AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Jul 26, 2017 at 11:36 AM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    @Aw9d I'm going to pull my subs from their box as know it is not sealed well. Can I use any RTV inside the box to seal it, or is there a specific one I should use.
  2. Jul 26, 2017 at 11:45 AM
    Aw9d
    Aw9d That one guy
    You can go at this two ways.
    1. Fiberglass the inside of the box. Fixes all the seal issues. :)
    2. You can use RTV or any silicon around all the edges. There shouldn't be any real need to seal the subs. Just make sure they are super tight. You can use some t-nuts so you can crank down the subs. I like to use wood insert lock nuts as well but those might be overkill for smaller subs. T-Nuts should work perfect. I'd highly suggest some type of T-Nut or Lock Nut on all subwoofer installs.
  3. Jul 26, 2017 at 11:56 AM
    GREGSBSPTACOMA
    GREGSBSPTACOMA Well-Known Member
    Greg
    Phoenix,AZ
    4runner
  4. Jul 26, 2017 at 11:58 AM
    Techoma
    Alta Mesa, AZ
    Fiberglass is more than I have time/patience for. I meant the sub box for sealing. The subs were installed to the box using 1.25 wood screws, and every one of them was loose or stripped! I've pulled them both out, now I'll pack the seams inside the box with RTV and I'll get some t nuts! Thanks.
  5. Jul 26, 2017 at 12:16 PM
    Aw9d
    Aw9d That one guy
    I was referring to fiberglassing the inside of your sub box to seal it. Not making one out of fiberglass.
    But yes, get the T-nuts and some bolts. Don't use the wood screws and that will solve a lot of issues.
    Techoma[QUOTED] likes this.
  6. Jul 26, 2017 at 2:05 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Ohhh Johnny boy. I have been awake since 6:30 pm last night and 4 beers in right now. I had the sharpie in hand about to sharpie two T's on my sack but the possibility of a ban kept me from completing my vision for a good laugh.
    05tacomabro and Techoma[QUOTED] like this.
  7. Jul 26, 2017 at 2:07 PM
    DukesTaco
    AZ
    I rinolined the inside of my box. It dried hard as fuuuuuck
  8. Jul 26, 2017 at 2:29 PM
    cmack
    cmack Well-Known Member
    18 Burrito
  9. Jul 26, 2017 at 2:37 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    So you rhino lined your box instead? T on your nuts would have been less painful
    MaverickTRD and stumbles like this.
  10. Jul 26, 2017 at 2:39 PM
    DukesTaco
    AZ
    I like pain and now my box is water proof
    Techoma and Cr250jumper[QUOTED] like this.
  11. Jul 26, 2017 at 2:41 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Touche, carry on :)
    Techoma likes this.
  12. Jul 26, 2017 at 2:41 PM
    DukesTaco
    AZ
    Yes you can toucheit
  13. Jul 26, 2017 at 3:14 PM
    LTacoman
    LTacoman Well-Known Member
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    ummmm did I miss something?? :rofl:
    :anonymous:
  14. Jul 26, 2017 at 3:22 PM
    Techoma
    Alta Mesa, AZ
    I knew that... still more time consuming!
    I'm TRY-SEXUAL! I'll try anything once.... more if I like it!!!!
  15. Jul 26, 2017 at 3:28 PM
    LTacoman
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    Your Legendary Mojo is just too much for us mere mortals to understand!
    Techoma[QUOTED] and Daria like this.
  16. Jul 26, 2017 at 3:39 PM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    You are not wrong. That man is a legend or something...
    Techoma likes this.
  17. Jul 26, 2017 at 3:41 PM
    Aw9d
    Aw9d That one guy
    Anyone have a charger for a 2013 MacBook Pro that I can borrow or buy off of?
  18. Jul 26, 2017 at 3:53 PM
    Mike330R
    Mike330R Well-Known Member
    Far West Phoenix
    '16 DC Offroad w/ stuff
    Pretty sure I do. Remind me Friday afternoon to look for it.
    Aw9d[QUOTED] likes this.
  19. Jul 26, 2017 at 4:12 PM
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    Anyone looking or know anyone looking for a job?
    We're looking for more people to work In our metal shop or glass shop. No prior experience required. Shop employees typically work with large brakes, creating, routing tables, running CNC machines (2 axis), forklifts, logistics etc.
    Pm me if you or anyone you know may be interested!
  20. Jul 26, 2017 at 4:43 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    I got all excited for a second but then I realized a quasi-cripple with 2 business degrees probably isn't the best fit.:D
    I'll ask my roommate though!
    In other news I got off my lazy ass and stuck some stickers!
    (I still need to get some TW-bro assistance on the total chaos bed brace install though!)
