AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Apr 8, 2016 at 1:09 PM
    06 Tacoma Amocat
    06 Tacoma Amocat Well-Known Member
    Bernard
    19 TRD sport 4x4
    Friday!!!
    Brian007Taco likes this.
  2. Apr 8, 2016 at 1:35 PM
    HectoRome
    HectoRome Playing Scientist In The PNW
    07 PreRunner SR5 TRD Off-Road Debadged, Icon Stuffs, MaxTrac Spindles, Dirt King LCAs, Archive Garage Shackle Flip
    59926P ICON 2.5 Remote Reservoir Front Coil Over Shocks 56103 Icon Rear Hydraulic Bump Stop Kit K53163 Icon RXT Leaf Springs Kit 58730 Icon 2.5 Front Remote Reservoir Coil overs 59926P Icon 2.5 RXT OMEGA Remote Reservoir By-Pass Shocks 58550 Icon Billet Aluminum Upper Control Arms Dirt King Steel Lower Control, 1” Uni-ball Joints Archive Garage Rear Leaf Spring Shackle Flip Kit TRD Cat Back Exhaust TRD High Flow Air Filter Kenwood Receiver + JL Audio Speakers Extended Stainless Steel Front Brake Lines Extended Stainless Steel Rear Brake Lines Electronic Locking Rear Differential Rigid LED Driving Lights LED Bar in Bumper Top Windshield LED Bar Custom TACOMA Raptor Grill w/ LED Running Lights METHOD Standard Matte Black Wheels
    So I wound up going to the stealership to buy a new TPMS sensor ($78) and had it associated / annotated to my warranty (bought sensor at same stealership I bought the truck from) so it would be covered under my extended warranty. I then had everyone and and their cousin to get quotes from. Walmart had the best deal for unmounting / mounting current undersized spare, installing sensor on steel wheel and programming the sensor to the truck ECU. Dealership wanted $100 to program, Discount + Big O wanted $19.99 but Walmart did it for free, only $4.99 to install sensor ! ! !
    Big O sold me a Hankook LT400 285/75-R16 for $109 mounted/balanced/road hazard for $139.00
    There's a ton of background here as I had a 2012 steel wheel, my truck is an 07 and 07 steel wheels had a different angle for the valve stem seat/sealing surface for the TPMS. Had to go back to the dealership explain I have a 2012 spare steel wheel, which requires an Alloy Wheel TPMS (seat angle is different) so that it would correctly mount up and seal into the steel wheel.
    In Summary
    2006 Early 2009 Tacoma Spare Steel Wheels Require - Steel Wheel TPMS
    Late 2009 Tacoma Spare Steel Wheels DO NOT Require TPMS - NO Longer Equipped.
    2010/2016 Spare Steel Wheels if Used on Early 2009 or EARLIER Tacoma Require ALLOY Wheel TPMS
    ALL New TPMS Sensors MUST Be Programmed To Vehicle ECU
    Simply 'Resetting' by using button located underneath on the steering column will only change tire pressure threshold for when to signal ECU tire pressure is low - It WILL NOT Program A New Sensor.
    I Go Through All The Pain - You Get All The Gain - No Pain No Gain - Learn From ME Peoples . . .
    Techoma and llibrm like this.
  3. Apr 8, 2016 at 2:10 PM
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    Glad you figured it all out buddy! sorry for all the confusion..
  4. Apr 8, 2016 at 2:34 PM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    Serious? I have thermo next semester.
  5. Apr 8, 2016 at 2:35 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    on average each problem takes a minimum of an hour
  6. Apr 8, 2016 at 2:36 PM
    a.smo
    Aaron
    PHX, Az
  7. Apr 8, 2016 at 2:39 PM
    Aw9d
    Aw9d That one guy
    So far it's been pretty mellow. My brother has been playing star wars religiously for a few days. I got all sorts of credits to spend now haha.
  8. Apr 8, 2016 at 2:40 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I figured t hat was him playing it the other night. lol
    what are you doin after work?.. i mean... after IM off work. lol
  9. Apr 8, 2016 at 2:54 PM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Was running on fumes...
    phx13 likes this.
  10. Apr 8, 2016 at 2:55 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    hahaha.. that was me Monday after the meet. think it shut off at 19.5.. I overfilled to 20. lol
    Techoma[QUOTED] and Zona Scout like this.
  11. Apr 8, 2016 at 3:01 PM
    signalbobby
    signalbobby Well-Known Member
    Robert
    Arizona
    18 Rapturd
    Sorry.. lol. j/k
  12. Apr 8, 2016 at 3:04 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    so.. fucking.. bored..
    running out of TW..
    I have barely done anything today.. 2 hours left.
    Techoma likes this.
  13. Apr 8, 2016 at 3:11 PM
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    I've been there. Go make me some stuff for my truck.
  14. Apr 8, 2016 at 3:13 PM
    Brian007Taco
    I have unfortunately been closer than that to empty. I've gotten to 20.5
    ocherp and Techoma[QUOTED] like this.
  15. Apr 8, 2016 at 3:13 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    lol..
    was gonna grab some scrap and make something.. eyeing this big ass piece of square tubing.. would make for a nice HC rear bumper...
    Brian007Taco[QUOTED] likes this.
  16. Apr 8, 2016 at 3:14 PM
    Brian007Taco
    Dew it!
  17. Apr 8, 2016 at 3:18 PM
    Cannonball
    Cannonball Well-Known Member
    Justin
    Phoenix
    2012 F-250 FX4 6.7 diesel / 1979 Jeep CJ-5
    Bought a used camper shell and the roof is sagging. It has Yakima tracks on it. I was thinking of removing the tracks and bending a curve in them and then maybe getting some flat stock, bending a slight curve in them, and making some stiffener cross rods which would mount inside the shell through the Yakima track bolts. Seems easy enough right?
  18. Apr 8, 2016 at 3:20 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Damn.. Just measured it.. JUST shy of what it probably needs to be.. 53" in length.
  19. Apr 8, 2016 at 3:21 PM
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    PM me your number. I got an idea I want to run by you. You can tell me if I'm a genius or dreaming. Haha.
  20. Apr 8, 2016 at 3:23 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    you wouldnt want anything that heavy josh. you want light. lol.
Thread Status:
