AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Jan 22, 2019 at 5:02 AM
    JTB727
    JTB727 Well-Known Member
    Justin
    AZ
    35's and a Good Time.
    When was the last time you went offroad and your driving skills were greater than the truck could handle/ frame flex caused you problems? Not a hack, just trying to see what your thoughts were heading towards. Its cool to have nice stuff but you gotta use the truck as it progresses to steer you where you want to go.
    stumbles and Rextinkleton93 like this.
  2. Jan 22, 2019 at 5:30 AM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    Check out incstores.com
    I'm a truck driver who picks up at the incstore warehouse in phoenix. I believe the main office is in Mesa. They have a massive amount of products, and they do custom cuts as well.
    phx13[QUOTED] likes this.
  3. Jan 22, 2019 at 5:35 AM
    ToxicTwin
    Robert
    Glendale AZ
    2009 TRD OR
    Me too!:fistbump:
  4. Jan 22, 2019 at 5:54 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Leave the spare under the bed until it’s too big to fit there. Especially if you’re concerned about bed space. You’re 2wd, so you really shouldn’t be getting yourself into any situations where you are dragging the hangers to bend them unlike myself that’s trying to beef up mine after last weeks trail. And if you want/ need more frame rigidity you can have the frame boxed and add supports in front or behind the spare.
  5. Jan 22, 2019 at 7:32 AM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Best fuckin sandals ever.
    DevilDocAZ likes this.
  6. Jan 22, 2019 at 8:10 AM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    It’s more about my philosophy of “supporting mods” if I am about to drop some serious coin on a suspension. Far too often I see modders (in all communities) matching a high dollar part with a weak link.
    I have outgrown the stock Bilstein takeoffs- the front shocks are not blown but they are clacking and don’t control the truck well enough.
    I’m still trying to decide what to do about the rear leaf setup but I want to have as solid of a framework for the suspension to do its job, but not quite bed cage long travel type stuff.
  7. Jan 22, 2019 at 8:19 AM
    cmack
    cmack Well-Known Member
    18 Burrito
    But those parts won’t get covered in dirt, right? Cuz then they won’t look pretty
  8. Jan 22, 2019 at 8:24 AM
    aztacoadventures
    aztacoadventures Well-Known Member
    Tucson
    2008 White Tacoma TRD
    Flip-pac camper, Pelfreybilt front bumper, RCI Sliders, Dual Battery setup
    You already install those hangers? Assuming so since you say it made a difference.
    Are you able to fabricate your own crossbrace? Im assuming you could make one with clearance for a spare tire under the bed.
  9. Jan 22, 2019 at 10:47 AM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    They look prettier covered in dirt which is why I only buy ExpoAF™ brand dirt and put it on when no one is looking.:rofl:
    Not a whole lot of clearance and that is the spare 245/75r16 which is a hair smaller than a 265/70r16.
    I guess I could probably get someone to do a tire-shaped hoop to clear maybe. Or just 45 degree gussets to the rear bumper frame.
    I’ll have to crawl around underneath when I am doing the diff fluid, see if there’s any obvious way to clear it.
  10. Jan 22, 2019 at 1:46 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Just throw the spare on the hood like the old land rovers. You already got the retro vinyl, now complete the look.
    05tacomabro likes this.
  11. Jan 22, 2019 at 2:03 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
  12. Jan 22, 2019 at 2:49 PM
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    What are the dimensions? How thick Of aluminum?
  13. Jan 22, 2019 at 3:26 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    60"x 16" x 3mm thick. 1 bend on each side long ways so that it ends up being 2" deep and 12" wide. No bends on the short ends. Doesnt have to be that specific thickness but does need to be strong enough to support a ~40lb tent mounted to 2 crossbars
  14. Jan 22, 2019 at 8:22 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    I hear ya on the bed space thing. Moving weight forwards is actually less desirable considering the weight balance is already forwards. If I were really going full OCD I would find a way to mount it at the rear passenger corner to offset the battery as best I could.
    But I think even I can say that's a bit overboard.;)
    We'll see, I'll probably scrap the idea for the sake of simplicity.
    While we're bullshitting about suspensions I wanna ask @Rextinkleton93 a hypothetical... Imagine 2 shocks of the same exact build quality and valving. One is a comp/rebound adjustable bypass and the other is a clicker. Would being able to adjust rebound be worth a couple extra hundo?
  15. Jan 22, 2019 at 8:48 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    I might be a little unhinged because I am looking at maybe doing this? Makes my current 35s look small. :beavisd:
  16. Jan 22, 2019 at 9:08 PM
    devidstaco
    devidstaco You look like a mothsfuckin uhhhhh
    David
    Tempe, AZ
    ‘18 QS DCSB TRD OR
    Nothing major
    Are you going through with it tho
  17. Jan 22, 2019 at 9:10 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    Tomorrow night I am hoping to put it on and see how much I am going to have to cut. Haha I just did it for the 35s a couple months ago.
  18. Jan 22, 2019 at 10:23 PM
    devidstaco
    David
    Tempe, AZ
    ‘18 QS DCSB TRD OR
    Nothing major
    Nothing like a few beers & an angle grinder late at night to end it on a good note lol
    llibrm and stumbles[QUOTED] like this.
  19. Jan 23, 2019 at 3:22 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    I am not @Rextinkleton93 but, I think once the suspension is dialed in, you're not going to change it. You're not racing so there is not going to change ever weekend based upon conditions. I think that clickers would be adequate for loaded vs unloaded. But in the end, bypasses look cooler and if you feel better, go for it. I wish I would have gone clicker on my setup simply for ease. It's faster to dial clickers and to a known point each time without tools
    edit: I don't have external bypasses either. I knew I didn't want to mess with them. It would have been wasted monies
  20. Jan 23, 2019 at 3:27 AM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    George gonna lose it when he sees you DD 37s with zero lift.
    Regarding a spare....
    Josh fit a 285x70r17 under his bed. He used a ratchet strap to keep it from rubbing the diff. His truck lives in dirt.
    My 75r17 just floats in the bed. I used to run the Y strap and a tire cover with the last truck, more hassle than what it's worth.
    Only time I strapped the tire in the 2015 was in Moab.
    At the end of the day it's a tiny ass spare you're creating a mountain over. Just put it under the bed and move on.
    Also, clickers or bypasses on a street truck? You need a new hobby to spend money on.
    Edit: I really don't care what you spend your money on. It's your truck be happy.
