AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Jan 27, 2017 at 8:38 AM
    JTB727
    JTB727 Well-Known Member
    Justin
    AZ
    35's and a Good Time.
    I like the ones with the little bracket that pinches the wire with the 2 bolts on each side. That way the main cable can go in there. And I can add ring terminals to the 2 bolts that hold the bracket to pinch the main cable.... Or get an aux fuse block so you only have the couple connections at the positive terminal.
  2. Jan 27, 2017 at 8:42 AM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    http://www.autozone.com/batteries-s...ery-terminal/95964_919598_23849?checkfit=true
    That is what I have currently. The 1/0 terminals don't fit side by side so they are on top of each other 90* off. The rest of the connections are on the other side. I had to get a longer bolt to fit the 1/0 terminals. I flipped the bolts so the top of the bolt enters the bottom of the battery terminal. Then when I was tightening the nut on top of that bolt, the bolt stripped the hex shaped bottom so now it rotates. Thinking of maybe doing a washer to keep the bolt out of the battery terminal underside. But I don't know yet if there is enough space.
  3. Jan 27, 2017 at 8:44 AM
    JTB727
    Justin
    AZ
    Buy a new set of terminals. They're like 15 bucks. Those will work. Use a star washer for better connections. And grind the paint off the red part under the cap. Than use the terminal spray to keep corrosion out. Mine has been that way for 10k miles with no issues.
    a.smo[QUOTED] likes this.
  4. Jan 27, 2017 at 8:46 AM
    JTB727
    Justin
    AZ
    Another option would be to get a bus bar and power the bus bar and connect to that.. Than you will have studs for each individual connection.
    llibrm and a.smo like this.
  5. Jan 27, 2017 at 8:47 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
  6. Jan 27, 2017 at 8:48 AM
    a.smo
    Aaron
    PHX, Az
    Ya you're correct. Should just replace them and not worry about it. Thanks!
    That's planned for auxiliary stuff. I'll have to see if I can do anything with those bigger terminals.
  7. Jan 27, 2017 at 8:51 AM
    JTB727
    Justin
    AZ
    Right on man. Sounds like an easy fix for ya.
  8. Jan 27, 2017 at 9:10 AM
    Taco Love
    Taco Love Well-Known Member
    Mathew
    Prescott AZ
    2017 tundra
    4 inch pro comp lift
    I have me some PROs on me truck I love them.
    MaverickTRD, phx13 and Daria[QUOTED] like this.
  9. Jan 27, 2017 at 9:12 AM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    What did you run prior? How's the road noise?
  10. Jan 27, 2017 at 9:13 AM
    Zenphx
    Zenphx KE7FC
    Neal
    Phoenix
    2005 Impulse Red Pearl SR5 4wd Long bed
    Sliders.
    Because I work in an industry that sets it up you could use a digital wallet (Apple Pay, Android Pay) on your phone and you are never stuck again.
  11. Jan 27, 2017 at 9:14 AM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    Oh that's how that works!? Good to know haha
    Chipskip, mechanicjon and mh.meier like this.
  12. Jan 27, 2017 at 9:16 AM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Thats science.
  13. Jan 27, 2017 at 9:20 AM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    How the hell do those work? I see some places saying they take Apple Pay, but do they like scan my phone or???
    mh.meier likes this.
  14. Jan 27, 2017 at 9:27 AM
    mh.meier
    The Doctor
    Commiefornia
    Pretty much. I dont trust any of that shit though. People are like, no way man, its totally safe! Yeah well people can hack the pentagon, they can hack my phone too. Everything is done over some kind of Wifi and is easy to hack, but then gain so is your card. You re all fucked and doomed to hve your money stolen at east once. Keep it in the mattress,
  15. Jan 27, 2017 at 9:32 AM
    JerryTaco
    JerryTaco Well-Known Member
    It's true. I work in an industry that protects credit card data and certifies the companies that store, process or transmit said data. You'd be surprised at how poorly secured some companies are in the storage of your credit card or personal information. Apple/Android pay are actually both reasonably safe however, Google(a client of mine) and Apple both take their Security very seriously and pay millions of dollars a year to outside consultants such as my company to certify and run monthly penetration tests on their environments.
    llibrm, Enjoihavok, a.smo and 4 others like this.
  16. Jan 27, 2017 at 9:34 AM
    iBoosted
    iBoosted It's go to be the king
    Niko
    Mesa, Arizona
    2017 BBP Tacoma TRD Off-Road 4x4
    TRD PRO Front Grille Icons stage 3 lift Icons Billet Upper Control Arms Method Roost's Toyo Tires Caliraised Ditch Lights Caliraised Rear facing amber lights Caliraised Fog Lights Interior: Many Patches Greyman Tactical Rigid Insert Molle Panel
    Wanna hook it up with a job lol.
  17. Jan 27, 2017 at 9:37 AM
    JerryTaco
    ha ha, what do you do? We actually are hiring consultants (QSA's) and Pen Testers
    iBoosted[QUOTED] likes this.
  18. Jan 27, 2017 at 9:37 AM
    iBoosted
    Niko
    Mesa, Arizona
    That was a blessing in disguise now come on.
  19. Jan 27, 2017 at 9:38 AM
    iBoosted
    Niko
    Mesa, Arizona
    I am a repair tech and Cloud Blue Ingram Micro.
  20. Jan 27, 2017 at 9:38 AM
    iBoosted
    Niko
    Mesa, Arizona
    :spy:
    MaverickTRD[QUOTED] likes this.
