AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Feb 16, 2016 at 9:43 PM
    cmyersgo
    cmyersgo Well-Known Member
    Carter
    Queen Creek AZ
    Haha would a belt sander work or could I just use a dremel? My only concern with a dremel is making it level in the back
  2. Feb 16, 2016 at 9:44 PM
    cmyersgo
    Carter
    Queen Creek AZ
    I don't have any spare headlights so I'm a bit worried.. haha
  3. Feb 16, 2016 at 10:13 PM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Pulling apart is easy, wiring easy, getting shit glued together and held in place evenly is the "fun" part.
    cmyersgo likes this.
  4. Feb 16, 2016 at 10:39 PM
    cmyersgo
    Carter
    Queen Creek AZ
    Haha I didn't even think about that part..
  5. Feb 16, 2016 at 10:40 PM
    cmyersgo
    Carter
    Queen Creek AZ
    I'm gonna need an extra pair of hands with this project
  6. Feb 16, 2016 at 11:59 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    1st gen lower ball joints are actually plastic, and that is why they fail
  7. Feb 17, 2016 at 2:49 AM
    genequit
    genequit Well-Known Member
    Gene
    Goodyear Arizona
    white
    Lol I think that's part of their culture there. My brother and I got into a fight with some Taiwanese expats in a casino in Subic Bay years ago. They are just naturally rude and have no concept of personal space.
  8. Feb 17, 2016 at 6:30 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    Anybody coming to Phoenix from Tucson in the near future? Looking for a mule. :rolleyes:
  9. Feb 17, 2016 at 6:38 AM
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    For the diff, it you want to fully reseal the third it's best to remove the third. So you don't get any gasket inside the housing. This means you have to put on jack stands, take off tires, unbolt driveshaft, drain fluid, remove locker from the third, pull axel shafts about 2in out on each side then finally unbolt and pull out the third assembly. Then just remove the old gasket, put on your new one. Repeat the process backwards and film when it's back together. It's really not that bad, I did mine about a year and a half ago and it probably took me 2 hours. I just used gasket maker instead of the crappy oem gasket. No leaks or problems..
    05TacoRunner and snowtank like this.
  10. Feb 17, 2016 at 7:12 AM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    That sounds like a bitch. Hum. Well It sounds like enough work since im in there I could just regear too right?
    StOrMyThEtAcO, AZ2013, llibrm and 4 others like this.
  11. Feb 17, 2016 at 7:12 AM
    Zona Scout
    Zona Scout The Local Marina Master Baiter
    Cody
    Tucson, AZ-->Oahu, HI
    2013 Wannabe Baja Badass Storm Trooper Knock Off Attempt
    Generic Cliche Bullshit
    I'm coming up in 12 March if no one else is and you can wait
    llibrm[QUOTED] likes this.
  12. Feb 17, 2016 at 7:13 AM
    snowtank
    Andrew
    Arizona
    @Moose1988 yeah if you got the part numbers that would be awesome
  13. Feb 17, 2016 at 7:18 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    They you have to do the front and setting up gears is not an easy job....
  14. Feb 17, 2016 at 7:23 AM
    snowtank
    Andrew
    Arizona
    Well shit. Ok no rear gearing then
  15. Feb 17, 2016 at 7:33 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thats why I never did mine Andrew ^^
    I'll grab the #'s at lunch today.
  16. Feb 17, 2016 at 7:34 AM
    RI Tacoma
    RI Tacoma Well-Known Member
    Tim
    Phx sometime soon
    2011 Sport DCLB
    OME 885's, Derped FJ TRD Wheels, Hankook Dynapro's ATM 265/75/16's, Retro's, WeatherTech Liners, Fog Light Mod, Bak Flip F-1, N-Fab Steps, 20% Tint, complete stereo, heated mirrors, Katzkin seats!!
    That or if anyone is heading to/from Globe or Showlow to PHX. I will be driving through both on Friday and Sunday.
    Brian007Taco likes this.
  17. Feb 17, 2016 at 7:36 AM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    ECGS builds and ships complete 3rd members and you give them your core. I think it's about 2100 if you do all of the labor front and rear. This was pulled from another thread recently. I believe it was the 3" w35s thread.
    snowtank[QUOTED] likes this.
  18. Feb 17, 2016 at 7:37 AM
    snowtank
    Andrew
    Arizona
    Cool sounds good. Thanks
  19. Feb 17, 2016 at 7:39 AM
    snowtank
    Andrew
    Arizona
    Wow thats still allot more than I have funds for right now. So I will just be fixing the leak and maybe get around to putting In the diff breather
    Zona Scout likes this.
  20. Feb 17, 2016 at 7:40 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Yeah it's about 2100 up front but then you get 950 back when you send in your cores. Ordering mine up once tax money gets here
Thread Status:
