AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Jan 19, 2016 at 3:49 PM
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    I'm gonna be mounting mine this week!
    snowtank likes this.
  2. Jan 19, 2016 at 3:50 PM
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    :worthless:
    post pics so i can see haha
  3. Jan 19, 2016 at 3:56 PM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    [QUOTE="StOrMyThEtAcO, post: 11614914, member: 151561]i wish it wasn't so ugly on the hood right there cause it would be easy as hell to run the cable[/QUOTE]
    You can unscrew the antenna off the spring and store It in the truck while around town. Then when you get ready to hit the trail you screw it back on
    StOrMyThEtAcO likes this.
  4. Jan 19, 2016 at 3:57 PM
    The Fluffer
    Andrew
    Scottsdale, AZ
    boughten
  5. Jan 19, 2016 at 4:07 PM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Jesus! Pic of the Fluffer mounting his CB.
    The Fluffer likes this.
  6. Jan 19, 2016 at 4:09 PM
    Desert Drifter
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    But, that little Uniden is a good little radio, for the limited range CB is good for. That's what I have.
  7. Jan 19, 2016 at 4:17 PM
    snowtank
    Andrew
    Arizona
    Yeah I really like mine. Never more than 2 miles away from the other trucks so for my purpose its awesome
  8. Jan 19, 2016 at 4:29 PM
    StOrMyThEtAcO
    Cody
    CO
    All of them
  9. Jan 19, 2016 at 4:30 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Exactly. It's been great.. And I love that it fits inside my center console, completely hidden. I dont want to replace it because of that reason! I just need to retune mine, and replace my antenna aux cable coupler thingy.. Lol its stripped so I cant fully crank it tight on my mount.. Maybe upgrade the antenna as well.
  10. Jan 19, 2016 at 4:30 PM
    StOrMyThEtAcO
    Cody
    CO
    All of them
    You can unscrew the antenna off the spring and store It in the truck while around town. Then when you get ready to hit the trail you screw it back on[/QUOTE]
    That's true didn't think of that.
    If I had armor up front I don't dislike it on the front bumper as much as by the windshield.
    snowtank[QUOTED] likes this.
  11. Jan 19, 2016 at 4:37 PM
    snowtank
    Andrew
    Arizona
    Yeah front bumper looks cool too. There are allot of options to do.
  12. Jan 19, 2016 at 4:39 PM
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    What would be a solid upgraded unit?
  13. Jan 19, 2016 at 4:41 PM
    snowtank
    Andrew
    Arizona
    Just one like andrew got. The fluffer. Something with thr weather band and a higher amp out put for further range.
  14. Jan 19, 2016 at 4:42 PM
    AZ2013
    Blake
    Gotcha. That's on my list but way down the line. Haha. Just figured I'd ask and get some suggestions. Thanks.
  15. Jan 19, 2016 at 4:48 PM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    I have the Cobra 75Wx. Only the Mic is visible. The box is under the center console near the shift. Firestick 4' Antenna.. but need to run a new antenna wire. I have an handheld SWR meter if anyone needs it.
    Got all my green switches today.... just waiting for the bracket, then will put the sunglass holder to good use!
  16. Jan 19, 2016 at 4:50 PM
    The Fluffer
    Andrew
    Scottsdale, AZ
    boughten
    Probably where Snow has his on the passenger side of the shifter. It's too big to go anywhere else but the center console. Unless I change out my stereo for a smaller one with a double din.
    That's where I want my switches. Did you go with the one from S-Podd?
  17. Jan 19, 2016 at 4:54 PM
    Techoma
    Alta Mesa, AZ
    Nope.... just a housing from Amazon to hold the new switches. One long rectangle hole cut, and voila! I think I'm going to make a harness and run it up the pillar rather than individual wires... then Sharpie the color code inside the pillar.
    My Cobra has weather on it too.... but I can open the window and look just as easy!!!!
    genequit likes this.
  18. Jan 19, 2016 at 5:10 PM
    AZ2013
    Blake
    Techoma likes this.
  19. Jan 19, 2016 at 5:18 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    That's where mine will be going as well! Flush mounted in the sunglass holder. You gonna fit all 7 in there?
    Wanting to do a dual battery setup prior to changing/adding all my lighting and switches. Want to run one harness down the pillar at once..
    Techoma, The Fluffer and Brian007Taco like this.
  20. Jan 19, 2016 at 6:38 PM
    Techoma
    Alta Mesa, AZ
    6 up top, the others on the left of the dash (normal). I'm splitting some of my "pairs" so I can have more control. I'm waiting on my Shok sheets so I can sound proof the cab before I run anymore wires. Dual battery.... NICE!!!
Thread Status:
