AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Apr 20, 2023 at 9:43 AM
    PilotBoy352
    PilotBoy352 Well-Known Member
    Tim
    Mesa, AZ
    2015 MGM DCSB (rip) now 2018 white DCSB TRDOR 6MT
    Sweet! I'm at Power and McDowell, so I may be seeing you around the streets:anonymous:
    Yacob_D likes this.
  2. Apr 20, 2023 at 9:54 AM
    Ross4x4
    Ross4x4 Well-Known Member
    Taylor
    Mesa , Az
    2014 DCSB Silver TRD Offroad
    ITs gunna be weird not having an hour commute just into town :rofl:
  3. Apr 20, 2023 at 9:55 AM
    Ross4x4
    Taylor
    Mesa , Az
    Ill be around that area often. See ya around :cheers:
    PilotBoy352[QUOTED] likes this.
  4. Apr 21, 2023 at 3:51 PM
    Dudeman86
    Dudeman86 Well-Known Member
    Scottsdale, AZ
    2016 Black DCLB OR
    So does anyone shop in AZ make a decent swing out bumper? Recently went up on tire size and need to carry full size spare along with me. Thanks in advance.
    05tacomabro likes this.
  5. Apr 21, 2023 at 7:31 PM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    Idk about shops but I hear @snowsk8air2 is a great fabricator. There’s @Yacob_D, @KingOfTheNorth, myself and a few others that know their way around welders and steel
    KingOfTheNorth likes this.
  6. Apr 21, 2023 at 7:45 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    What size tires you running? 33’s/285’s fit under the bed still pretty easily. Seen a few guys fit 35’s under there with a little persuasion.
    Yacob_D likes this.
  7. Apr 21, 2023 at 9:19 PM
    Maxx
    Maxx Well-Known Member
    Unless it’s 37”+ then it will fit. Now if your just looking for an excuse for a new bumper, we can support that.
    Ross4x4, TACOTU3, Yacob_D and 3 others like this.
  8. Apr 21, 2023 at 9:54 PM
    Atl-atl
    Atl-atl Well-Known Member
    Phoenix+Flagstaff
    2024 Ram Power Wagon
    Fox, Thuren, 40s, other stuff
    Like the other guys said, if you just want a bumper then yeah, get one. Otherwise up to a 35 can be made to fit in the stock location with minimal modifications.
  9. Apr 22, 2023 at 6:58 PM
    azchris
    azchris Well-Known Member
    Prescott, AZ
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    I guess I'm being lazy by not searching this but... what mods get a 35 under the bed? I have a 33 under there right now pushed all the way back against the tow hitch and I'm pretty sure I do not have two inches of clearance between the tire and the diff. Maybe if I took the factory hitch out and got an aftermarket rear bumper with a receiver built in (but at that point I'd be pretty tempted to just do a tire carrier bumper).
  10. Apr 22, 2023 at 7:14 PM
    Atl-atl
    Phoenix+Flagstaff
    2nd gen and 3rd gen might be slightly different but you only need 1 inch of extra room all the way around not two. There are a ton of write ups about this. There are tabs hanging off the frame that are 2-3" long, they are meant to keep the stock size spare in place, you have to beat them flat or at least out of the way and then you remove the hoist, drill new holes for it farther towards the rear of the truck and then bolt it back in place. You might have to run the tire at 10-15psi depending on the tire but you should have a compressor in your truck at all times so that shouldnt be an issue. Here is a write up for relocating the hoist. https://www.tacomaworld.com/threads...to-new-adventures.528480/page-5#post-17311994
    llibrm, Yacob_D and saidyoudid like this.
  11. Apr 22, 2023 at 9:29 PM
    Maxx
    Chop the exhaust after the axle. That’s about the only extra thing you need to do if you already have a 33” tire under there. It will rub your diff a bit but that’s life. If you have stock rear hangers, more room and less likely to rub the diff.
  12. Apr 23, 2023 at 11:55 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    Free.99. Last chance as they are headed to the recycler tomorrow. Great for a trailer build.
    MulletTaco likes this.
  13. Apr 23, 2023 at 3:44 PM
    aroma
    aroma Well-Known Member
    Snottsdale AZ
    Are you planning on towing with it? I have an extra falcon tow bar and maybe a braking system.
  14. Apr 23, 2023 at 8:24 PM
    Atl-atl
    Phoenix+Flagstaff
    Not for this trip. In the future, maybe. They only rate these things at 5000lbs towing capacity which is kinda ridiculous. Id love to pull my K5 on a trailer behind it in the future to hit Moab and other fun places but that might be a pipe dream.
  15. Apr 24, 2023 at 7:15 AM
    KingOfTheNorth
    KingOfTheNorth Kum and Go King
    97 4runner
    All the mods
    I am still debating on which route to go with the rear bumper for the 4runner. Do I really want to weld another together or just spend the money on one that is all done.
    MulletTaco[QUOTED] likes this.
  16. Apr 24, 2023 at 8:21 AM
    Yacob_D
    Yacob_D It's Fine, Leave It.
    Jacob
    The J
    08 Red, AC
    Couple nuts and bolts 4x converted
    I was in the same boat with my rear bumper. I did the best of both and went with the Coastal Offroad like your wife has now. They designed it and I burned it together.
  17. Apr 24, 2023 at 8:28 AM
    KingOfTheNorth
    97 4runner
    All the mods
    yeah exactly. I am stuck between that one or the eimkieth one. But then I need to do a gas tank relocate and bigger tank.
  18. Apr 24, 2023 at 8:33 AM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    I like the look of that one as well. Does it call for a relocation or you just moving and upgrading?
  19. Apr 24, 2023 at 8:39 AM
    KingOfTheNorth
    97 4runner
    All the mods
    It is designed around a f150 tank to be added and relocated to where the spare tire goes. So get to add like a extra 5 gallons. I do like the more added armor around the bottom.
  20. Apr 24, 2023 at 8:43 AM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    That's what caught my eye, similar to the Coastal with the 3/16" wrap under.
    The added fuel would be helpful but not the weight.
