
    snowtank
    Andrew
    Arizona
    Just got off work and got home a hour ago. Im winding down drinking a couple.
    And no problem cody. I will be down Wednesday and working on my truck if you want a hand or just someone to answer questions.
  14. May 29, 2015 at 11:26 PM
    StOrMyThEtAcO
    Cody
    CO
    All of them
    for sure well I'm up in flagstaff but i will most deff hit y'all up if i need.
  15. May 29, 2015 at 11:29 PM
    snowtank
    Andrew
    Arizona
    [QUTOTE: StOrMyThEtAcO, post: 10306850, member: 151561"]for sure well I'm up in flagstaff but i will most deff hit y'all up if i need.[/QUOTE]
    Oh youre up in flag. Im in show low. You're closer than phx to me
  16. May 29, 2015 at 11:38 PM
    StOrMyThEtAcO
    Cody
    CO
    All of them
    ahh ok yeah just a hop skip an jump away
  17. May 29, 2015 at 11:40 PM
    snowtank
    Andrew
    Arizona
    Takes me a hour thirty to Flag from the house. A little more if I go the limit lol
  18. May 29, 2015 at 11:41 PM
    StOrMyThEtAcO
    Cody
    CO
    All of them
    haha i always drive the speed limit after a criminal speeding ticket :facepalm:
  19. May 29, 2015 at 11:51 PM
    snowtank
    Andrew
    Arizona
    I got out of a 88 in a 50 because I wore a tie to court. Haha only person dressed for the judge and she surpassed traffic school rules for me. It was awesome!
    TaylorU likes this.
  20. May 30, 2015 at 6:41 AM
    RI Tacoma
    RI Tacoma Well-Known Member
    Tim
    Phx sometime soon
    2011 Sport DCLB
    OME 885's, Derped FJ TRD Wheels, Hankook Dynapro's ATM 265/75/16's, Retro's, WeatherTech Liners, Fog Light Mod, Bak Flip F-1, N-Fab Steps, 20% Tint, complete stereo, heated mirrors, Katzkin seats!!
    I'm heading up to phoenix today to pick up my kid from the inlaws. If anyone sees a lifted silver limo with a cap and stock tires it's me. Lol. Can't want to take the cap off and put the hankooks back on.
Thread Status:
