AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Aug 5, 2024 at 10:37 AM
    Aw9d
    Aw9d That one guy
    Thanks fellas!
  2. Aug 5, 2024 at 1:23 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Duplantis of Sweden. World record holder for pole vault, won the gold. Just sailed ABOVE the bar every jump to get the gold. They allowed him to try to break his own world record by vaulting 20'6" after that. He made it on the third attempt. The stadium did NOT empty during his world record attempt.
    There was only 2 or 3 inches of the support posts left after they raised the brackets that hold the bar. They might have to modify the support posts for the future ...
    llibrm and Nitori like this.
  3. Aug 5, 2024 at 3:33 PM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    Anyone got a recommendation for an alignment shop, preferably east valley? Pulled the trigger on a 6112/6150 setup and gonna need to have something lined up.
    Also, any experience with Taco Tabs or any of the octagonal bolt kits? Debating about locking at least the rear to max out caster or both if it puts up decent numbers.
    TACOTU3 likes this.
  4. Aug 5, 2024 at 3:59 PM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
    Az Toy pros
  5. Aug 5, 2024 at 3:59 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Desert Toy Shop for alignment, and highly recommend Taco Tabs.. although.. they dont make them for your year 4runner... so I would suggest 333 Fabrications and their kit.
    velogeek[QUOTED] likes this.
  6. Aug 6, 2024 at 7:54 AM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    I have the Marlin crawler gusset kit and it's quite nice. Had to clearance a tiny spot in my TRD skid plate for the front, but only on the drivers side.
    I like the idea of keeping the adjustability of the stock cams, but reinforcing the tabs they interact with so that they will withstand more abuse.
    Of course I run stock tire size so even the marlin kit is probably stupendous overkill.
  7. Aug 6, 2024 at 8:13 AM
    Atl-atl
    Atl-atl Well-Known Member
    Phoenix+Flagstaff
    2024 Ram Power Wagon
    Fox, Thuren, 40s, other stuff
    Yeah but this is what we all really want to see...
    https://x.com/i/status/1819714571688677404
  8. Aug 6, 2024 at 8:36 AM
    Ross4x4
    Ross4x4 Well-Known Member
    Taylor
    Mesa , Az
    2014 DCSB Silver TRD Offroad
    so less oil in the liquid state = less performance? in terms of rebound?
  9. Aug 6, 2024 at 9:21 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    oh weird... could have sworn I saw them up to 2023 somewhere but must be crossing wires. I'll take a look at the 333 stuff.
  10. Aug 6, 2024 at 9:27 AM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    Rudimentality likes this.
  11. Aug 6, 2024 at 9:39 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Basically... it's not like it vaporizes like steam but it reduces aeration and viscosity issues that hurt performance.
  12. Aug 6, 2024 at 11:51 AM
    RichochetRabbit
    Not an expert in shocks, but if the system is "hydraulic", "pneumatic" is not good. Brake systems react badly to air in the brake fluid.
  13. Aug 6, 2024 at 12:14 PM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Well you always have some sort of gas in the shock or else piston movement gets janky. Nitrogen is the typical choice because it's more stable from a volume standpoint when heated and it's totally devoid of moisture. Even using totally dry air, oxygen expands more when heated and it makes things less predictable.
  14. Aug 6, 2024 at 6:14 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    As a heads up. Theres lots of changes coming in refrigeration world that WILL also effect home systems. Bascially the EPA is trying to get all the bad stuff out of circulation by a certain date, 2028-2030 ish.
    With that, certain refrigerants will be ceased to be made, same with components to repair such systems. 410a will be around for a but, but if you home system is 404 or older. Even a 410a system in 5yrs or so, expect costs to go up. Quite a bit. Not sure how soon they want to push the A2L stuff to residential, but its coming.
    asuchemist likes this.
  15. Aug 6, 2024 at 6:25 PM
    Twitch57
    Twitch57 Well-Known Member
    N AZ
    2021 DCSB SR 4x4
    Me explaining to the wife how literally any system is better without EPA meddling
  16. Aug 6, 2024 at 6:52 PM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    yea, its becoming a mess. So, Trump signed it into Law back in 2020/2022 but the EPA has been dragging ass writing the actual rules. So manufactures are trying to get ahead. Plus with the the new A2L designation, the NFPA is trying to re write some of the fire code. Because its so low flammable, doesn't need the same code as a A3. However, it still IS flammable even if barely. So when it is used, there's just so much more valves and sensors and everything else that it needs. Calculations, in certain confined instances, need to be able to vent to atmosphere etc.
    Its a mess.
  17. Aug 6, 2024 at 7:27 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Anyone have plumber recs in west valley? Nothing crazy but need a new hose spigot soldered on. Might attempt it myself, I already have a MAP torch, but need someone on standby for when I fuck it up.
  18. Aug 6, 2024 at 7:36 PM
    jjsinaz
    jjsinaz Well-Known Member
    Jim
    Sun City West, AZ
    2023 TRD Sport DCLB Ice Cap 4X4
    Uhh Trump was not president in 2020/2022, Biden was, so don;t blame it on Trump
  19. Aug 6, 2024 at 8:07 PM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Trump was President in 2020 when he signed it. With a start date of 2022.
    Get your political shit the fuck outta here.
    Rudimentality, TSAVO, BillW and 8 others like this.
  20. Aug 7, 2024 at 7:58 AM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
