AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Sep 26, 2012 at 9:17 PM
    superswamper003
    superswamper003 Taco
    Hendrik
    N. Snottsdale Arizona
    1998 4wd TRD 3.4l Tacoma Xcab 313k miles!!!
    Fox Xtended travel coilovers w/resis, AllPro UCA's, AllPro 3 inch leaflets, 1" Diff Drop, 285/75/16 Bfg KO, 16x8 Black Pro Comp Steelies, AP 1.25" wheel spacers in front, 8 inch Rockford Fosgate sub that bumps like your mother, old school deck, downey headers, cold air intake, grey wire mod, e-locker, hurst shift knob, LED Strips, USMC Decals FTMFW, Fox decal, Billet grille, Alarm with no remote, Straight piped to the side of the truck
    Ok so when i put my battery terminal onto the battery in my truck, there is a spark but the truck completely shut off. Any ideas why there is spark? Thanks!
  2. Sep 26, 2012 at 9:35 PM
    superswamper003
    Hendrik
    Ok but where is the circuit coming from because everything on my truck is shut off? Thats what im really confused about
  3. Sep 26, 2012 at 9:45 PM
    superswamper003
    Hendrik
    Ok thanks for your help anyways! Im gonna wait till my dad comes home then ill try to jump start it with his v10 haha :D ford power! (i like toyota better dont worry)
  4. Sep 26, 2012 at 10:08 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    I'm going to get up bright and early to head to u-fix-it and install my extended 5100 Billies. I was going to do the rear ss brakelines but I guess then need some extra fab work so ill just do them when I head back to Yuma.
  5. Sep 26, 2012 at 10:31 PM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    What extra fab work is needed to install brake lines?
  6. Sep 26, 2012 at 10:40 PM
    dbkid05tacoma
    dbkid05tacoma Well-Known Member
    Brooks
    Phoenix, Arizona
    05 long travel 4.0L
    Total chaos long travel, fox 2.5 coil overs, glassworks unlimited fenders front and rear, DMZ fab motor mounts, Bilstien 5100s in the rear, k&n cold air intake, 33/12.5r17 red letter grabbers
    so i have learned a very important lesson tonight. If you have a truck with 13 inches of travel always have a floor jacket because the normal car jacks dont work.
  7. Sep 26, 2012 at 10:47 PM
    dbkid05tacoma
    Brooks
    Phoenix, Arizona
    05 long travel 4.0L
    yea i am going to get a harbor freight jack and DMZ makes plates for them that they mount to so they can mount to the bed.
  8. Sep 26, 2012 at 10:49 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    and some of those don't even work. :(
    get an arcan, 100 bucks at cosco
    :D
  9. Sep 26, 2012 at 10:52 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Just drill out the holes a little bigger on the brackets for the new lines and add some washers. Its easy but i'd rather take my time and not be charged by the hour while doing it. Bleeding the brakes is what will be the most time consuming.
  10. Sep 26, 2012 at 10:53 PM
    dbkid05tacoma
    Brooks
    Phoenix, Arizona
    05 long travel 4.0L
    can i barrow your Costco card so i can get one lol
  11. Sep 27, 2012 at 12:28 AM
    Kyouto42
    Kyouto42 [OP] Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Josh if you want some help with the front brakes I can help you. I haven't done drums before but I'm sure we can figure it out (I should probably inspect mine too). I got the Duralast rotors at autzone (cause it was sunday, and Napa was closed as were the dealers). So far... it stops just as well as the stockers did... honestly I can't see justifying paying for the dealer ones thus far after how well these have actually worked out.
    For the carrier bearing install I'll have to pull the invoice, but to do the rear u-joint, carrier bearing, removal/install/balance and all parts was 330 at Arizona Driveshaft.
    I'd just have your tires road forced at discount tire...
    As for the a/c blower motor... what's the issue with it? If it's the clicking... have you tried to re-grease it first? It's pretty easy... I can help you out with it if you want. I still have a ton of grease too (if I can find it lol)
  12. Sep 27, 2012 at 7:11 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    road-force balance and a tire rotation once your there. The sedona trip might have knocked out some lead weights out with all that mud.
  13. Sep 27, 2012 at 7:48 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Awesome. thanks Jake. Check Out the Az section for the wrenching thread. I have all the details of what I plan on getting done in there. Let me know what you think.
    Definitely. Goin by today to see what they say.
    The truck definitely feels and sounds different after being at the dealer. I don't like it :( I switched to a new synthetic oil (already running synthetic, but tried a new kind) and now I have a slight knocking sound. Not sure whats goin on. Definitely needs some tlc
  14. Sep 27, 2012 at 8:24 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Advice with drums, do one side at a time so you can use the other side as a reference
  15. Sep 27, 2012 at 8:27 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Should I do the drums? Was just gonna have the rotors resurfaced.
  16. Sep 27, 2012 at 8:33 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Your just finding flaws in everything. I think the louder tocking sound is just in your head. These engines always tick.
    Anyways, I'm here at u-fix-it 15 after 8 and all the bays are full already. Just waiting anddrinking a cup of joe, enjoying the weather.
  17. Sep 27, 2012 at 8:40 AM
    Kyouto42
    Jake
    Ahwatukee, AZ
    My engine makes ticking sounds too with Mobil 1... but that's just the nature of the valves on the 4.0L. Cliff is running amsoil I think and his engine actually does sound fairly significantly quieter... but I looked up some results on Blackstone Labs from other Tacoma users back with my 08 and the results with Mobil 1 were pretty awesome on paper. I never saw any amsoil tests so it may be just as good or better, but I just haven't researched it. Knocking though... that's a different game and a bad one if it's actually knocking. First things I'd consider... what gas are you running, and what octane? I run QT (cheveron and shell as backup) 91 only in my truck... since I beat the living shit out of it as you well know. I'd find it very hard to believe your truck would be developing engine issues and mine isn't.... lol.
    Also as for re-surfacing rotors... honestly just drop a bit of cash on new ones man. Re-surfacing is always a temporary fix... and with how anal you are on balance issues, vibrations, ect... it won't be nearly as good as just replacing.... nor will it last. If they are warped they're done. You can improve them short term but the damage is done at that point. I am running toyota pads though with my vatozone specials... the pads make more of a difference than anything (pending the rotors don't explode lmao... but that's only a real concern with improperly drilled/slotted setups or really shitty materials).
  18. Sep 27, 2012 at 8:40 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    It's not the usual ticking sound. I know that one ;). It's a lower tone, slower knocking sound.
    But your probably right somewhat..I'm picking up on everything too. Lol
  19. Sep 27, 2012 at 8:45 AM
    Kyouto42
    Jake
    Ahwatukee, AZ
    Another consideration with knocking is your O2 sensors may be toast too...
  20. Sep 27, 2012 at 8:47 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Your going to get him paranoid Jake!
Thread Status:
