AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Sep 15, 2020 at 12:50 AM
    mangosmoothie
    mangosmoothie Well-Known Member
    Casey
    Northern AZ
    '22 Pro
    Anyone wanna show me some trails next month? Should have this thing ready to ride. Just needs fuel lines now. For how simple those carbs are... Total nightmare. Leaked gas. Cleaned. Still leaked. Rebuilt with new needle and seat. Still leaked. Adjusted floats, one was slightly off. Still leaked. Banged it with a wrench. No more leaks.
    Now I'm scared to ever pull the bowls off to change jets. Luckily it seems jetted ok.
    BillW, Tsinajinii and cytocycle like this.
  2. Sep 15, 2020 at 5:28 AM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    If you've already checked the grounds, it may be the factory fog lamp relay.
    Baja Designs LED...polar opposite of Chinese :thumbsup:
  3. Sep 15, 2020 at 10:17 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    this. They are Baja Designs with some weather pack connectors. I'll try some DE grease and check relays/fuses.
    I have an HP Tuner with a Trans flash. I'm running 4.56's but I also have a Shift Kit and S/C as well. Regardless, the flash will help out with shift points. Get with @JustDSM for the Trans files. I'm not skilled enough to mess with the tables myself. I just did the logging and file saving, then sent off my stock file logs to Justin and he sent back the new files to flash. all easy to do.
  4. Sep 15, 2020 at 1:41 PM
    mangosmoothie
    Casey
    Northern AZ
    '22 Pro
    I plan on hitting coral pink and sand hollow. Loan Rock is close and also looks pretty fun. I hear sedona has some good trails too.
    Thanks for the heads up. I've been meaning to check if my pipes have spark arrestors but I forgot. If not, I plan to order some FMF Turbinecore silencers. The website says they're USFS approved.
  5. Sep 17, 2020 at 6:05 PM
    micah323
    micah323 Well-Known Member
    What are you guys all running for skids in Az? Trying to decide between rci aluminum or steel. Not going to be doing anything crazy since truck has almost 200k. Just don’t want to buy alum to save weight and find out they don’t work to well around Phoenix
  6. Sep 17, 2020 at 6:37 PM
    Dudeman86
    Dudeman86 Well-Known Member
    Scottsdale, AZ
    2016 Black DCLB OR
    I am running a full set of RCI steel. Got a lot of whacks on it while running stock suspension. Once I upgraded my suspension, rarely hit the skids now. I mostly use my truck for hunting, not climbing over boulders.
    llibrm likes this.
  7. Sep 18, 2020 at 12:11 PM
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    4.88, Radflo 2.5" Resi,ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack+2,front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
    I run aluminum and they work here no problem. Steel let’s you slide better on rocks whereas the aluminum will hang a little. I needed the weight reduction and makes working on truck way easier when you are dropping armor
  8. Sep 18, 2020 at 1:12 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Full aluminum here as well. they get bent and gouged if you use em enough.
  9. Sep 18, 2020 at 3:11 PM
    micah323
    Do you wish you got steel?
    wilcam47 likes this.
  10. Sep 18, 2020 at 4:02 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Definitely not. The weight savings and ease of off/on is worth it imo. For the majority of our wheeling.. they do just fine. Occasionally I'll do some stuff that beats on em, but they hold up pretty well. Some gouges and small bends but nothing structurally threatening. At the end of the day they are better than stock so no complaints.
  11. Sep 18, 2020 at 6:34 PM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    I agree. I have a 4 banger so I need all the help I can get in the weight department. However, they do show more wear and tear.
    Das it mang, Snaeper and wilcam47 like this.
  12. Sep 19, 2020 at 7:37 PM
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    That one's them fancy Canadian plates?
    Bikinaz[QUOTED] likes this.
  13. Sep 19, 2020 at 9:00 PM
    Bikinaz
    Hey You!
    Phoenix, AZ
    Nah. It came with the truck. I'll probably keep it till I punch a hole clean through it, which will probably be the next time I try to keep up with you on the trail. :p
    I do believe it is a collector's item though. I'm pretty sure Relentless is out of the skid plate game.
    Snaeper[QUOTED] likes this.
  14. Sep 19, 2020 at 9:04 PM
    Snaeper
    Martin
    Phoenix, AZ
    Oh, nice, and let's hope not!
    I need to get a skid on mine, otherwise I'll beat you to the hole in the oil pan.
  15. Sep 19, 2020 at 9:06 PM
    Bikinaz
    Hey You!
    Phoenix, AZ
  16. Sep 19, 2020 at 9:11 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Diablo trail is cool with history. But unfortunately with the proximity to the border. It can be dicey to run. Used to hit it from the west when I was stationed in Yuma. Hell we didn’t even know the official name. Just was a cool trail.
    Snaeper and Bikinaz like this.
  17. Sep 19, 2020 at 9:13 PM
    Snaeper
    Martin
    Phoenix, AZ
  18. Sep 19, 2020 at 9:16 PM
    Bikinaz
    Hey You!
    Phoenix, AZ
    It's been on my to do list for too long. Due to the remote location I haven't done it alone but I'm shooting for December.
    Snaeper likes this.
  19. Sep 19, 2020 at 9:18 PM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    I wouldn’t solo. But if you are I’d contact the border patrol let em know your plans. So they can kinda keep track of ya. There all over out there. Plus they grate the roads with tires often looking for tracks.
  20. Sep 19, 2020 at 9:22 PM
    Bikinaz
    Hey You!
    Phoenix, AZ
    Yeah, I'm going to want at least a second vehicle to go along. I don't want Murphy's Law choosing me 40 miles walking from the nearest NAPA store.
    MR E30 and wilcam47 like this.
