AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Sep 26, 2012 at 12:00 PM
    TheGloryFades
    TheGloryFades Well-Known Member
    Seth
    Arizona
    '13 toaster
    Yeah it's been a rough week to say the least. luckily today is Friday
  2. Sep 26, 2012 at 12:01 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I guess. Be safe out there man.
    On another note.. still haven't heard from the dealer. Not sure if that's good or bad.
  3. Sep 26, 2012 at 1:04 PM
    superswamper003
    superswamper003 Taco
    Hendrik
    N. Snottsdale Arizona
    1998 4wd TRD 3.4l Tacoma Xcab 313k miles!!!
    Fox Xtended travel coilovers w/resis, AllPro UCA's, AllPro 3 inch leaflets, 1" Diff Drop, 285/75/16 Bfg KO, 16x8 Black Pro Comp Steelies, AP 1.25" wheel spacers in front, 8 inch Rockford Fosgate sub that bumps like your mother, old school deck, downey headers, cold air intake, grey wire mod, e-locker, hurst shift knob, LED Strips, USMC Decals FTMFW, Fox decal, Billet grille, Alarm with no remote, Straight piped to the side of the truck
    Im sorry you have to be there so much :(
  4. Sep 26, 2012 at 1:26 PM
    Aw9d
    Aw9d That one guy
    Meh I'm sure its fine. The dealer you go to is always busy.
  5. Sep 26, 2012 at 2:01 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Dealer just called. Battery was toast, they had to put in a Said the road force wont do anything.. the tires are too out of whack. The blower motor needs to be replaced.. My brakes front and rear need to be cleaned/resurfaced.. blah blah blah. Etc etc.. so.. do i have them road force the tires anyways? Should I just say no to everything and go to discount and or do it myself? They said 780 for everything. No way I can drop that much right now.
  6. Sep 26, 2012 at 2:03 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Breaks are easy do it yourself.
    Battery I have had great luck with the Autozone Golds ~$100
    I say do the blower motor and then thats all Or buy one on rock auto and we will do it.
  7. Sep 26, 2012 at 2:03 PM
    Aw9d
    Aw9d That one guy
    Have discount do the balance. According to their shop manager when I asked for Road Force he stated that their new machines do better than road force older machines. IDk.
    Brakes- you and I can do those in my garage.
    Blower motor- not sure how hard that is to replace. Bet we can do that too.
    Yeah man, lets start wrenching!
  8. Sep 26, 2012 at 2:06 PM
    Aw9d
    Aw9d That one guy
    There ya go Josh. We'll have a mini wrenching party and get all your shit on your truck fixed at once.
  9. Sep 26, 2012 at 2:12 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I would call BS on that one. If the pads are good you probably dont need to resurface unless you can feel it in the brake pedal. If you dont feel a shudder in the pedal when braking just remove the tires and spray the rotors and calipers out and you will be fine. Also if the rotors truly need resurfaced you should be changing pads too
  10. Sep 26, 2012 at 2:13 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
  11. Sep 26, 2012 at 2:14 PM
    dbkid05tacoma
    dbkid05tacoma Well-Known Member
    Brooks
    Phoenix, Arizona
    05 long travel 4.0L
    Total chaos long travel, fox 2.5 coil overs, glassworks unlimited fenders front and rear, DMZ fab motor mounts, Bilstien 5100s in the rear, k&n cold air intake, 33/12.5r17 red letter grabbers
    i found a turbo 2jz with matching transmission for 2500 online :D
  12. Sep 26, 2012 at 2:17 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Ah yes the 2jz swap, Ive heard of this
  13. Sep 26, 2012 at 2:18 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    as always JD, ftw.
  14. Sep 26, 2012 at 2:19 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'm JUST out of warranty. This sucks. I completely forgot I didnt have the extended warranty.. that was my last Taco.. I got them mixed up. So.. this is all new for me. I've always had extended warranties.
    I told them to do the service (obviously) and the battery. They couldn't even do the tests cuz it wouldnt start. Not sure how much a Toyota battery is.
    Everything else I said no to. So.. I need:
    -The leaf spacer kit (replaces the stock bushings in between the leafs with thicker rubber ones) gets rid of the squeak I have. Between 20-40 bucks
    -new blower motor. Not sure on price
    -new brakes front and rear. Not sure
    -second opinion on road force, or, live with them, and try a different resolution (hub centric rings/carrier bearing)
    Opinions? This is making me lean towards the car Idea again...
  15. Sep 26, 2012 at 2:27 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    When I called back I got clarification.. the rotors are warped... he says. I dont feel anything in the pedal.. its more of the steering wheel. Which.. should be a balancing issue.. correct?
  16. Sep 26, 2012 at 2:28 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Usually if you feel it when not on the brakes it would be the tires, if you feel it during braking then its the rotors
  17. Sep 26, 2012 at 2:31 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    See.. Its both. I think changing the brakes.. a road force through discount.. and the other things done on my own.. should resolve my issues.. a complete overhaul type deal.
    What do you guys think?
  18. Sep 26, 2012 at 2:37 PM
    dbkid05tacoma
    Brooks
    Phoenix, Arizona
    05 long travel 4.0L
    :rofl:
  19. Sep 26, 2012 at 2:44 PM
    Aw9d
    Aw9d That one guy
    I think its a good idea. This is just normal wear and tear for a vehicle. Plus you can save a lot of money if you do the labor yourself.
  20. Sep 26, 2012 at 2:49 PM
    Cr250jumper
    The moon
    50 shades of tan©
Thread Status:
