AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Apr 4, 2018 at 12:02 PM
    Enjoihavok
    Enjoihavok Never Forget Z.S.
    Erik
    Chandler, AZ
    2021 Tundra Pro
    You know @Brian007Taco has been busy when he likes a post from 1700 messages ago, hah.
  2. Apr 4, 2018 at 12:03 PM
    cmack
    cmack Well-Known Member
    18 Burrito
    Could have been from yesterday tho. You know how fast this BS place moves
  3. Apr 4, 2018 at 12:04 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    That dumbass root B'S didn't help
  4. Apr 4, 2018 at 12:11 PM
    Enjoihavok
    Erik
    Chandler, AZ
    2021 Tundra Pro
    Nah, 2 weeks ago hah.
  5. Apr 4, 2018 at 12:29 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    Who all here is running dual batteries? I'm thinking of adding a second battery but I'm more confused each time I look into the options. Curious what my local crew is running vs the rest of the inter-webs as we know we have extreme elements here in the great state
    Techoma, AZBACKCOUNTRY and Chipskip like this.
  6. Apr 4, 2018 at 12:38 PM
    cmack
    18 Burrito
    I ran just 1 group 31 and it accomplished what I needed
  7. Apr 4, 2018 at 12:42 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Well I have a fridge that Im looking to add for trips and wanted to have the security of having the unit isolated from the starting battery
    AZBACKCOUNTRY likes this.
  8. Apr 4, 2018 at 12:57 PM
    cmack
    18 Burrito
    Ah. I just keep a portable jumper charged and with me. Only used it twice and that was in my work garage (once on my crawler and once on a coworkers car)
    RPS1030 likes this.
  9. Apr 4, 2018 at 1:00 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    valid point. I got one from Secret Santa last round. Ive never had to use it. :thumbsup:
    phx13 likes this.
  10. Apr 4, 2018 at 1:12 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    I have 90% of my parts sourced/ acquired. After lots of research I'm going with the redarc bc D.C.
    1225d. 25 amp smart charger , solar mppt controller
    https://redarcelectronics.com/products/dual_input_25a_in-vehicle_dc_battery_charger
    Dual optima yellow tops and off grid engineering battery tray on the passenger side.
    I have 100 watt panel on the prinsu, the panel will allow the charge to go straight to the dual battery and ease the load on the alternator.
    I run an Arb 50 as my fridge, winch, lights etc. I have ARB 12v dedicated running to the bed.
    http://store.arbusa.com/ARB-FRIDGE-FREEZER-WIRING-KIT-THREADED-SOCKET-10900027-P22817.aspx
    Let me know if you have any questions, so many options out there. But in Az solar is A no brainer.
  11. Apr 4, 2018 at 1:21 PM
    AZBACKCOUNTRY
    Doug
    Chipskip and llibrm like this.
  12. Apr 4, 2018 at 1:45 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    @Cr250jumper How difficult or involved was your fuel cell install? You have it working with the stock sender to get fuel level?
  13. Apr 4, 2018 at 1:55 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Its a bit of work, but you are doing SAS so its not anywhere near that hard. The hardest part is making a fill plate to adapt your stock items. Some people use aftermarket pumps that make it a little easier but I wanted the fuel level to work in the cab and didn't want to mess fuel delivery issues. Depending on which cell you use you might have to extend the pump so it reaches all the way to the bottom but that part is easy. But once you make a fill plate to bolt your stuff its all just plug and play, extend fuel vapor and electric but thats it. Its been about a year and no leaks and check engine lights
    I just cut the pieces off my old gas tank, traced them on a blank plate, cut holes, then welded the OEM gas tank pieces to the fill plate. Uses all stock pieces, gaskets, etc
  14. Apr 4, 2018 at 2:02 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    This is awesome. :transformer: Thanks. :hattip: Doesn't look like that much work. Did you also add tube for the fuel filler or just cap it there?
    RPS1030 likes this.
  15. Apr 4, 2018 at 2:17 PM
    Cr250jumper
    The moon
    50 shades of tan©
    I used the OEM filler because it has to connect to the other vents for all of the smog stuff to work
  16. Apr 4, 2018 at 2:21 PM
    Mike330R
    Mike330R Well-Known Member
    Far West Phoenix
    '16 DC Offroad w/ stuff
    Tested a Bullseye camera system today. Makes seeing hits at distance much easier.
  17. Apr 4, 2018 at 2:35 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    Kick ass. I also like your clamp system to hold the cell in place.
    Cr250jumper[QUOTED] likes this.
  18. Apr 4, 2018 at 2:42 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Thanks, its a little warped from welding so its a bitch to get all the bolts in but once they are in it cant move lol
    stumbles[QUOTED] likes this.
  19. Apr 4, 2018 at 3:26 PM
    BlazingTaco
    BlazingTaco ~,!,,___(•v•)___,,!,~
    Exile
    2016 Tacoma SR5 BBP DCSB 4x2
    Mall landscaping pin stripes.
    Courtesy Chevy taking off the gloves...
  20. Apr 4, 2018 at 3:31 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Is that a Toyota in a dumpster?
    Not sure if this marketing ploy is going to work.
