AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Nov 22, 2024 at 6:23 PM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    I want in! Do I have to get jumped in orrrrrr???
    prise[QUOTED] likes this.
  2. Nov 22, 2024 at 6:27 PM
    prise
    prise AZ's Toaster Strudel Low T Andrew
    Prise
    Rally Runner 04 GX470
    Definitely the other one ;)
    TACOTU3[QUOTED] likes this.
  3. Nov 22, 2024 at 6:33 PM
    Queso_Blanco
    Queso_Blanco Formerly known as "Bad_Guac"
    Tyler
    Mesa, AZ
    '23 Super White DCSB TRD OR 4X4
    Accutune stage 4 Adjustable King 2.5's w/resi's All the meso Diamondback HD Method 701's 17x8.5" 285/70R17 Diode dynamics fog/ditch/stealth lightbar Sliders RCI skids OTT tune Total Chaos bed gussets Etc...
    Swap cell #'s with @prise you'll get bombarded with market place finds until you finally pull the trigger on one.
  4. Nov 22, 2024 at 7:47 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  5. Nov 22, 2024 at 8:06 PM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    Very glad you went with a 1.6. The 1.28gal/flush toilets fucking suck. They’re designed for piping with 1/8” per foot of pitch, which is relatively new. Older drainage is 1/4” per foot. The extra water helps flow things down river faster with the 1/4”, but when you don’t have that extra bit, it causes clog after clog.
    EatSleepTacos[QUOTED] likes this.
  6. Nov 22, 2024 at 8:09 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s interesting, good to know. Yeah I agree, I’m not trying to save 5 gallons of water a day when we’re already averaging 250 gallons a day in our house. Not worth the pain. I’ll just take a slightly shorter shower to make up the difference if I really wanted.
    TACOTU3 and emelianenkov[QUOTED] like this.
  7. Nov 22, 2024 at 8:11 PM
    emelianenkov
    Alex
    NORTH POLE
    Definitely not, especially when snaking plumbing is involved. I’ve done a lot of commercial and residential drain cleaning in my plumbing career. It ain’t fun, and it ain’t cheap!
  8. Nov 22, 2024 at 8:22 PM
    TACOTU3
    That was a plot for a whole episode of King of the Hill!
  9. Nov 22, 2024 at 8:54 PM
    emelianenkov
    Alex
    NORTH POLE
    I feel like there’s a KOTH quote for everything :laugh:
  10. Nov 22, 2024 at 8:56 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    XPOTRPR[QUOTED] and TACOTU3 like this.
  11. Nov 22, 2024 at 9:09 PM
    MGMDesertTaco
    1.6gpm, lol. You can always raise the float so the tank sends a little more water down river with each yule log/hickery farms sampler. :poking:
    emelianenkov and TACOTU3 like this.
  12. Nov 23, 2024 at 6:21 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    I'm not a plumber but maybe I should be. I've swapped out at least 9 toilets with Kohler Highline Classics. They run about $200ish and are 14 golf ball rated. Takes a lot of fiber to plug one up.
    Did two in the current house.
    Three in the last house
    Two in Mom's condo.
    Two in the previous last house.
    Seems to be that the initial toilet design with the low water usage that came out in 1990 through 2000 weren't really designed for low flow. They just took a 7 gallon toilet and cut it down to 2.3 gallons. Now they are engineered to run low flow and can get by with 1.2ish if you get a good one.
    And yeah - F-That Wax Seal.
  13. Nov 23, 2024 at 6:28 AM
    emelianenkov
    Alex
    NORTH POLE
    Drain piping should be considered when you go to a 1.28gpf. Sure the toilet itself won’t clog, but usually the water runs away faster than the solids and you end up with a blockage
  14. Nov 23, 2024 at 6:38 AM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    prise and TACOTU3 like this.
  15. Nov 23, 2024 at 6:42 AM
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
    True - We had a "plumbers belly" in a line at one house. That's where the line from the toilet to the main sewage line by the street sags down a little below the main line and solids have to go a little bit up hill near the end of the trip before it becomes "the city's problem."
    Ended up putting in a Pressure Assisted Toilet in that house.
    https://www.thespruce.com/best-pressure-assisted-toilets-4158678
    They work off of capturing your water pressure. We lived right close to the water-tower and I raised our PSI to the max safest recommended amount. That thing flushed really well. Would suck your ass hairs off if you were sitting on it. But after we moved they started recalling them because they would go BOOM in the night. That was around 2003. I think they have the kinks worked out now.
    emelianenkov[QUOTED] likes this.
  16. Nov 23, 2024 at 9:14 AM
    MGMDesertTaco
  17. Nov 23, 2024 at 12:13 PM
    Yacob_D
    Yacob_D It's Fine, Leave It.
    Jacob
    The J
    08 Red, AC
    Couple nuts and bolts 4x converted
    Might be time to sell the Ford and try to be part of the gang again?? Miss hanging with you guys, time and business is killing my friend connections..
  18. Nov 23, 2024 at 12:17 PM
    time623
    James
    AZ
    Minitruck gang
  19. Nov 23, 2024 at 12:49 PM
    Twitch57
    Twitch57 Well-Known Member
    N AZ
    2021 DCSB SR 4x4
  20. Nov 23, 2024 at 1:34 PM
    time623
    James
    AZ
    Twitch57[QUOTED] likes this.
