AZ BS Thread 2.0
Discussion in 'Arizona' started by Kyouto42, Oct 3, 2010.
Thread Status:
Not open for further replies.
  1. Oct 30, 2012 at 11:21 AM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    Easiest way is find a relay just like it in the block and swap them.
  2. Oct 30, 2012 at 11:24 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    The relay for headlights is not the same as the others :( I can just pull the relay and jump the power and if it works its the relay right? If it doesnt work its probably a break in wiring somewhere
  3. Oct 30, 2012 at 11:25 AM
    Aw9d
    Aw9d That one guy
    Yup. Just remove the relay and check from there.
    I'm sure you checked, but did you pull the bulb out and try a new one? Doubt that's the case but hell, you never know.
  4. Oct 30, 2012 at 11:30 AM
    Cr250jumper
    The moon
    50 shades of tan©
    Yeah first thing I did was replace the bulb, also switched bulb to the passenger side and it works fine
  5. Oct 30, 2012 at 12:09 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Connor, Jake, I think either of those will Work thanks guys!
  6. Oct 30, 2012 at 12:39 PM
    Aw9d
    Aw9d That one guy
    And you only have one relay for both headlights?
  7. Oct 30, 2012 at 12:40 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Yes
  8. Oct 30, 2012 at 12:46 PM
    05TacoRunner
    Peoria, Az
    If you only have one relay then the relay is unlikely your issue. I would say a corroded wire or terminal causing a voltage drop to your headlight,
  9. Oct 30, 2012 at 12:49 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Thats what I am thinking now too. I pulled the relay to look at it and it only has 4 pins, so I doubt it controls left and right separate. Im going to test the wire when I get off work and let you guys know, thanks for the help
  10. Oct 30, 2012 at 1:19 PM
    Aw9d
    Aw9d That one guy
    Agreed. If you only have 1 relay for both, then both would be affected the same.
    I would check all the pins and wires. On your plugs pull out your VM and check to make sure they are all working as they should be. Also pop those pins out if you can and double check the lead wires going into the pins. I've seen those come loose and just sit there. It looks connected, but it's really not.
  11. Oct 30, 2012 at 2:20 PM
    Aw9d
    Aw9d That one guy
  12. Oct 30, 2012 at 2:25 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    You, me, and Josh can tat people together online :D
  13. Oct 30, 2012 at 5:25 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Dear sweet bearded baby Jesus... The new Parkway Drive is AMAZING!!
  14. Oct 30, 2012 at 5:51 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    link. now.
  15. Oct 30, 2012 at 5:55 PM
    Aw9d
    Aw9d That one guy
  16. Oct 30, 2012 at 5:57 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    I hate you Colby :/
  17. Oct 30, 2012 at 5:58 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  18. Oct 30, 2012 at 5:58 PM
    Aw9d
    Aw9d That one guy
  19. Oct 30, 2012 at 6:02 PM
    superswamper003
    superswamper003 Taco
    Hendrik
    N. Snottsdale Arizona
    1998 4wd TRD 3.4l Tacoma Xcab 313k miles!!!
    Fox Xtended travel coilovers w/resis, AllPro UCA's, AllPro 3 inch leaflets, 1" Diff Drop, 285/75/16 Bfg KO, 16x8 Black Pro Comp Steelies, AP 1.25" wheel spacers in front, 8 inch Rockford Fosgate sub that bumps like your mother, old school deck, downey headers, cold air intake, grey wire mod, e-locker, hurst shift knob, LED Strips, USMC Decals FTMFW, Fox decal, Billet grille, Alarm with no remote, Straight piped to the side of the truck
    Morning folks.
  20. Oct 30, 2012 at 6:22 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    12 Hours off the charger and my phone is just at 50% Bwahahahahaha. :D
Thread Status:
