AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Nov 22, 2018 at 7:43 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    I know exactly where you were sitting! Good seats.
  2. Nov 22, 2018 at 8:56 AM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    Just got done with my bike ride. 8.4 miles of fun. I'm glad I got the bike
    Time to partake in the herb and relax until it's time to eat!
  3. Nov 22, 2018 at 9:19 AM
    azshooter40
    azshooter40 Well-Known Member
    Robert
    Chandler, AZ
    2020 OR 4x4
    Went to the Boston game, have tickets for the Rangers and Pens too.
    JTB727 likes this.
  4. Nov 22, 2018 at 9:29 AM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
    Happy Thanksgiving. Time to load up the bba stouts and get to eating.
  5. Nov 22, 2018 at 10:18 AM
    Plastics Guy
    Plastics Guy DuroBumps
    DuroBumps
    Arizona
    02 4Runner
    Plasti-dip & exhaust tip
    Happy Thanksgiving my AZ Friends!!!
    ToxicTwin and stumbles like this.
  6. Nov 22, 2018 at 10:28 AM
    Mike330R
    Mike330R Well-Known Member
    Far West Phoenix
    '16 DC Offroad w/ stuff
    Cool sway bar disconnect idea. Wonder how hard it is to get the pin back in.
    Carter'sTaco and TACOVRD like this.
  7. Nov 22, 2018 at 10:31 AM
    OmegaMan73
    OmegaMan73 Well-Known Member
    Mesa AZ
    2017 Tacoma TRD Sport 4x4
    Happy Thanksgiving everyone!
    Plastics Guy likes this.
  8. Nov 22, 2018 at 10:50 AM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    As long as you are parked on level ground it should be pretty simple.
    I considered going this route but a few things kept me from doing so- first being the fact that the sway bar is not really "disconnected" so much as you now have a whole lot of free play in the endlink- what this means is a sway-free experience followed by a hard stop and a sway now binding in an awkward position. For instance if you stuff one wheel and droop the other you will run out of "difference" that setup allows.
    Also it's noisy and the amount of deflection in the sway bar rods does not inspire confidence.
    My latest ass-hat idea is thinking of a way you could make a sway bar that is in two halves with a mating collar, such that you still remove the whole thing but it is simplified by being able to pull one half out then the other. This only really saves you having to wrestle the bar out from between the skid and frame (depending on your skid this might be impossible). Still 3 bolts each side...
    Carter'sTaco likes this.
  9. Nov 22, 2018 at 10:51 AM
    DeltaBravo
    DeltaBravo Do you know what nemesis means?
    Waste Management's residential dumpster rental allows you to quickly find the right size dumpster for your project, schedule delivery and pay, all in just a few steps.
    The vehicle commonly referred to as "The War Rig" is a 78 foot 18 wheeler based on a Tatra T815
  10. Nov 22, 2018 at 11:39 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    I worked almost every game.
    Last night was a great game, sad they lost in OT, but it was still fun to watch. If they would look before they pass, they could have easily won it.
    azshooter40[QUOTED] likes this.
  11. Nov 22, 2018 at 12:37 PM
    OnePuttBlunder
    AZ
    Former Zamboni driver. I was at a lot of the games their first few years in the valley
  12. Nov 22, 2018 at 1:29 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    So today I did the sway bar delete. Did a little slalom at about 35 mph down the paved section of my road and again after I had cranked up my clickers to just shy of max compression damping.
    I’d say negligible difference in how the truck handled compared to with the sway bar on. There is a tad more nose dive on sharp turns under acceleration but the truck certainly doesn’t handle like a boat.
    Will be leaving it off for a while for full evaluation.
  13. Nov 22, 2018 at 1:35 PM
    Mike330R
    Far West Phoenix
    Good info. Try it with your clickers all the way soft.
  14. Nov 22, 2018 at 1:38 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Will do.
    azshooter40 likes this.
  15. Nov 22, 2018 at 5:44 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Definitely more body roll at 35 mph slalom with 0 compression damping.
    Mike330R[QUOTED] and azshooter40 like this.
  16. Nov 22, 2018 at 5:57 PM
    JTB727
    JTB727 Well-Known Member
    Justin
    AZ
    35's and a Good Time.
    throw it in the garbage, and forget it was ever part of the truck.
  17. Nov 22, 2018 at 6:03 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Yeah, I’ll try it out for several weeks but after today’s little test I think just cranking up the damping will be just fine for highway use......very glad I spent the extra $300 and got clickers.
    :burnrubber:
  18. Nov 22, 2018 at 7:07 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    What rate are your springs? I see you have a bumper so I'm guessing 650 or 700?
    Did you adjust the clickers all the way around or just front?
    I'll try to TL;DR but for compensating for no sway you want to use less clicks in the rear and more clicks in the front.
    Body roll aside, without a front sway you are biased towards oversteer on the slalom/handling spectrum. More compression damping up front pushes you back towards understeer, but more compression damping in the back can push you back to oversteer again.
    How many clicks does your suspension have? Try going half as many rear as your do front and see what happens.:thumbsup:
  19. Nov 22, 2018 at 7:30 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    700 lb coils
    Just adjusted the fronts. I’ve kept the rears at +8 clicks with the weight in the back. The first test was +10 clicks on the front, the second was +19 clicks and the last was at +1 click. Settled on +14 on the front and +8 on the rear.
    ADS clickers are 20 clicks and affect both low and high speed inputs (though not independently like Fox DSC) and are overall valved to be progressive on compression and digressive on rebound IIRC.
    Hey, what was the purveyor of odd and/or unique (security) bolts and nuts that you had mentioned a while back - it wasn’t Fastenal it was something else...?
  20. Nov 22, 2018 at 7:52 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    You mean Belmetric? They're the ones I usually get my odds and ends from.
    Oh and speaking of clickers where do your ADS shocks clickers mount in the rear? Was it like kings where you get a bracket you bolt in and it's already handled, or was there some drilling required?
