AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Dec 28, 2017 at 9:04 AM
    Phessor
    Phessor Well-Known Member
    I have a 2.1" pulley and pushing 8# of boost at 7000 feet with a Snow Performance methanol injection kit running -20° washer fluid and 91 octane fuel. I still have a slight ping issue between 2500 and 3000 rpms and pre-boost that I am trying to solve.
    Chipskip and wheeliest[QUOTED] like this.
  2. Dec 28, 2017 at 9:38 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    Yeah thats the nature of the beast running 14.5 AFR at high loads and low rpm.. higher octane and pulling timing down low with a AEM FIC..
    yeah i could but no reason, you can safely run to 9 afr with meth..
  3. Dec 28, 2017 at 9:40 AM
    wheeliest
    Json
    TMPE AZ
    150mi @ 18 gals will suck
  4. Dec 28, 2017 at 9:56 AM
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    I actually don't know where there is E85 around here
  5. Dec 28, 2017 at 10:14 AM
    wheeliest
    Json
    TMPE AZ
    It's a lot of work t9 use e85
  6. Dec 28, 2017 at 10:15 AM
    wheeliest
    Json
    TMPE AZ
    Not on methanol, yes on normal.fuel
  7. Dec 28, 2017 at 10:17 AM
    wheeliest
    Json
    TMPE AZ
    Nah, I'd get several tanks to my washer fluid bottle.. e85 won't improve mpg for this type of application
  8. Dec 28, 2017 at 10:19 AM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    I don't know if I'm interpreting this wrong but you use washer fluid in the place of methanol?
  9. Dec 28, 2017 at 10:21 AM
    wheeliest
    Json
    TMPE AZ
    You can.. as it has alcohol/methanol in it to stop from freezing. But it's a 20/80 mix.. I use my washer fluid tank as a meth tank
    MaverickTRD likes this.
  10. Dec 28, 2017 at 10:22 AM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    So it's basically 20/80 water/alcohol methanol?
  11. Dec 28, 2017 at 10:24 AM
    wheeliest
    Json
    TMPE AZ
    Yes very understandable but we are not speaking of a highly nodded race car.. this is a daily.truck and wasting time to dial in AFR with meth is a lot of work considering when he starts delving I to it he will know what target afr. I used it to keep safe and it was a small price to pay to keep the motor happy. I had no fi control and bandaided lack of with meth and seen the gage travel to 13s at the same settings so my safe zone ranged from 9 to 11 are with meth.
    And 1500 was for electronics and go control, meth was just a fun adder
    MaverickTRD[QUOTED] likes this.
  12. Dec 28, 2017 at 10:26 AM
    wheeliest
    Json
    TMPE AZ
    No backwards, so all these methanol companies don't preach to use any more than a 50/50 mix or less on the methanol side, after 50/50 it becomes flammable.. basically running higher than 50/50 is like running around the s3imming pool.. you can do it but it's risky if you fuck up.
  13. Dec 28, 2017 at 10:28 AM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Which is why I want the 7th injector. I'm not racing it.. yet.. when I want it to race I will have a second vehicle as a daily driver. 7th injector seems much easier
  14. Dec 28, 2017 at 10:29 AM
    wheeliest
    Json
    TMPE AZ
    Mapecu3 with injectors is much easier
  15. Dec 28, 2017 at 10:30 AM
    wheeliest
    Json
    TMPE AZ
    And 40+hp
  16. Dec 28, 2017 at 10:34 AM
    wheeliest
    Json
    TMPE AZ
    The sc on 1st gens heats up the air, thats why methanol is so perfect for them.. it condenses the air before which is a lot dif then the 2ng gen sc..
  17. Dec 28, 2017 at 10:37 AM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Dammit you're talking me to the dark side.. I can cancel the order with urd. What do I need to know bout methanol injection...
    Chipskip likes this.
  18. Dec 28, 2017 at 10:38 AM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    USAA. Always, depends on what you can do.
  19. Dec 28, 2017 at 10:39 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I want a supercharger :(
    Enjoihavok likes this.
  20. Dec 28, 2017 at 10:44 AM
    wheeliest
    Json
    TMPE AZ
    I did the first race wars event. ran 180mph. I ran 9.7 @ 150 1/4th. My bike was gearing limited to 180mph I could have probably hit 185 in the half mile.
