AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Apr 30, 2020 at 5:47 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Well.. it works!
  2. Apr 30, 2020 at 6:00 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    cytocycle and OneWheelPeel like this.
  3. Apr 30, 2020 at 6:49 PM
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    JIM
    I've been binging The Office.
    Atl-atl and XPOTRPR[QUOTED] like this.
  4. Apr 30, 2020 at 7:42 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Lol. Funny you mention that. My Wife has started watching it these last couple weeks. First time either of us have watched it. It's not as bad as I thought it would be.
    Fearthisbeard likes this.
  5. Apr 30, 2020 at 8:29 PM
    Snaeper
    Martin
    Phoenix, AZ
    First time for me, too, aside from the odd episode when it originally aired. The side and background jokes are my favorite bits.
  6. Apr 30, 2020 at 8:29 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I put some down pressure on my brand and it comes out cleaner
  7. May 1, 2020 at 7:32 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    That was with some pressure. It actually came out much cleaner than I expected, and completely ok with it. That was tested on a scrap 2x4 I had laying around. The soft Balsawood type wood this little box is made of was definitely more tricky.
  8. May 1, 2020 at 3:48 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Awesome to see! To everyone on the front lines!
    Seven F-35A Lightning IIs and seven F-16 Fighting Falcons will be flying out of Luke Air Force Base, and one KC-135 will be from the 161st ARW.
  9. May 1, 2020 at 4:20 PM
    shadow images
    shadow images Member
    2009 Tacoma TRD
    They flew straight over our house95329468_10215900423213925_1491619851020533760_o.jpg
  10. May 1, 2020 at 4:24 PM
    LTacoman
    LTacoman Well-Known Member
    Luis
    Gilbert, Az
    2019 F150 Lariat EB
    I'm bummed I didn't get to see them out here in SE G_Town :tumbleweed:
    wilcam47 and freddy2923 like this.
  11. May 2, 2020 at 9:08 AM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Round 2 has begun. Reality is setting in. After disconnecting the winch, front camera, bumper ditch lights, bumper light bar, grill lights, accent lighting, skit plate, and grill cover, I used the engine hoist to support it as I yanked it off.
    Now Ive moved onto the hoses and factory wiring. It's a bit overwhelming!
  12. May 2, 2020 at 9:49 AM
    Atl-atl
    Atl-atl Well-Known Member
    Phoenix+Flagstaff
    2024 Ram Power Wagon
    Fox, Thuren, 40s, other stuff
    Well I did a thing, but dont worry @snowsk8air2 I am nowhere near good enough to build my bumper...
  13. May 2, 2020 at 1:38 PM
    Techoma
    Alta Mesa, AZ
    And quitting just a few hours later.... Tranny bolts loose, fan and shroud removed, radiator hoses off, exhaust disconnected, and a handful of harnesses/misc bolts removed.
  14. May 2, 2020 at 3:50 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Yeah that thing will be fun and handy for little projects here and there. But definitely not a bumper building welder.
    Atl-atl[QUOTED] likes this.
  15. May 3, 2020 at 1:31 PM
    wilcam47
    Will
    Bourbon state
  16. May 4, 2020 at 10:13 AM
    Atl-atl
    Phoenix+Flagstaff
    Anyone have a roofer and painter they recommend? I need to get some things fixed up in order to list my house for sale in the next couple weeks.
    wilcam47 likes this.
  17. May 4, 2020 at 5:51 PM
    BillW
    BillW Well-Known Member
    N. Phoenix
    2018 DCSB TRD OR MT
    I kept procrastinating, but I'm scheduled next week to take my Tech ham license test. Pretty stoked. Have the HT pretty much picked out, now to figure what mobile system to run.
    cytocycle, wilcam47 and llibrm like this.
  18. May 4, 2020 at 7:49 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Sup guys. For those up north in the Flagstaff area. Hows the rental market? Taken a hit lately? Moving there early June for work. Gotta find a place in or near Flagstaff; ~within a hours drive basically.
  19. May 4, 2020 at 9:06 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Tons of rentals up here as it’s a college town. But, most are apartments or similar. Not sure what you’re looking for, but June should have lots available since all the college kids are gone.
  20. May 5, 2020 at 6:19 AM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    I need a house, moving the family over in June. I have a few that I need to call about. Just looking for some local input. Oh, I dont need to be close to NAU. Probably further away would be good. My kids are still young.
