AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Jun 15, 2017 at 8:27 AM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    He needs to finish the buggy first. :boink:
  2. Jun 15, 2017 at 8:37 AM
    Daria
    Dodging tumbleweeds
    Literally burning up in the shop, eh?
    snowtank and Brian007Taco[OP] like this.
  3. Jun 15, 2017 at 8:45 AM
    Daria
    Dodging tumbleweeds
    :tumbleweed: Whatcha waiting on? Retirement?
  4. Jun 15, 2017 at 8:50 AM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Brian007Taco[OP] likes this.
  5. Jun 15, 2017 at 9:18 AM
    Techoma
    Alta Mesa, AZ
    Damn you!!! Always chasing tweakers and forgetting about us!!!!
  6. Jun 15, 2017 at 10:20 AM
    Techoma
    Alta Mesa, AZ
    Truck rpm Guage is as you know not perfect. So on my way to the docs, I set cruise for 80 and got this... 20170615_094824.jpg
    It fluctuated down to 2755...
  7. Jun 15, 2017 at 10:21 AM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Would love that 4 peaks night run, but will be on Coronado :cool:
  8. Jun 15, 2017 at 10:26 AM
    phx13
    Rob
    2015 DCSB TRD O/R
  9. Jun 15, 2017 at 10:48 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Ok.. let's beat this horse some more ..
    4.56 vs 4.88 on my truck with plans to go to 34's and only adding more weight... 35's are honestly irrelevant because I have no idea if I'm going to those.. don't plan on it, but who knows.
    I imagine to be right around 2500 to 2600 with 34's and 4.88's cruising at 80. And 2400-2500 with 4.56's at 80.
    Maybe a couple hundred rpm's higher with my current 33's
  10. Jun 15, 2017 at 10:54 AM
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    John is on 35's, and according to his scanguage thing at 80mph he is at 2800 Rpms. I'm thinking you would be higher than that.
    I'm honestly considering 4.56 with my 35s. According to the internet that's nearly stock for me. Not sure I want to listen to my exhaust at 2800 rpms on road trips
  11. Jun 15, 2017 at 10:54 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I went in between at 4.63, but I have a 1st gen so its irrelevant lol
  12. Jun 15, 2017 at 10:55 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    see, I've been seeing mixed things.. I assumed I would be higher too. I probably have it wrong.
  13. Jun 15, 2017 at 10:57 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I drive like that a lot to begin with, leaving it in 4th. Doesnt bother me..because there really isnt a drone. I went through that hell of getting the exhaust tamed down, so its good to go.
    THAT... is the main reason im thinking of 4.88's.. the performance side of it.. but.. is that little bit of use worth the trade off daily driving it?
  14. Jun 15, 2017 at 11:08 AM
    Az4x4
    Az4x4 Az4x4Taco
    George
    White Mountains, AZ
    '03 Tacoma TRD SR5 DC 4x4
    Deck Plate Mod, Grey Wire Mod, Vision Shell, Alpine Speakers and Amp, Sway-A-Way RaceRunner Nitrogen Shocks with Coilovers up Front, Deaver 8 Pack at the Rear with Bilsteins, All-Pro Rock Sliders, Cobra 29LTD CB, 800W Inverter, Constant 12v Power Outlet Mod, Open Door Warning Disabled, Garmin GPS..
    I'm a long way from Deer Valley so I can't put eyes on the vehicle for you, but after looking over the Jeep you pointed out I'd suggest that whoever goes to see it checks to see if it's an original Arizona vehicle and not an import. If it was originally sold in Arizona, and it's spent its lifetime in the Valley and not on wet salted icy roads somewhere, then the frame and undercarriage will be in good shape, and that's critical.
    Short of verifying that detail plus any others that may pop up, that Jeep looks good! Amazing how much alike the '06 Jeep X and my lifted '93 Wrangler look.
    New%20Hard%20Top%20on%20My%20Jeep%205-16_3120bcd667dcb2bcb9a18c4667d37ab653346fd6.jpg
    Gotta love Jeep for making a good thing and sticking with it all these decades!..
  15. Jun 15, 2017 at 11:09 AM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    4.88 because fuck it. There's almost 0 height difference between 35's and 34's because the variance in tire size is at least half an inch between makes
  16. Jun 15, 2017 at 11:17 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I just dont want to run high rpms all the time daily driving this thing..
    The more I think about it, I think the 4.88's are too much. 4.56's will already be an upgrade and help out.. and will be a good medium.
  17. Jun 15, 2017 at 11:18 AM
    cmack
    cmack Well-Known Member
    18 Burrito
    5.13's cause ferd :cool:
  18. Jun 15, 2017 at 11:19 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Gtfo
    llibrm and Brian007Taco[OP] like this.
  19. Jun 15, 2017 at 11:25 AM
    cmack
    18 Burrito
    go buy some armour
  20. Jun 15, 2017 at 11:26 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    not needed.
