AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Jul 13, 2017 at 5:57 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    It's pretty easy if you have the tool for it. Just jack the front of the truck up so the tires are in the air, spray some sort of lubricant (wd-40, 6 in 1) and go for it. Only issue for me ever was not being able to get to one of the holes per revolution because the spacing on the lock screw for the adjusters. So you'll need a punch and hammer to move it an inch to get past that point on each turn. Other than that it should go pretty easy
  2. Jul 13, 2017 at 7:58 AM
    Enjoihavok
    Enjoihavok Never Forget Z.S.
    Erik
    Chandler, AZ
    2021 Tundra Pro
  3. Jul 13, 2017 at 8:29 AM
    Cal671
    Cal671 Well-Known Member
    calvin
    AZ
    08 Taco smurf, 10 fj, 16 runner
    My huskys was chewing up walls at some point good thing theyre over that phase and just stick to their toys now 20170713_082818.jpg
  4. Jul 13, 2017 at 9:07 AM
    Aw9d
    Aw9d That one guy
    I use Raamaudio. I've bought so much deadener from them I just call them and tell them what car I'm doing and they make me custom setups. Price is good, material is great.
  5. Jul 13, 2017 at 9:29 AM
    OmegaMan73
    OmegaMan73 Well-Known Member
    Mesa AZ
    2017 Tacoma TRD Sport 4x4
    So I'm sitting at the dealership right now wondering how these people can blatantly lie to people with a straight face like these d!@k heads. Took the truck in because it's got that driveline vibration that everyone complains about. This guy comes out and tells me that the vibration from 40 to 50mph is from the torque converter locking up. So I tell him why does it do it in neutral and why does it not go away when it changes gears? His answer... Toyota's are just built like that. And the low speed vibration you have is because of your tires.
    Unbelievable.
  6. Jul 13, 2017 at 9:50 AM
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    Which dealership so we can mock them?
    Old School and OmegaMan73 like this.
  7. Jul 13, 2017 at 9:51 AM
    Aw9d
    Aw9d That one guy
    Take your pick, they all suck ass.
  8. Jul 13, 2017 at 10:04 AM
    OmegaMan73
    Mesa AZ
    Earnhardt Toyota on the 60 and superstition springs.
  9. Jul 13, 2017 at 10:16 AM
    Aw9d
    Aw9d That one guy
  10. Jul 13, 2017 at 10:18 AM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Patience and lots of time!
    phx13[QUOTED] likes this.
  11. Jul 13, 2017 at 10:31 AM
    Aw9d
    Aw9d That one guy
    This is really all you need to sound deaden a car/truck. I think mine took 20 hours to do with help from my brother. I ended up doing all vertical walls down, inside the doors, floor pan, 2 layers on the back wall, and much as the firewall as I could get to without taking the dash out. I haven't done the roof still. We did some expanding foam but not much.
    Then I covered all the sound deadner (expect inside the doors) with ensolite foam.
    This is a good place to get a lot of info on how to do this: http://www.raamaudio.com/pages/How%2dTo.html
  12. Jul 13, 2017 at 11:02 AM
    BlazingTaco
    BlazingTaco ~,!,,___(•v•)___,,!,~
    Exile
    2016 Tacoma SR5 BBP DCSB 4x2
    Mall landscaping pin stripes.
    :bananadance::bananadance::bananadance::dancingbacon::dancingbacon::dancingbacon:
    I am awaiting better weather to take her up.
    My good friend picked this mug up for me, straight coffee thuggery!
    05tacomabro, genequit, llibrm and 5 others like this.
  13. Jul 13, 2017 at 11:06 AM
    LTacoman
    LTacoman Well-Known Member
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    That coffee mug is legit!
    BlazingTaco[QUOTED] likes this.
  14. Jul 13, 2017 at 11:09 AM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    As far as sound deadning goes I go another route than the name brand high price stuff.
    First layer is Blue skin 100% on all metal. I even put some on the back side of the a pillars , and b pillars plastic coverings. https://www.amazon.com/Henry-BH200WB4559-Blueskin-Self-Adhesive-Waterproofing/dp/B00373PKGGIMG_20170621_103921987.jpg
    Second layer is a 1/4 closed cell foam that I buy at a local upholstery shop. You can go even thicker for the doors but 1/4 works in 80% of the interior outer door skin, roof and floor. IMG_20170701_131159964_HDR.jpg IMG_20170621_204649643.jpg
    The third layer is also a closed cell foam but only 2mm thick. This goes on the back wall and on the inner door skins.IMG_20170626_202534400.jpg
    The closed cell foam is glued in place with contact cement. I bought a gallon for $30 I have used it on two trucks and still have about a 1/4 gallon left. A half gallon should be more than enough for one truck.
    All in all I spent about $170 on all the material needed. It took me a week to do it all including a system installation in the hottest week ever. Had to take heat breaks from 1 to 5.
    To me the truck is very quiet. So quiet that I expect a speeding ticket very soon because you don't realize how fast I am driving.
    2ndGenJonny, LTacoman and Techoma like this.
  15. Jul 13, 2017 at 11:11 AM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Sounds to me like your average service writer's "dude, I've got a lot of customers, if I say this will you please just stop talking to me" shtick.
    My 3rd gen jiggles too but after driving myself bonkers and even installing a carrier bearing spacer I realized that it's actually related to road surface. For instance I can hang out at exactly 65 on the 101, sometimes it's smooth as glass, other times I get the steering and cab vibrations.
    I think it also has a little to do with my A/T tires but I have no low speed vibes. (2WD 4banger tho)
    I had them do my TSB for the tag light moisture and the 10K Toyota care. Dalton was my service dude and he seemed pretty chill. They even gave me 6 qts of 0W20 and a filter when I told them not to do the oil change because I had done it myself ~300 miles earlier.
    I think that's one of the sources I was reading. I was searching for what the best light weight deadener is, because if I do throw some in my truck I'm trying not to add too much weight (but maybe I'm just getting my shorts in a knot over nothing):p
    OmegaMan73[QUOTED] likes this.
  16. Jul 13, 2017 at 11:32 AM
    Aw9d
    Aw9d That one guy
    It's not a bunch of weight. Maybe 30lbs
  17. Jul 13, 2017 at 11:41 AM
    Techoma
    Alta Mesa, AZ
    Yeah... skip the high lift, 1" of tire size, 40" instead of a 50" lightbar, etc.... do the sound deadener!
  18. Jul 13, 2017 at 11:43 AM
    BDMcGuire
    BDMcGuire Well-Known Member
    Brent
    Peoria, AZ
    06 Tacoma OR SBDC
    Definitely choked on my Arizona iced tea (name drop), when I read this.
  19. Jul 13, 2017 at 11:54 AM
    Techoma
    Alta Mesa, AZ
    Slowly but Surely getting there. Small section of passenger side floor, some pillar work, an then headliner... then doors.
  20. Jul 13, 2017 at 12:04 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    :D You have to understand my frame of reference here though, my Miata weighs roughly half what the Tacoma does, and 30 pounds... I took the A/C out to save ~35 :eek:
    Brian007Taco[OP] likes this.
