AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Oct 21, 2012 at 8:54 PM
    Kyouto42
    Kyouto42 [OP] Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I'm a manufacturing technician at Intel.
    :jellydance:
  2. Oct 21, 2012 at 9:22 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    marlin crawler clutch kit installed!
    10month old timken wheel bearing detonated, lost two seals (100 bucks from toyota), entire spindle is heat treated (replaced), hub is STUCK, so got a new spindle, new seals, new bearing thanks to warranty from vatozone, abs line is a melted sticky mess, so im just covering that hole, abs is messed up though.
    marlin clutch kit, disc/pressure/release/pilot/flywheel, so much better! old flywheel and yaer old pressure plate were heat cracked :(
    master cylinder is stuck for the front wheels, super slow release, fast press though. ordered new one.
    cleaned air filter, tranny, and tcase while they were out.
    used a 93 cummins 4x4 as a press, toyota wanted 140 bucks to use the press on the spindle, with it removed, and the 6ton the neighbor had couldnt do it. so we used the truck, and a hammer, and alot of wd, works great :D
    also, now i have climate control lights on my dash!
    such a long weekend, ugh.
  3. Oct 21, 2012 at 9:36 PM
    02TACOMA4WD
    02TACOMA4WD Well-Known Member
    02 Tacoma TRD 4x4
    How was the install on the clutch? I'm planing on doing the marlin crawler HD (1200lb. Any feed back? How much did you end up paying for everything?
  4. Oct 21, 2012 at 9:40 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Lol this thing is pretty awesome. Only gripe so far is how it organizes media in the gallery. I'm used to HTC's sense ui.. Where it has just "pictures" and "videos". Wish I could I figure that out..
  5. Oct 21, 2012 at 9:40 PM
    Kyouto42
    Jake
    Ahwatukee, AZ
    Man, pretty soon you'll have replaced every mechanical component on that thing...
  6. Oct 21, 2012 at 9:50 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    im not far behind, engine, and rebuild all cases (tranny, tcase, and diffs) and i will. brian has my new engine, and a sas is not to far out.
    the 1200lb is great so far, only one they offer. i did the 600 dollar toyota oem replacement a year ago, but mechanic neglected to resurface flywheel, he was a buddy and paid half price, so 1200 bucks for parts.
    or 330 from marlin, with shifter boot, and a 1200lb over 900 lb, great option, while tranny is out, great time to clean everything, change steering rack bushings, service driveshafts, check master/slave cylinder for clutch, etc etc.
    install was easy enough.
    ive now worked on in my opinion 90% of this truck, ive not opened any cases or engine yet, but done just about everything else :(
    sas is a real option. buddy can do it, its about me getting the axle, and other misc parts, dont know if i want a rockjock, or a d44 waggy, im leaning towards rockjock so i can keep a third member, and elocker.
    ive also been looking at 4bt's....
  7. Oct 21, 2012 at 10:09 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    Yeah I'm buying the whole clutch assembly$250 and then I'm buying a brand new flywheel $120. And I'll be installing myself. Does that price sound about right?
  8. Oct 21, 2012 at 10:20 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    nope.
    both 2.4/2.7/3.4 are 300 bucks, from marlin http://www.marlincrawler.com/clutch/heavy-duty/heavy-duty-clutch-kit-1200-lb
    as for a flywheel, neither marlin or centerforce carry a flywheel for my 3.4 that i could see, but needed one quick so opted for autozone, but was shipped from PA. Same as my new Master Cylinder id imagine.
    could look into toyota :( are you still on that chattery release bearing?
  9. Oct 21, 2012 at 10:24 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    Marlin makes a flywheel for the 2.7. Yeah I'm still driving on it, so I'm gonna do everything at once and I'm trying to get everything i need and priced out so I can pull the trigger
  10. Oct 21, 2012 at 10:26 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
  11. Oct 21, 2012 at 10:35 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    well hot fuck.
    yea get complete clutch kit, flywheel, and uv joints for your sockets/extensions.
  12. Oct 22, 2012 at 7:52 AM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Every morning I leave for school pulling out of my drive way when I go down the curb at full lock to the left, I hear a loud poping sound. Does anyone know what it is?
  13. Oct 22, 2012 at 8:19 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Check your tie rods
  14. Oct 22, 2012 at 8:26 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Josh I'm between the droid maxx hd and the galaxy s3, drop some words of wisdom on me!
  15. Oct 22, 2012 at 8:31 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    My buddy has the s3... It's a nice phone for sure..but I wanted battery life.. And the maxx definitely delivers. Give me a couple days to get used to it.. But as of now it's pretty sweet
  16. Oct 22, 2012 at 8:36 AM
    PLC721
    Patrick
    Chandler, Az
    Let me know if the battery life is really what they claim it is! I played with iPhone 5, and didnt notice a big difference between my 4S
  17. Oct 22, 2012 at 8:38 AM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    Go for the S3!
  18. Oct 22, 2012 at 9:02 AM
    Aw9d
    Aw9d That one guy
    Motorola blur (Razor) vs. TouchWiz (S3).
    Touchwiz FTW.
    Touchwiz vs. HTC Sense.
    Sense FTW
    AOSP vs All of those
    AOSP FTW!!!
    (I'm talking about software only)
  19. Oct 22, 2012 at 9:05 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I do have to agree with Colby. Sense UI though best. This blur... Ehhh.. Still getting used to it though
  20. Oct 22, 2012 at 9:19 AM
    Aw9d
    Aw9d That one guy
    Blur is just odd to me. It doesn't seem to 'flow' well. Touchwiz isn't bad, but seem's unfinished. Sense is awesome but eats battery life and ram. AOSP is great but has no 'flair' to it. But if you want the best battery life possible, ASOP is the way to to go.
    Hardware wise the Razor MaxxHD is good. It's just that damn blur that keeps me away from Motorola phones.
Thread Status:
