AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Jul 20, 2024 at 2:54 PM
    jjsinaz
    jjsinaz Well-Known Member
    Jim
    Sun City West, AZ
    2023 TRD Sport DCLB Ice Cap 4X4
    Gees! Glad you're okay. That must have been a scary experience.
  2. Jul 20, 2024 at 6:16 PM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
    Damn man hope you're OK
  3. Jul 20, 2024 at 7:17 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Damn, here's one to hoping it all goes well. The fact that your posting here is a good sign.
    TailHook and Nitori[QUOTED] like this.
  4. Jul 20, 2024 at 7:37 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    The world can't escape my shitposting that easily.;)
    Honestly I feel mostly normal and the PT/OT gave me approval to come home (which I am now) and they pretty much point blank said this was an extremely lucky break.
  5. Jul 20, 2024 at 8:16 PM
    OnePuttBlunder
    AZ
    Twas a good night. Good thing it was warm forgot my new down quilt thankfully the Dixxon sherpa blanket I had in the truck was enough
  6. Jul 22, 2024 at 6:27 AM
    KingOfTheNorth
    KingOfTheNorth Kum and Go King
    97 4runner
    All the mods
    damn man. Glad you were able to make it to your phone and youre alright!
  7. Jul 22, 2024 at 6:34 AM
    azshooter40
    azshooter40 Well-Known Member
    Robert
    Chandler, AZ
    2020 OR 4x4
    Damn! Glad to hear you are back home and up and moving.
  8. Jul 22, 2024 at 6:36 AM
    azshooter40
    Robert
    Chandler, AZ
    2020 OR 4x4
    It was good to get out of this brutal heat for a while!
  9. Jul 22, 2024 at 7:35 AM
    jayavilak5
    jayavilak5 Well-Known Member
    Jay
    Phoenix, AZ
    2018 TACOMA TRD OFF ROAD 4x4
    Dang! Glad to hear you are doing better!
  10. Jul 22, 2024 at 3:03 PM
    taco_jak
    taco_jak Well-Known Member
    18 TRD Sport 4x4
    anyone have suggestions on removing uca’s on a 3rd gen? Cut the bolt/bend the metal? Thoughts?
  11. Jul 22, 2024 at 3:19 PM
    KingOfTheNorth
    97 4runner
    All the mods
    bend the metal then push and yell.
  12. Jul 22, 2024 at 3:27 PM
    jayavilak5
    Jay
    Phoenix, AZ
    Grab some channel locks and bend the sheet metal outwards a bit to clear. Just be careful because there is some wiring/brake lines behind it on the drivers side if I remember correctly. Some just cut the bolt and install it backwards with loctite. I re-installed it in the same direction.
    total chaos posted this years ago and he shows where to bend:
    https://youtu.be/bbsTJgb6S_c?si=idAUfi_DXf-TZD9H
  13. Jul 22, 2024 at 5:43 PM
    Yacob_D
    Yacob_D It's Fine, Leave It.
    Jacob
    The J
    08 Red, AC
    Couple nuts and bolts 4x converted
    Just bend it outta the way. Keep in mind the little plastic clips that hold a few wire looms and you can manage without too much damage. DON'T use vise grips, it can be done very carefully with an adjustable wrench in small bits and bent back afterwards. The mud flaps will hide some sin if you get carried away. Easily a one man show, just take your time. Replacing can be tough when lining up the washers, but very doable. Get yourself a long rod to help push the bolt in on both sides. Slip it in through the from grill and lightly tap it into place. You can access both bolts from the grill. Check the washer locations after a few taps and send it. Best of Luck
    Please don't install the bolt backwards.. Not a good idea IMO
    AZTaco2sDay and taco_jak[QUOTED] like this.
  14. Jul 22, 2024 at 7:14 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    The bolt is a pain in the balls to get in backwards anyways.
    You run into just as many clearance issues hitting it from the back with the same sized rod. :burp::rofl:
    Honestly I feel like a very precise little notch would make the replacement sunshine and rainbows, but actually cutting it properly would be a bear.
  15. Jul 22, 2024 at 7:49 PM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    BillW and taco_jak[QUOTED] like this.
  16. Jul 22, 2024 at 8:34 PM
    taco_jak
    18 TRD Sport 4x4
    That’s a resounding answer from all of you: bend metal > cut bolt.
    Thanks. Dont know when the front shocks are coming in the mail, but I found out my future BIL has a shop/lift I can use in Flagstaff. It was a drive to install the rear suspension this weekend but a happy one as the temps dropped.
    no more saggy taco butt on my ride.
    KingOfTheNorth likes this.
  17. Jul 22, 2024 at 8:40 PM
    taco_jak
    18 TRD Sport 4x4
    I saw that video but it’s a second gen and I read that the 3rd gen was tighter clearance. Hopefully I’ll be able to take my dad with me as a second set of hands.
  18. Jul 23, 2024 at 7:40 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    I just cut my OEM bolt and reinstalled a new OEM bolt backwards when I did mine. No bending required (only temporary repositioning of brake lines) and no tapping it in with a long rod from the end. Keep everything aligned and you can push it in with your hand, (maybe only if your truck is an AZ truck (rustfree), though we did clean/scrub everything, including inside of the tubing, during the disassembly process).
    The only story I have ever heard of a UCA bolt/nut coming undone was by a guy here in the AZBS thread, and his bolt wasn't reoriented to be backwards, it was OEM.
    The horrors associated with putting it in backwards are unfounded in my professional experience. Stick some Vibra-tite on your crucial bolt/nut interactions and periodically check them when you get gas or have a minute or two to spare waiting for someone to come out of the house/restaurant/store.
    TailHook, taco_jak and 05tacomabro like this.
  19. Jul 23, 2024 at 9:38 AM
    05tacomabro
    05tacomabro will work for truck parts...
    Alex
    Tucson
    05 dcsb trd OR, 06 xrunner, 73 fj 40
    Icon ex. Travel co's, spc uca's, bamf lca skids, 1" body, all pro heavy duty sliders, expo springs, BAMF shackle hangers, 14" bilstein 7100, rear frame box, custom rear frame crossmember, ifs skid, transmission skid, t-case skid(modified by @jeepandrew for exhaust reroute and more beef), custom k&n intake, flowmaster, diff breather mod, stereo with nav/speakers/subs, coverking tactical ballistic seat covers, Baja utility rack, lots of bed liner, anytime fog mod and steel braided brake lines, energy suspension rad support bushings, abs kill switch, cali raised ditch lights, fsr rtt. Lots of plans, little money....
    Huak tuah and spit on that thing
  20. Jul 23, 2024 at 7:22 PM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    ^^^^This^^^^
    Torque strip bright colors works awesome as well.
    TailHook likes this.
