AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Nov 15, 2017 at 8:20 AM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Dispatcher: “Are there any weapons?”
    Caller: “Yes”
    Trust me, they will come.
  2. Nov 15, 2017 at 8:25 AM
    AZTacoDrew
    AZTacoDrew Well-Known Member
    Andrew
    Phoenix
    2015 Super White TRD OR
    SPC LR UCA OME 887 5100's Icon progressive 3 leaf AAL
    Anyone have experience popping out the needle bearing and putting in the ECGS one? I know there's someone here who has the puller but I'm trying to get a hand when the time comes to do it all.
  3. Nov 15, 2017 at 8:57 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    I've done it.
    I would start here with this video.
    https://youtu.be/WnA_R3gFf2s
    If you can gather all the tools and fluid in advance , it's not too bad.
    For some reason the axl gave me the biggest challenge, which others have experienced.
    A BFH, fixed that.
    Let me know if you have any questions, depending on the weekend - can lend a hand.
    Az
    Here's the difference in the 2...
  4. Nov 15, 2017 at 9:10 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Small milestone this morning
  5. Nov 15, 2017 at 9:13 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Finally broken in!
    mbmack1 and Chipskip[QUOTED] like this.
  6. Nov 15, 2017 at 9:27 AM
    AZTacoDrew
    Andrew
    Phoenix
    I'm planning mid-December I think, most weekends are usually good for me. Will definitely reach out if I need some help. What were you having to hammer to get the axle out? Seems like slide hammers can pop em out fairly easy but always down for free with a hammer instead of renting one out from the parts store.
    Brian007Taco[OP] likes this.
  7. Nov 15, 2017 at 9:33 AM
    AZBACKCOUNTRY
    Doug
    The slide hammer , I had was too small. So , I resorted to this crom made a post in his build.good info there.
    https://youtu.be/ZZ5JSWu6mTE
  8. Nov 15, 2017 at 9:38 AM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Right behind you at 296... but only averaging 1 mile a month moving it from spot to spot, LOL
  9. Nov 15, 2017 at 9:58 AM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    And free shipping.
  10. Nov 15, 2017 at 9:59 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Haha.... I have been at 299 for 4 months. Truck doesn’t get driven as much anymore. Mainly drive the family wagon (4Runner).
  11. Nov 15, 2017 at 10:12 AM
    BlazingTaco
    BlazingTaco ~,!,,___(•v•)___,,!,~
    Exile
    2016 Tacoma SR5 BBP DCSB 4x2
    Mall landscaping pin stripes.
    Typically, if you request it, they will, especially for commercial drivers in vehicles owned by large companies.
  12. Nov 15, 2017 at 11:47 AM
    phx13
    Rob
    2015 DCSB TRD O/R
    Anyone else watching Damnation? Pretty good so far
    Brian007Taco[OP] and AZTacoDrew like this.
  13. Nov 15, 2017 at 11:47 AM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
  14. Nov 15, 2017 at 12:19 PM
    Enjoihavok
    Enjoihavok Never Forget Z.S.
    Erik
    Chandler, AZ
    2021 Tundra Pro
    If anyone has a good 2 hours to burn, download the joe rogan podcast of Tom Delonge from blink 182, dude and his alien talk is crazy to hear it's worth a listen.
  15. Nov 15, 2017 at 12:21 PM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    That dude is crazy AF
  16. Nov 15, 2017 at 12:23 PM
    DukesTaco
    AZ
    what grit sand paper do you use to clean the gauges:(?
  17. Nov 15, 2017 at 3:53 PM
    BlazingTaco
    Exile
    Who dat!?
  18. Nov 15, 2017 at 4:00 PM
    Enjoihavok
    Erik
    Chandler, AZ
    2021 Tundra Pro
    Someone who doesn't know which az thread to post this spotted question....
  19. Nov 15, 2017 at 4:01 PM
    Enjoihavok
    Erik
    Chandler, AZ
    2021 Tundra Pro
    @Daria a relative of yours?
    llibrm and Brian007Taco[OP] like this.
  20. Nov 15, 2017 at 4:01 PM
    Enjoihavok
    Erik
    Chandler, AZ
    2021 Tundra Pro
