AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Jul 1, 2012 at 10:32 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    I took everything off the switch. so going into the cab I have the wire plugged into 86.
  2. Jul 1, 2012 at 10:37 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    if 85 is to ground, then 86 has to be hot to energize the coil that closes the contacts between 30 and 87. that then energizes the lights which need their own ground to close the circuit.
    so a hot wire needs to run into the switch and the other of the switch goes to the relay
  3. Jul 1, 2012 at 10:39 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    so have power go to the switch and then ground it? because I tried that and it didn't work
  4. Jul 1, 2012 at 10:41 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    power to switch, then switch to 86. that should make it atleast click
  5. Jul 1, 2012 at 11:16 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    David that worked. I called it a night an will play with it some more tomorrow. Might have to redo the connections out back.
  6. Jul 2, 2012 at 3:09 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    AM I in the right thread?.??/
  7. Jul 2, 2012 at 7:18 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    no sir, the Magic Mike thread is in the off topic section. :D
  8. Jul 2, 2012 at 1:02 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Anyone wanna do something for the 4th? Like little BBQ during the day then go line up the tacos in a field and watch fireworks?
  9. Jul 2, 2012 at 1:03 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Pool and bbq.. our place?
  10. Jul 2, 2012 at 1:05 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Works. Their is this big lot by where chandler does theirs we can park that night
  11. Jul 2, 2012 at 1:30 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I live within viewing distance of the one they do at Schnepf Farms. If I dont have my daughter I may head up and meet you guys
  12. Jul 2, 2012 at 3:21 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    So maybe later after the roommate leaves ripping the wiring I just and starting over. lol :facepalm: Need more relays because the lights aren't getting enough power to all five the way I set it up.
  13. Jul 2, 2012 at 3:30 PM
    Cr250jumper
    The moon
    50 shades of tan©
    You and your "I have too many HID's" problem :p by the way I have those motor mounts in my truck if you still want them
  14. Jul 2, 2012 at 3:37 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    ugh such a problem lol The thing I'm bummed about is I heat shrinked, soldred and wire loomed everything and now it has to come out. Also there is no where in 1st gens to mount stuff in the engine bay.
    Cool, I'll snag them from you tomorrow. I should have don'e it today when I was in that area but didn't even think about it.
  15. Jul 2, 2012 at 4:34 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
  16. Jul 2, 2012 at 4:49 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    No gopro's at 50% off.... *sob*
  17. Jul 2, 2012 at 5:19 PM
    Jonesn13
    Jonesn13 Nifty
    Tempe, AZ
    '16 T4R Trail Premium, 08 AC 4x4 6spd(Sold)
    Some, Suspension and stuff, tires, maybeh some armor.
    So this year will be the 3rd time in my adult life that I will be in the country for 4th of July. I am pretty excited.
    Too bad the fire danger is so bad, otherwise I would be goin crazy with the fireworks.
  18. Jul 2, 2012 at 5:20 PM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    :spy: Garrett watching :spy:
  19. Jul 2, 2012 at 5:31 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    x2..
  20. Jul 2, 2012 at 5:47 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Damn did you guys see the story of the kid that got hit on the bicycle in chandler? I found out my sister has been good friends with his dad since high school. They had a car wash over the weekend and raised $9k
Thread Status:
