AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Jun 16, 2019 at 4:40 PM
    Man of Steel TRD
    Man of Steel TRD Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    Do any of you know of an easy way to get the old rubber out of control arms easily? The ones in the back are leaving tons of old rubber behind when I press the bushings out. I tried to burn them out but they just make a huge mess.
    I was thinking a little flapper wheel for my dremel but was a bit afraid to take more than rubber out.
  2. Jun 16, 2019 at 4:51 PM
    Mike330R
    Mike330R Well-Known Member
    Far West Phoenix
    '16 DC Offroad w/ stuff
    Mite as well cut the floor boards out and Flintstone it, will be just as fast ;)
  3. Jun 16, 2019 at 5:11 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    It is a TT not the NA one, so maybe cut both floorboards out and have a helper. ;)
  4. Jun 16, 2019 at 5:12 PM
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Mike330R[QUOTED] likes this.
  5. Jun 16, 2019 at 5:13 PM
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Burns hotter?
  6. Jun 16, 2019 at 5:15 PM
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    That would be sweet if I could.
  7. Jun 16, 2019 at 5:15 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    Danger to manifold! :rofl:
    Oh uhhhh yeah key point that a lot of people mistake... You heat up the housing so the rubber boils and the bond releases, not try to fry the whole bushing into a lump of coal tar.
    Just making sure man, I know a lot of people do it. :)
  8. Jun 16, 2019 at 5:16 PM
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Well when I was using a propane torch it was just burning the surface really and making a mess.
  9. Jun 16, 2019 at 5:17 PM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
    Man I sure hope they have a crew out digging fire line around reavis ranch. I'd hate to see that and the apple trees go. Regret never going out there already.
  10. Jun 16, 2019 at 5:48 PM
    MrMccrackin
    MrMccrackin Well-Known Member
    Gilbert, AZ
    2004 TRDOR PreRunner, 2017 MGM TRDOR 4x4
    This explains lunch instead of coffee!
    DevilDocAZ likes this.
  11. Jun 16, 2019 at 5:52 PM
    MrMccrackin
    Gilbert, AZ
    There is not a good way, unless you have a arbor that’s a few thousands smaller than the bushing housing.
    The sanding flapper wheel in a drill press would work, go slow.
  12. Jun 17, 2019 at 12:27 AM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Copied this from a group I’m in. Absolutely horrible.
    Just got back from another Woodbury Fire meeting from Roosevelt. The news is not good, in fact I would say it is completely devastating.
    To make a long meeting short I will get right to it. Currently 0% containment and over 700 personal working the fire. As of right now they have stopped the northern movement of the fire at highway 88 and the Tortilla TH area due to the back burning that has been done there. They are continuing to back burn moving west towards Tortilla Flat. They have placed a sprinkler system around Tortilla Flat to try and protect it once the fire gets there. Also the owner of Reavis Mountain School (forgot his name) spoke for a minute and he is working with a crew to clear brush around the school area. Now the devastating news. Due to the extreme steepness of the terrain in the majority of the fire area they are unable to get crews on the ground to fight it. They also are not able to use air support without a crew on the ground in the area, apparently they work together. With that said the plan right now is to unfortunately let it burn until it moves closer to 88 on the east side and north side and comes off the cliffs on the west side. They have planned points on the east side on where they can start fighting it and are waiting for it to burn it's way through Reavis Canyon, Campaign Creek , Fish Creek.
    I have included the latest fire map. As you can see the fire has made it's way up Reavis Saddle and is closing in on the ranch. They advised that it took a couple days for it to move on the east side as the manzanita was so thick it did not want to burn originally, however it has dried out the past couple days and they expect the fire to start to accelerate through the Reavis area. I have circled the fire on the east side in pink coming up the saddle with the Ranch and Roger's Canyon Cliff Dwellings circled in green. After the meeting I spoke to the Roosevelt Ranger one on one and they are fully expecting the fire to take the Reavis ranch area including the orchards and are hoping the Rogers Canyon Cliff Dwellings survive the fire due to their height in the canyon.
    On the West side, they are also expecting it to continue it's movement and you can see on the map today the fire has now moved into Barks Canyon and is making it's way down La Barge Canyon to Charlebois and is moving into Boulder Canyon (circled in pink). On the south side the fire is sitting on top of Buzzards Roost where they may drop some water on it to stop that piece of the fire. The remaining south side end has been cold for a couple days (black line).
    They did say the fire will not be out until the monsoons arrive and they are predicting a later then normal start this season, looking like the end of July.
    I think that's about all that I can remember. Like I said beyond devastating news as we could be potentially watching 75% or more of the Superstition Wilderness burn in this fire. Like a lot of people here the Superstition are more then just a wilderness to me and words absolutely can not express how I am currently feeling.
  13. Jun 17, 2019 at 4:40 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    It’s a terrible situation.
  14. Jun 17, 2019 at 5:23 AM
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Crazy how much is burning all over the place. I'm originally from Washington state and they have wild fires every year too on the east side too.
  15. Jun 17, 2019 at 5:27 AM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Where in WA?
  16. Jun 17, 2019 at 5:52 AM
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    RIP RINZLER! Happy Taco Tuesday :cheers: FYI I'm selling my RTT guys. Tepui Ruggedized Autana w/ Annex in Expedition Orange $1500
  17. Jun 17, 2019 at 6:55 AM
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Sunnyside originally.
  18. Jun 17, 2019 at 7:07 AM
    Eric F
    Eric F Well-Known Member
    AZ
    2014 DC SB TRD-OR 4x4
    Anytime fog lights, U.S. Off Road-Winch Mount Bumper, diff breather, Doug Thorley mid pipe
    Hey guys,
    Looks like I'm going to need a new battery before the day is over, my truck alarm barely beeped and it was slow to start this morning.
    Any recommendations? This is my second factory battery (first one replaced under warranty). I have a 2014 V6 4x4.
    Thanks,
    E
  19. Jun 17, 2019 at 7:36 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    I've had really good luck with Costco batteries. The one at PV (near me) stocks the correct size for our trucks. ~$100
  20. Jun 17, 2019 at 8:31 AM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Ah ok cool.
    My wife grew up near Seattle and we lived in Mount Vernon for about 8 years before moving down here.
