AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Jan 21, 2023 at 2:47 PM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    a lot of grassroots rally guys will use 1/4 thick HDPE sheets for skids of sorts. It works to deflect and flexes, some times cracks, but in true rally car fashion…:itllbuffout:
    llibrm, Nitori[QUOTED] and Yacob_D like this.
  2. Jan 21, 2023 at 3:11 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Yeah I have an idea to mod my existing RCI skids, a little plan that probably wouldn't cost a ton and gain me a fair bit of clearance but sadly I'm not a custom fabricator and I can't weld aluminum. Everything else is mostly just measuring and cutting, but I don't have access to a lift or a workshop with something to zip through 1/4" aluminum easily. So it'd be a lot of testing and fitting and going back and forth on my DD which would be an absolute ballbuster.
    Basically it goes as follows:
    -Zip off the diff drop tumor, since I'm not using a diff drop. Weld in a plate of aluminum, cut a relief slot in it if necessary.
    -Move back to the interface between the transmission and engine skid. Use a setup with a plate and some nut serts on top of the crossmember to stick some countersunk bolts into, up through from the bottom. Kinda like the Artec belly pan:
    Screenshot 2023-01-21 at 16-00-02 (14) Toyota 4Runner 5th Gen Bellypan System INSTALL - YouTube.jpg
    -Cut the engine and transmission skid to fit against each other like puzzle pieces, instead of stacked one on top of the other. Zip down the bolt protection shelves because the new bolts are countersunk.
    -Move to the rear of the transmission skid and give it the countersunk bolt treatment too.
    Most of it is drilling countersinks but that cut and weld... yeah that'd be a bear for me to DIY.
    MulletTaco likes this.
  3. Jan 21, 2023 at 5:11 PM
    Ross4x4
    Ross4x4 Well-Known Member
    Taylor
    Mesa , Az
    2014 DCSB Silver TRD Offroad
    Kinetic ropes are meant to give a head start and give a yank, tow straps are meant to be pulled tight then use the tension to pull out. A lot of people use tow straps like they would a kinetic rope and it’s super dangerous.
  4. Jan 22, 2023 at 6:27 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
  5. Jan 22, 2023 at 9:34 AM
    MulletTaco
    Kevin
    Somewhere in AZ
    If you wanna buy me a spool gun for my Hobart handler I’d gladly put it together for ya lmao. And a 4.5” cut off on a grinder will work just fine to “zip” through the aluminum
    cookiedough likes this.
  6. Jan 22, 2023 at 9:35 AM
    MulletTaco
    Kevin
    Somewhere in AZ
  7. Jan 22, 2023 at 9:36 AM
    MulletTaco
    Kevin
    Somewhere in AZ
    Very, pretty sure that’s partially what helped kill that guy up near kingman not too long ago
    Rudimentality likes this.
  8. Jan 22, 2023 at 11:35 AM
    Taco_Traplord
    Taco_Traplord Well-Known Member
    2018 Taco Off-Road
    Hey anyone know of a shop or someone who does good cmc or bmc for 4Runners. Need it done whenever because my tires rub.
  9. Jan 22, 2023 at 1:04 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah. Enjoying the snow. And up to another foot coming tomorrow. This particular spot was very very deep and heavy snow
    MulletTaco[QUOTED] likes this.
  10. Jan 22, 2023 at 1:38 PM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    @state48overland
    Maybe @Maxx, too? :notsure:
    Maxx and Taco_Traplord[QUOTED] like this.
  11. Jan 22, 2023 at 4:17 PM
    Maxx
    Maxx Well-Known Member
    I can cut but I can’t weld. Lol. My buddy who did all my welding moved so have to get a machine and comfy with it. Have to wait until I move since have no room.
    TailHook[QUOTED] likes this.
  12. Jan 22, 2023 at 4:27 PM
    TailHook
    Alan
    Southern UT
    I need to learn how to weld myself...
  13. Jan 22, 2023 at 4:35 PM
    Taco_Traplord
    2018 Taco Off-Road
    Hahaha screw it don’t need no plate there jk man! Yeah my brother is good but he’s all the way in northeastern AZ
  14. Jan 22, 2023 at 4:36 PM
    Taco_Traplord
    2018 Taco Off-Road
  15. Jan 22, 2023 at 5:34 PM
    cookiedough
    cookiedough Well-Known Member
    Phx, Arizona
    02 DCSB OR, 19 DCSB OR
    '02 - No mods. '19 Blue Friday - GFC, RXT S1, Bilsteins
    I should probably take my advice I gave my daughters, figure out what you want to do and acquire the tools and skills to do that. I'm probably spending too much time on the YT. I don't really trust some unknown to yank me out, and I don't want some unknown rear ending me. Traction boards, compressor and a proper shovel I think will be my recovery gear (which I already have). I only have the stock hooks on the front, maybe I'll machine up a factor 55 style hitch mount for the rear. If I'm in deep, I get to spend some quality time with a shovel.
    @TailHook - ok, brain housing group - had to look that one up (I'm thinking, wow, I haven't ever heard of that brand) - and yes made me laugh! Agreed. As an engineer, I probably try to engage that way too often and spend too much time trying to work out a unique solution instead of just getting it done.
    Thanks for all the input, yes I do appreciate and have look up most of the suggestions, and those using the urban dictionary were mostly done at home.
    TailHook and PilotBoy352 like this.
  16. Jan 22, 2023 at 5:35 PM
    cookiedough
    Phx, Arizona
    PilotBoy352 likes this.
  17. Jan 22, 2023 at 5:44 PM
    PilotBoy352
    PilotBoy352 Well-Known Member
    Tim
    Mesa, AZ
    2015 MGM DCSB (rip) now 2018 white DCSB TRDOR 6MT
    Since we're on the topic of recovering stuck tacos, anybody know a good set of recovery boards for about $75 or less? I'm looking at the x-bull ones, but any advice would be great. Thanks!
  18. Jan 22, 2023 at 7:43 PM
    cookiedough
    Phx, Arizona
    I have the x-bull. Used them several times in Vermillion Cliffs NM. Always fully supported, in sand, never bridging a gap, careful throttle control. I guess I kinda know they are not as durable as say a real MaxTrax, but then not the cost either. A good shovel and a compressor to enable you to air down and refill will get you out of most things in the SW. Brain Housing Group, my newest acquired phrase - know the limitations of the tool, and you'll do just fine.
    But then I'm not asking the most relevant question, what are you hoping to get out of, where are you planning on going and needing to get out of? Me - I'm mostly on forest service roads, probably some sand, never in a lake bed - ain't worth it - and other members have had multiple lessons.
  19. Jan 23, 2023 at 6:47 AM
    Enjoihavok
    Enjoihavok Never Forget Z.S.
    Erik
    Chandler, AZ
    2021 Tundra Pro
    Finished the ucs millennium falcon this weekend, it’s massive for sure:
    Here’s what the family had built in the last 2-3 weeks of family building time:
    Wife built the monkey kid set, daughter did the princess castle set, my son powered threw and built the tiger, groot, iron man set, the imperial light cruiser then moved onto a Star Wars armored marauder (not pictured, finished that in a day and now is onto the daily bugle set:
    cookiedough, Phessor, llibrm and 6 others like this.
  20. Jan 23, 2023 at 7:03 AM
    PilotBoy352
    Tim
    Mesa, AZ
    I just got the bonzai tree on friday, and I ordered the Jurrassic Park diorama set online since honey gave me $15 cashback. I can't wait to get the JP set, I'm a huge fan!
    Enjoihavok[QUOTED] likes this.
