AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Feb 10, 2012 at 11:51 AM
    #7641
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    Like this? This is for 4wd to clear the axle
    Then you flip the coilover adapter and cut the bucket to compensate for the longer lower rod end
  2. Feb 10, 2012 at 11:56 AM
    #7642
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    nope, in that second picture they only did that to gusset the coil bucket because they had to notch it for the resi hose. if you dont gusset that all hell can break loose. paden had his gusseted like this..
    before^ after V
  3. Feb 10, 2012 at 11:58 AM
    #7643
    jtlachac08
    jtlachac08 Well-Known Member
    Jeremy
    Phoenix, Az
    Here's mine I'm at a different ride height now though....
  4. Feb 10, 2012 at 12:01 PM
    #7644
    97yota4wd
    Eric
    Mesa, AZ
    TC coilover mounts look like this- so the top sticks through on some kits, but it depends on where your resi hose is at now.
    burg-
    saw-
    i dont think you should have the longer rod ends.... i really dont know but i know you have to have the cone mount to fit the axel
  5. Feb 10, 2012 at 12:01 PM
    #7645
    05TacoRunner
    Peoria, Az
    With Icons maybe... with Fox shock and Kings the adapter from total chaos alows you to bolt in the prerunners with out cutting the bucket you need to cut it when 4wd
  6. Feb 10, 2012 at 12:02 PM
    #7646
    05TacoRunner
    Peoria, Az
    Different on 1st gens vs 2nd gens
  7. Feb 10, 2012 at 12:02 PM
    #7647
    jtlachac08
    Jeremy
    Phoenix, Az
    Right I didnt utilize my coilover adapters cuz of the OEM top mount that king supplies, and no need to cut the coilover bucket being 2wd
  8. Feb 10, 2012 at 12:04 PM
    #7648
    97yota4wd
    Eric
    Mesa, AZ
    even the mounts are?
    i think with icons you have to do it either way though
  9. Feb 10, 2012 at 12:06 PM
    #7649
    05TacoRunner
    Peoria, Az
    Correct but when you run the 4wd you cut the bucket and move the coil over up to compensate for the longer end. It looks like in your application you are running the 4wd adapter with no cut coil bucket and no bumpstop extension. You will bottom out your shock way befor you hit the bumps
    Here is the chaos mounts for coil overs
  10. Feb 10, 2012 at 12:06 PM
    #7650
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    There seems to be a ton of different setups but I think the upper mount is more dependent on the shock than the kit. The long lowers are to clear 4wd axles but Im not sure if they keep the long rod on 2wd. That one picture the coil bucket is super notched because of the added length of the rod end. The ICONS are notched because of the way the resi hose mounts. My upper mounts look exactly like the chaos ones eric posted and mine are camburg and kings
  11. Feb 10, 2012 at 12:07 PM
    #7651
    97yota4wd
    Eric
    Mesa, AZ
    yeah those rod ends are def for 4x4.
  12. Feb 10, 2012 at 12:09 PM
    #7652
    Cr250jumper
    The moon
    50 shades of tan©
    I think this is correct, if you have the extended lower rod but do not have a notched bucket you are losing some of your up travel. Jeremy have you ever cycled your front end with the sock in but no springs?
  13. Feb 10, 2012 at 12:11 PM
    #7653
    jtlachac08
    Jeremy
    Phoenix, Az
    The bump stop extensions werent in, in that pic. They are now. I still have the eyelet adapters from TC if anyone needs them.
    Are the longer rods ends affecting me any? Like I said the truck runs good.
  14. Feb 10, 2012 at 12:15 PM
    #7654
    05TacoRunner
    Peoria, Az
    ^ This....
    With out the notched bucket you are bottoming out the shock before the bumpstop and loosing up travel.
  15. Feb 10, 2012 at 12:18 PM
    #7655
    jtlachac08
    Jeremy
    Phoenix, Az
    I have not, However when I set the front to full droop without the straps attached. The shock is full extended before the uniballs are. But, at that point the uni's are at their max point to where TC says to put them with the straps in....
    Does that make sense?
  16. Feb 10, 2012 at 12:20 PM
    #7656
    05TacoRunner
    Peoria, Az
    Also forgot to mention that when I bought my kit I had SDHQ order it and forgot to tell them the spring rate I wanted and the ordered 500lb springs...
  17. Feb 10, 2012 at 12:23 PM
    #7657
    jtlachac08
    Jeremy
    Phoenix, Az
    Im lost
    I what way would notching the bucket be of any significance to me?
    The top mount on my coilovers bolt into the stock three bolt holes of the bucket.
    Mine are like this
    not this
  18. Feb 10, 2012 at 12:24 PM
    #7658
    Cr250jumper
    The moon
    50 shades of tan©
    Yeah like your uniballs have more room but not usable. You should have enough up travel then. My shocks still have about an inch or more of down travel left from where they are strapped on down travel and my wheel hits the core support/fender wall before my shock bottoms on up travel. I has no bumps in front :eek:
  19. Feb 10, 2012 at 12:27 PM
    #7659
    Cr250jumper
    The moon
    50 shades of tan©
    They are the same, the top one has a bolt of some kind going through it and that is just a top plate of a different style like eric posted. You would benfit more from getting a non extended lower rod. Those come off of the shaft and you shouldnt even need to take the shock apart (other than springs). It would also lower the preload and drop your truck down a little
    EDIT: But you may end up not having enough downtravel if your shock are maxed at down travel now. I would cylce it before you change anything
  20. Feb 10, 2012 at 12:27 PM
    #7660
    jtlachac08
    Jeremy
    Phoenix, Az
    I have no bumps either, other than what the TC spacers are giving me.
    I've never bottomed it out either, but did notice after sycamore I had some rubbing on the inner fender structure. But not much
Thread Status:
