AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Apr 15, 2020 at 3:52 PM
    TucTaco520
    TucTaco520 Well-Known Member
    Phil
    It's a dry heat
    11 Hooptie
    OME 90000s+887s, LR UCAs. AllPro Expos + 5100. KM Fab hybrid sliders w/kickout. KM Fab bed rack. 48" hi-lift. 16" FJ Trail Team wheels. 285/75/16 Hankook Dynapro ATMs. Magnaflow cat-back. K&N filter. TRD short-throw shifter. Murdered out via plasti-derp front grille and rear bumper. LED interior. De-badged tailgate. Rock lights (7). G2V 3x2 ditch lights.
    @JeepAndrew
    ryan_tx[QUOTED] likes this.
  2. Apr 15, 2020 at 4:01 PM
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    Meant to mention he fabbed up my sliders and bed rack to perfection. There's a thread about his work, business is called Keepers MetalFab.
    ryan_tx likes this.
  3. Apr 15, 2020 at 11:13 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    its rare but possible. Could be booster or the rod between the booster is bent or out of adjustment. I had one on an old ford that was out of adjustment.
    Only thing i can say is try a full bleed on all brakes again. Is it pumping up pressure when your vehicle is off? Have you changed the booster before?
  4. Apr 15, 2020 at 11:34 PM
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    Pressure is not building on the pedal. But now that I think of it, the guy I was with wasn't turning the key on when he was pumping. Not sure if that would make a difference in a 30 year old truck?
    We just picked it up, so not sure if aftermarket or not. I'll check all the lines and see, otherwise just replace the booster.
    wilcam47[QUOTED] likes this.
  5. Apr 16, 2020 at 4:24 PM
    ryan_tx
    ryan_tx Well-Known Member
    Tucson, AZ
    2018 TRD OffRoad MT
    Sweet, thanks for the reference. I'll reach out to him
    wilcam47 likes this.
  6. Apr 16, 2020 at 11:22 PM
    wilcam47
    Will
    Bourbon state
    ignition should be off. If its not building up you got a leak somewhere or its MC.
  7. Apr 17, 2020 at 8:09 AM
    cromag27
    cromag27 THE insurance expert - licensed in all 50 states
    dexter morgan (matt)
    phx-ish
    2011 trd off road dcsb
    anybody else here have saltwater fish?
  8. Apr 17, 2020 at 9:49 AM
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    Thanks a lot!
  9. Apr 17, 2020 at 12:12 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Thanks for the recommendation, Super quick job for a fair price!
    wilcam47, llibrm, Enjoihavok and 5 others like this.
  10. Apr 18, 2020 at 2:40 PM
    ryan_tx
    Tucson, AZ
    2018 TRD OffRoad MT
    Anybody have a bandsaw & drill press they'd be willing to let me use to cut down and redrill some steel brackets for a bed rack sometime next week? Or anything else that might work?
    More than willing to pay in cash or beer! (all out of TP or that'd be on the table too :anonymous:)
  11. Apr 19, 2020 at 12:23 PM
    azchris
    azchris Well-Known Member
    Prescott, AZ
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    Posted this over in the 2nd gen forums but I figured I'd ask here since yall are pretty active.
    From my searching I apparently may be the only person in the world to have difficulty with this particular step of a lower control arm swap. Shock and cam bolts came right out in two seconds with no fuss, but I cannot get the steering stop to budge. I've sprayed it down with PB blaster and beat the hell out of it with a sledgehammer and it hasn't moved. Any tricks to this that don't involve a beefy press?
  12. Apr 19, 2020 at 12:26 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Do you have a tie rod or ball joint puller? Or a map gas torch? I assume you have new lca’s so if that one gets damaged it’s not too bad. Torch the adapter and give it another try
  13. Apr 19, 2020 at 12:35 PM
    azchris
    Prescott, AZ
    Tie rod puller is too small to fit around it, and I don't have a ball joint kit. You're right - not too worried about the LCAs themselves since I've got Total Chaos ones going in. I do have an oxy torch with a rosebud... guess it's time to give that a shot :bananadead:
  14. Apr 19, 2020 at 12:57 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Give it some fire and quit swinging like a girl. It should pop right out.
  15. Apr 19, 2020 at 1:42 PM
    azchris
    Prescott, AZ
    Yep, just had to go for it. Made myself a nice little balljoint fire and got it freed up. Thanks!
  16. Apr 19, 2020 at 4:07 PM
    Atl-atl
    Atl-atl Well-Known Member
    Phoenix+Flagstaff
    2024 Ram Power Wagon
    Fox, Thuren, 40s, other stuff
    If I had a torch like that Id use it even when I didnt need it hahahaha, surprised you even asked.
    cytocycle and wilcam47 like this.
  17. Apr 19, 2020 at 5:00 PM
    azchris
    Prescott, AZ
    Mostly wanted to make sure I wasn't missing an obvious step... This is the first truck that I've done anything more than minor repairs and regular maintenance, so I'm learning as I go. Figured it wouldn't hurt to ask before taking a torch to it :D
    azshooter40, wilcam47 and Tsinajinii like this.
  18. Apr 19, 2020 at 9:09 PM
    BillW
    BillW Well-Known Member
    N. Phoenix
    2018 DCSB TRD OR MT
    Went up Schnebly Hill for the first time, and up 89A again since I was young lad.
    Tsinajinii and Techoma like this.
  19. Apr 19, 2020 at 9:33 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    @ColoradoTJ do you know a girl that lives in CO that knows someone that's a moderator on an internet truck forum and drives a jeep? Met a friend of a friend this weekend that said she knew someone named Chris that fit this description. Had me and @Coot83 awfully suspicious of you
    Coot83, wilcam47 and Daria like this.
  20. Apr 19, 2020 at 9:37 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    That doesn’t ring a bell. Do you have a description of the Jeep or said girl?
