AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Mar 17, 2023 at 11:06 AM
    Rudimentality
    Rudimentality Well-Known Member
    Brad
    Mesa, AZ
    3rd Gen DCSB TRD Off-Road
    Stuff that costs more than my wife thinks.
    Ah shit, I’d have to look back. I did the full kit, wheels and tires on one invoice to follow the buy once cry once method, only to come back this spring for the front end. @state48overland could probably give a better ballpark of what they’re running today. I ordered late 2021 and waited the wait to avoid price hikes that have since occurred.
    but yes, they are the 2.5’s. Love the build and the ride.
    TailHook and KingOfTheNorth like this.
  2. Mar 17, 2023 at 11:08 AM
    Rudimentality
    Brad
    Mesa, AZ
    bet you love ‘em more when they’re quiet! :rofl:
    In all seriousness, nothing but love for those that choose parenthood. We are the funcles that spoil the shit out of the kids that were born to teenage siblings.
    we spend more than enough on those crumbs snatchers.
    KingOfTheNorth likes this.
  3. Mar 17, 2023 at 11:16 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Amd here i thought it was crabs.
  4. Mar 17, 2023 at 11:50 AM
    Atl-atl
    Atl-atl Well-Known Member
    Phoenix+Flagstaff
    2024 Ram Power Wagon
    Fox, Thuren, 40s, other stuff
    In addition to what you’ve already got, to go up to 35s truly without rubbing offroad youll need a cab mount relocation, lots of firewall massaging with a large sledge, ditch your wheelwell liners entirely, cut n fold the pinch seam and most likely something like the JDFab subframe which will run you about $3000 installed plus the correct UCAs to match it. Thats my current setup and i still rub occasionally when offroad. I need a true firewall “correction” :rofl:or a solid axle which might happen sooner than later.
    Rudimentality[QUOTED] likes this.
  5. Mar 17, 2023 at 12:12 PM
    Rudimentality
    Brad
    Mesa, AZ
    yup, all sounds about as expected. Gonna put some dirt and work on these before I move up, as the build suits me just fine for now.
    And then I go to a meet with you assholes. :spending:
  6. Mar 17, 2023 at 12:15 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    This is why I say wheel specs are a big part of it. What's the backspacing on your wheels out of curiosity?
    I have done all the same, minus the JD kit obviously, but have set up my DK lowers to imitate what the JD kit does to a point (push everything forward) and I have minimal rubbing (only when actually hard stuffing while wheeling). Tires play a factor as well with so many different sizes and lug design/size.
    Not trying to be negative or anything.. but hearing that you still have issues with the JD kit makes me feel a little better and gives a little reassurance/justification as I had just spent a large amount to rebuild the front end with the DK LCAs, another new pair of gusseted spindles, wheel bearings, Wilwood BBK, new wheels with the specific offset I wanted, etc and then I saw the JD stuff. So, I have been determined to do as much as I can with what I currently have, vs going through the process of selling, buying again, more down time, etc... because I did think about it there for a while.. lol
    true solution is choppity chop chop. which is what I'm gonna be doing shortly. guess what I'm getting as is I dont think there is an almighty one and done solution. too many variables... even with a specific kit to help.
    In general.. I think wheel specs + max caster that you can get away with + cutting/trimming/tubbing for the rest are the main/dumbed down points.
  7. Mar 17, 2023 at 12:27 PM
    Twitch57
    Twitch57 Well-Known Member
    N AZ
    2021 DCSB SR 4x4
    ....Chuckles then Sobs of desperation....
  8. Mar 17, 2023 at 12:35 PM
    PilotBoy352
    PilotBoy352 Well-Known Member
    Tim
    Mesa, AZ
    2015 MGM DCSB (rip) now 2018 white DCSB TRDOR 6MT
    Anybody got a reliable alignment shop in the east valley? I'm installing my icon suspension tomorrow and want to get it aligned afterwards. Thanks in advance.
  9. Mar 17, 2023 at 12:36 PM
    Rudimentality
    Brad
    Mesa, AZ
    this is the real reason I’m in no hurry. When I go away from the current build, I’ll do it big, so gonna enjoy what I’ve got while I’ve got it.
  10. Mar 17, 2023 at 12:36 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Desert Toy Shop.
  11. Mar 17, 2023 at 1:06 PM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    @state48overland is another good choice...
  12. Mar 17, 2023 at 1:07 PM
    TailHook
    Alan
    Southern UT
    The real question is...did you do the sway bar delete yet?
  13. Mar 17, 2023 at 1:22 PM
    PilotBoy352
    Tim
    Mesa, AZ
    They're closer than Desert Toy Shop to me, I'll probably end up going there. Thanks for the help! I may be back for advice when I do something wrong:anonymous:
    TailHook[QUOTED] likes this.
  14. Mar 17, 2023 at 1:27 PM
    Atl-atl
    Phoenix+Flagstaff
    Current wheels are RRW RR6-H 17x8.5 ET0. They rub. Previous wheels were Method MR314 17x8.5 ET-25. They rubbed and also they rubbed on my rear shocks due to the 12" shock conversion thus the reason I swapped wheels. Once I did the JDFab subframe my firewall rubbing essentially stopped except at like 3/4 lock in a really crossed up crawling type scenario where the very corner of the tire tread is closest to the firewall. I could definitely pound back my firewall more but Im slightly concerned about the fusebox thats right on the other side. I now only rub the top of the inside of the wheel wells, even with superbumps and Im only on BFG AT2s 315/70-17. If I were on a true "35" things would be worse. Im half tempted to go "up" to a true 35 instead of 37s but I hate thinking about getting into a D or E load rating. I love the C load rating you can get with the BFGs. Thanks Furd.
  15. Mar 17, 2023 at 1:42 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Same for me.. only on the corners, fully locked and twisted up.. the lugs grab, and these M/T Baja Boss MTs are true to size 35 and extra chunky in the side lugs. no wheel spacers right? Interesting regardless. I found the -25mm to be the sweet spot (at least for the front).. but good (and bad) to hear about the rear interference on the conversion.. as that's on the soon to be done list as well. Wondering if its the same across the board for all the rear towers out there. I wont run spacers myself.. so that would mean I would be looking for different wheels as well if that does become an issue. Also.. going from E's to these M/T D rated tires.. was amazing. Personally I would never run a C.. but if you're used to it.. I can see that being a drawback.
    05tacomabro likes this.
  16. Mar 17, 2023 at 5:13 PM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    Guy I bought my wheels from invited me out to China dam today. Great loop. Lots of water.
    2E8E4196-1182-458C-8C11-4515C8C302D6.jpg FCFA511F-8E25-45BE-803B-63C959D21891.jpg 96F47EF6-65D3-428B-9883-6007D02FA394.jpg828C59C3-0C2D-4442-BEE5-B0FD3953ACC3.jpg
    Jeep guy wanted to join the cool kids somewhere along the trail lol
  17. Mar 17, 2023 at 5:14 PM
    Atl-atl
    Phoenix+Flagstaff
    No spacers. I did like the -25 Methods and contemplated running a spacer but ultimately I chose not to. It just baaarely rubbed enough to scuff my schmancy shocks and piss me off. I have the BAMF shock relocation for what its worth. As for not running C load rated tires, why not? They ride nice, flex really well when aired down and are a lot lighter weight. The load rating of my BFG ATs is 2535 so its plenty even with my weighed down pig of a rig to lift a tire offroad and still not be over the weight limit of 3 tires. What more do you need?
  18. Mar 17, 2023 at 5:46 PM
    PilotBoy352
    Tim
    Mesa, AZ
    That looks sweet! Where exactly is that at?
  19. Mar 17, 2023 at 5:59 PM
    MulletTaco
    Kevin
    Somewhere in AZ
    Up north of lake pleasant
  20. Mar 17, 2023 at 9:04 PM
    65skyturbo
    65skyturbo Well-Known Member
    Mesa, AZ
    06 Speedway Blue DCSB TRD Off Road
    Yeah, I wish there were more choices for C rated tires in the larger sizes. Toyo and General have 35x12.50's in load C.
    https://www.tirerack.com/tires/tire...QR7OCAT3&vehicleSearch=false&fromCompare1=yes
    https://www.tirerack.com/tires/tire...d Red Letter&partnum=525QR7GRX3RLV2&tab=Sizes
    I don't recall seeing any C rated 37's besides BFG. I'm hoping they become more common now that the Raptor is available with 37's and tire manufacturers want a direct replacement option to be available. I guess it just comes down to how much demand there is from Raptor owners for C rated replacements.
    I've got to admit though, I didn't see a drastic difference in ride quality changing from C rated KO2 to D rated Baja Boss A/T tires. I can tell they are heavier when braking, and noisier at speed, but still about 90% the ride quality of the BFG. I had a 40 year veteran with Discount Tire tell me that it's not the load range letter rating that matters for ride quality but the load index number. The lower the number the more flexible the tire. I'm inclined to believe him since my experience lines up. The C rated BFG's are a 116 index and my Baja Boss is 119. I had C rated 34" Ridge Grapplers before the BFG's and they were nowhere near as soft as the BFG's. They were rated at 118. Rubber compound also plays into this since the 119 rated, D load Mickey Thompsons ride much better than the 118 rated, C load Nittos. Just my 2 cents for what it's worth...
