AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Mar 28, 2023 at 6:54 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    I have one in my garage you can come over and use. Tolerances and spacing will only be as good as you can make them with your hands though.
  2. Mar 28, 2023 at 8:25 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    got a pic of what you're trying to do? If its something quick and basic I can probably do it after work one day for you..
    05tacomabro likes this.
  3. Mar 28, 2023 at 9:19 AM
    05tacomabro
    05tacomabro will work for truck parts...
    Alex
    Tucson
    05 dcsb trd OR, 06 xrunner, 73 fj 40
    Icon ex. Travel co's, spc uca's, bamf lca skids, 1" body, all pro heavy duty sliders, expo springs, BAMF shackle hangers, 14" bilstein 7100, rear frame box, custom rear frame crossmember, ifs skid, transmission skid, t-case skid(modified by @jeepandrew for exhaust reroute and more beef), custom k&n intake, flowmaster, diff breather mod, stereo with nav/speakers/subs, coverking tactical ballistic seat covers, Baja utility rack, lots of bed liner, anytime fog mod and steel braided brake lines, energy suspension rad support bushings, abs kill switch, cali raised ditch lights, fsr rtt. Lots of plans, little money....
    Im quick and basic and you can do me anytime after work.... and my feet pic will slide in your dms soon
  4. Mar 28, 2023 at 9:27 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :rofl:
    05tacomabro[QUOTED] likes this.
  5. Mar 29, 2023 at 5:32 AM
    prise
    prise AZ's Toaster Strudel Low T Andrew
    Prise
    Rally Runner 04 GX470
  6. Mar 29, 2023 at 8:55 AM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    This is exactly the kind of thing that’s ruining good clean family threads…
    …I love it :taco:
  7. Mar 29, 2023 at 9:03 AM
    Yacob_D
    Yacob_D It's Fine, Leave It.
    Jacob
    The J
    08 Red, AC
    Couple nuts and bolts 4x converted
    Seen this comment while scrolling for another posted video. Sorry I didn't get you one Kevin, I think i was loading Bills bumper and you guys bounced really quick to get bk hm. I've got plenty more for another meet up.
  8. Mar 29, 2023 at 9:06 AM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    Looking for the coil spring video, I wanna refresh the how to and slam my new coils in Thursday before the weekend.
  9. Mar 29, 2023 at 9:40 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    you'll need a wall compressor or the like to swap coilover coils.
  10. Mar 29, 2023 at 9:43 AM
    Atl-atl
    Atl-atl Well-Known Member
    Phoenix+Flagstaff
    2024 Ram Power Wagon
    Fox, Thuren, 40s, other stuff
    Ive done it with the sketchy rental compressors a few times but I dont condone that behavior, especially when you get up to 700lb springs :eek:
  11. Mar 29, 2023 at 9:46 AM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    Damnit, I was afraid they would be too tough to cheat with a floor jack like i did with the 650lbs..
    Guess ill take it to my buddies shop.. No go for new coils this weekend:annoyed:
  12. Mar 29, 2023 at 9:51 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I've tried it too and yeah.. bailed on it and found a wall compressor to use. A hydraulic press with the right spacing/setup works too,. @05TacoRunner showed me that trick.
  13. Mar 29, 2023 at 9:51 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    we can do coils one day soon too if you want.
  14. Mar 29, 2023 at 9:53 AM
    Atl-atl
    Phoenix+Flagstaff
    Wait, do you have coilovers or something like Bilstein 5100s?
  15. Mar 29, 2023 at 10:04 AM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    6112's with 650lbs , going to 700lbs coils to help with added weight
  16. Mar 29, 2023 at 10:06 AM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    Ive got a message to my buddy. Seeing him this evening to look into my bad exhaust rattle. Better bring beer and the coils if he has his press up. I'll get bk to you on this.
  17. Mar 29, 2023 at 10:08 AM
    Atl-atl
    Phoenix+Flagstaff
    Ok those you can do with the floor jack method. Jack up the LCA to compress the spring enough to take the tension off the shock shaft nut, undo the the shock shaft nut, undo the UCA/ball joint nut and separate from the spindle, lower the LCA and everything comes apart. Reassemble in reverse with the new coils.
    Twitch57 likes this.
  18. Mar 29, 2023 at 10:13 AM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    Yeah that's how I installed them, wasn't sure if the added 50lbs would be a bitch to compress. Wanted refresh my brain with the process. I do recall it being that easy, it's been a minute since I had them off.
    Thanks Mike
  19. Mar 29, 2023 at 10:14 AM
    Atl-atl
    Phoenix+Flagstaff
    Nah youll be fine with that method and 700s. I edited my post to add, make sure to undo the UCA from the spindle ha.
    Yacob_D[QUOTED] likes this.
  20. Mar 29, 2023 at 10:19 AM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    Taco tabs will be even better help now. I can loose them up and swing the LCA outta the way and not lose alignment!
    I’m sure I’ll find out really fast on the first side if I can get it done.
    Atl-atl likes this.
