AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Jan 26, 2017 at 10:05 PM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    Basically same truck. '97 t4r.
    I have aftermarket radio with only the rear speakers playing.
  2. Jan 26, 2017 at 10:26 PM
    a.smo
    Aaron
    PHX, Az
    And the easiest way to test the alternator I presume is taking it to autozone or something of the sort?
  3. Jan 26, 2017 at 10:37 PM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Our timing!!!!!!
  4. Jan 26, 2017 at 10:38 PM
    BlazingTaco
    BlazingTaco ~,!,,___(•v•)___,,!,~
    Exile
    2016 Tacoma SR5 BBP DCSB 4x2
    Mall landscaping pin stripes.
    Yes, they can test it on a bench load tester. Otherwise, you can quickly test it on the vehicle with a DMM, an alternator with a functioning voltage regulator will typically put out 14-15 vdc at idle at the battery.
    MaverickTRD likes this.
  5. Jan 26, 2017 at 11:42 PM
    a.smo
    Aaron
    PHX, Az
    Hm. Well the second way isn't feasible if the truck doesnt start.
  6. Jan 27, 2017 at 3:31 AM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    :pccoffee:
    At least it's Friday
    Techoma and a.smo like this.
  7. Jan 27, 2017 at 3:39 AM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    Yay Friday! I think.
    Techoma likes this.
  8. Jan 27, 2017 at 4:26 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Not even with a jump?
    a.smo[QUOTED] and MaverickTRD like this.
  9. Jan 27, 2017 at 4:48 AM
    Daria
    Dodging tumbleweeds
    That moment when you realize you left your wallet at work and you're trying to pick up breakfast.
    Guess I'll go work for a few hours then take a breakfaat break.
    Brian007Taco[OP] likes this.
  10. Jan 27, 2017 at 5:05 AM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    Come down
    mh.meier likes this.
  11. Jan 27, 2017 at 5:05 AM
    JTB727
    JTB727 Well-Known Member
    Justin
    AZ
    35's and a Good Time.
    This... jump it and see what it does. Also double check your connections are tight. And make sure there is no corrosion on the wires.... Also I thought I read in a post you put new battery cables in her truck a few weeks back? Make sure ALL of your connections are tight. With a dmm if you still aren't up and running. Check your ground. A good ground is usually .1 to .5 ohms... Smack that starter a few times with a hammer. Might have to hit it pretty good. Don't wanna smash the thing but dont be scared.... @a.smo @swalters
    Another good way that'll shed light is if you jump start it and it dies when you pull the cables off. If the battery is ran completely dead.(or close too) and is not being charged it'll die again.
    a.smo likes this.
  12. Jan 27, 2017 at 6:13 AM
    JTB727
    Justin
    AZ
    anybody have any experience with power steering? My truck has some intermittent power steering. It's always been pretty stiff and hard to turn one handed, even the smooth spots are stiff its smooth, than a hard spot, smooth, than a hard spot. (say if you were cranking to make a tight right, or a u turn). If I keep the rpms up there isn't any of the stiff spots and I cleaned all the steering U joints, and lubricated them. I flushed the old power steering fluid a few months back, and it made a difference for a while, but it was still pretty stiff compared to my other 2 tacomas I have had.. The pump is a little noisy but not screeming, My rack seems to be in pretty good shape, no tears, and no leaks.. I'm thinking about putting a new PS pump, but don't want to just shotgun parts at it. Anything else I should be checking first that I overlooked? it's my first time doing much trouble shooting with PS. I've replaced pumps and lines and racks but mostly due to leaks.
  13. Jan 27, 2017 at 6:18 AM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    That's why you gotta carry an extra $50 in the glovebox, homie. That, and incase you forget the wallet and need fuel.
  14. Jan 27, 2017 at 6:25 AM
    Daria
    Dodging tumbleweeds
    Normally I keep a twenty or two hiding. Not sure where it is. My coworker called and brought me lunch.
  15. Jan 27, 2017 at 6:26 AM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    Anyone on the Westside have a bubba rope or similar snatch strap i can borrow for the weekend?
    2ndGenJonny likes this.
  16. Jan 27, 2017 at 6:33 AM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    I hope by powersteering fluid you mean ATF. Our power steering systems run on Dex type III. If you're running power steering fluid that is definitely your issue.
    Otherwise it sounds like you just need a good flush and bleed to get the air out.
    stumbles likes this.
  17. Jan 27, 2017 at 6:34 AM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Woke up to a text at 3 am asking if I had finished homework I had never heard of, so that was fun.
    Techoma, llibrm, Enjoihavok and 2 others like this.
  18. Jan 27, 2017 at 6:49 AM
    JTB727
    Justin
    AZ
    Yeah I put in the right stuff.. Even when I flushed it last time it was still so stiff it was hard to turn with one hand.
    Maybe another flush I guess?
  19. Jan 27, 2017 at 6:51 AM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Does the pump make any noises when turning, especially during rough spots?
  20. Jan 27, 2017 at 6:55 AM
    a.smo
    Aaron
    PHX, Az
    Forgot to say that. She tried to have a Co worker jump it and nothing. I'll recheck everything over and start playing with the starter.
