AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Sep 7, 2019 at 5:22 PM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
    Picked up a ratchet strap and fire extinguisher for the truck today. Related-fuck my weekends are boring as hell.
    azshooter40 and Man of Steel TRD like this.
  2. Sep 7, 2019 at 5:35 PM
    Mike330R
    Mike330R Well-Known Member
    Far West Phoenix
    '16 DC Offroad w/ stuff
    Come by here I'll make it interesting.
    Went shooting early, tried some new mags that would not feed rounds. Rounds would get jammed up in the mags body and not spring up.
    Used mags that I know work, rapid fire, and one round fired out of battery. Scared the crap out of me, big poof of smoke. Then had issues with a 22 pistol trigger not resetting.
    Pic of .45 with jammed up mags and a mis-fed round in the chamber in low right of the pic:
    Come home to fix the sprinklers that have been leaking for a while. Turn off the water supply, replace valve diaphragm, turn supply back one and that sprinkler circuit comes one when it should not.
    Eff with it for a few hours with no luck, call and 'expert' with no luck and $60 wasted, still no workie. "I can replace all 7 of those old valves for $975". Umm "that's a lot!!"
    Have to leave the water supply off, which I later learned supplies the pool so now the pool pump has no water supply.
    Hoping I can get it out and replaced tomorrow but plumbing is not my ForTae, yes ForTae because I can't spell forte.
    Middle valve:
  3. Sep 7, 2019 at 5:40 PM
    OnePuttBlunder
    AZ
    Given the choice I'll stick with boring. Yikes that's a shit day
    TACOVRD and Man of Steel TRD like this.
  4. Sep 7, 2019 at 6:09 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Looks like just the inner is torn, but might as well do the outer too while you’re in there. Have you ever pulled the axle out on this truck yet? That’ll be the hardest part honestly. Probably some good YouTube videos to walk you through pulling the axle and replacing the boots.
  5. Sep 7, 2019 at 6:20 PM
    LTacoman
    LTacoman Well-Known Member
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    Might as well put some rounds through the valves at this point
  6. Sep 7, 2019 at 6:24 PM
    Mike330R
    Far West Phoenix
    A splendid idea!
  7. Sep 7, 2019 at 6:46 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Can’t, he said the guns jammed.
  8. Sep 7, 2019 at 7:58 PM
    MrMccrackin
    MrMccrackin Well-Known Member
    Gilbert, AZ
    2004 TRDOR PreRunner, 2017 MGM TRDOR 4x4
    I absolutely loathe irrigation systems.
    I have dug up and replaced more than I care to admit.
  9. Sep 7, 2019 at 8:02 PM
    MrMccrackin
    Gilbert, AZ
    Boots are easy, buy the higher end replacement boots.
    Be aware the clamps are 1x use only, just cut the old ones off.
    C-clips hold the whole thing together, it’s messy but not hard to do.
  10. Sep 7, 2019 at 8:04 PM
    MrMccrackin
    Gilbert, AZ
    I can tell you I have screwed up more than 1 attempting to put them on and not taking my time.
    Snapping axles in the STi was my specialty
  11. Sep 7, 2019 at 8:05 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Rims came in a few days ago. Damn new fake beadlocks are
    more fake than the old ones. Rings don't even come off so I can't paint them orange :angrygirl:. At least not until I can convert them to real ones later on.
    At least I got he bolts all pulled so I can paint them black and keep all chrome away from the truck.
    Another sad note, 37’s are back ordered til the end of the month. :frusty:
  12. Sep 7, 2019 at 8:05 PM
    Man of Steel TRD
    Man of Steel TRD Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    Think I should rebuild my axles on my Z?
    TACOVRD and azshooter40 like this.
  13. Sep 7, 2019 at 8:08 PM
    MrMccrackin
    Gilbert, AZ
    Grab them and see if they have any play, if they are solid, your good.
    If there is play, swap out with replacements, they take the old ones as core charge.
  14. Sep 7, 2019 at 8:14 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    You get the 17x9? I just got my next set of ray 10s. Last set has been great for the last 3 years
    Need to do the bolts too. 3 years ago they offered black bolts as an option but no longer because time consumption
    TACOVRD likes this.
  15. Sep 7, 2019 at 8:17 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah I learned last time that my 9mm doesn’t like steel casings apparently. Few thousand rounds through it previously without issue. Fiancé bought steel casing rounds
    Yep got the 17x9 with 3.5” back spacing. Back spacing is what I was looking for in rims.
    Side note, did you get your relocation kit installed? Looked like that’s what you were doing in the sc thread
    TACOVRD likes this.
  16. Sep 7, 2019 at 8:34 PM
    azshooter40
    azshooter40 Well-Known Member
    Robert
    Chandler, AZ
    2020 OR 4x4
    Smoking some chicken thighs tonight and prepping beef and salmon for tomorrow! Hell yes!!!!
  17. Sep 7, 2019 at 8:38 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Ha haaaa I dated a girl who was 23 when I first got to AZ. Thought I was cool shit like man here I am still getting it in with college girls. :cool:
    Yeah no that was a mistake. If it's down to that and pillows I will stick with the pillows. :rofl:
    The one zinger that I will never for the rest of my life be able to forget was when we were sitting in traffic.
    Her: "What kind of truck is this??"
    Me: It's a Toyota Tacoma, third generation.
    Her: "Oh wow a Tacoma, those are like super rare! You don't see many of those!!"
    Me: Hun, this entire state is like one giant Tacoma meetup. There are 3 of them at this light right now.:confused:
    Aw man it got deleted, I missed it! What happened?? :D
  18. Sep 7, 2019 at 8:49 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Nope not done. Wanting to do it in flag
  19. Sep 7, 2019 at 8:50 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Got it. Your post about the axle install had me confused
    GT7[QUOTED] likes this.
  20. Sep 7, 2019 at 9:25 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Well I’ve had these Archive Hammer Hangers since Feb ‘18 sitting in my office and finally decided to tackle the frame rivets....
    Picked up a few Cobalt bits at Home Depot - they made quick work of the pilot holes.
