AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Feb 19, 2025 at 2:04 PM
    KingOfTheNorth
    KingOfTheNorth Kum and Go King
    97 4runner
    All the mods
    I was just fucking around. I am sure it was a fair price for him to do it. Its when going to a specialty shop pays off as they can hammer it out and know how to be profitable in doing it.
    PilotBoy352[QUOTED] likes this.
  2. Feb 19, 2025 at 2:06 PM
    PilotBoy352
    PilotBoy352 Well-Known Member
    Tim
    Mesa, AZ
    2015 MGM DCSB (rip) now 2018 white DCSB TRDOR 6MT
    Yeah, he's a good guy, but engines aren't his thing. This shop seems to get good reviews, and they seemed honest over the phone
  3. Feb 19, 2025 at 2:09 PM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    My man! That’s more like it!
    For sure do research on the shop and make sure you are getting a solid warranty, but this sounds a lot closer to fair and reasonable.
  4. Feb 19, 2025 at 2:13 PM
    PilotBoy352
    Tim
    Mesa, AZ
    Same warranty my scoutmaster could do, 12 months/12,000 miles. Its not like I will be able to bring it back anyways. Hopefully it goes well, I am going to take some of my stuff out and my skid plates off tonight and hopefully tow it tomorrow afternoon
  5. Feb 19, 2025 at 2:16 PM
    TACOTU3
    That should be enough time for any issues from the (I assume) wreck or the install to surface.
  6. Feb 19, 2025 at 2:17 PM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    From my previous post, the vacuum pump engines are for non-OR/Pro trims...do you plan on removing the vacuum pump and installing the cam sealing ball and block off plate?
  7. Feb 19, 2025 at 2:20 PM
    PilotBoy352
    Tim
    Mesa, AZ
    Shit, I told him the wrong thing, I'm dumb. I remembered it as the OR having the pump. I will update again in a bit
  8. Feb 19, 2025 at 3:12 PM
    PilotBoy352
    Tim
    Mesa, AZ
    They found me a 22,000 mile NON vacuum pump motor out of a 2021 Tacoma, the guy said it will be the same price. The other engine was out of a 2019, so this one will be a bit newer and a few less miles
  9. Feb 19, 2025 at 3:32 PM
    TailHook
    Alan
    Southern UT
    Nice...still cheaper than another truck!
  10. Feb 19, 2025 at 3:49 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    My guess for it being the same price is partly because he wants your business more than to nickel-and-dime you.
  11. Feb 19, 2025 at 4:43 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    I've seen a lot of A&D contractors (more D than A to be fair:burp:) just be a total clownshow of dudes running taps bone dry and a salty ass jug of mystery loctite.;)
    But you're absolutely right and I want to work somewhere where they do just that!
  12. Feb 19, 2025 at 4:52 PM
    TACOTU3
    :spy:
  13. Feb 19, 2025 at 5:59 PM
    Maxx
    Maxx Well-Known Member
    Reseal the front cover while it is out of the truck. It will leak soon from the lower passenger side and it will be more pain doing it in the truck vs out.
    Replace the plastic oil filter housing with the aluminum Camry part right out the gate.
    Get an oil catch can to help protect against hydrolock due to oil pooling in the head while on an incline.
    Check rear plastic coolant crossover pipe for leaks as it is known to crack and be a pain to replace with the motor in the truck.
    If the motor arrives and still has any amount of oil in it, ask them to drain or pump it into a clean container and send off to Blackstone Laboratory for analysis. It can tell you a lot for only $40.
  14. Feb 19, 2025 at 6:19 PM
    TACOTU3
    I’ve read some horror stories about this, just swap to the metal one while it’s out!
  15. Feb 19, 2025 at 6:22 PM
    TailHook
    Alan
    Southern UT
    There is no metal part available...plastic part was revised in 2018
  16. Feb 19, 2025 at 7:43 PM
    PilotBoy352
    Tim
    Mesa, AZ
    Do you have part numbers for the stuff I need to get? I will talk with the shop when I get it towed tomorrow afternoon.
  17. Feb 20, 2025 at 5:50 AM
    TailHook
    Alan
    Southern UT
    Good list, I have a slightly different take...
    Front timing cover: The 2GR does like to leak on Bank 1 (PS) where the cover meets the block and the head (right by the vane pump), usually because the factory sealer was insufficient at this junction. Inspect it first for weep/leak, as well as the color of the sealer...gray is factory, while black would indicate the cover has already been resealed. Based on that, make the call if it's really even necessary...I subscribe to the "if it ain't broke" school of thought. This is an in-service engine and you could possibly introduce problems rather than solve them. ETA: This was mostly an issue with '16-'17...'18 and up are less prone.
    Composite oil filter housing: Just fine if it isn't He-Man torqued and the o-ring is in the proper groove...the o-ring does the sealing, not tightening of the housing (spec is 18 ft/lbs). Inspect it for any signs of cracking near the wings, replace if necessary. Definitely pull it and do a fresh oil change with an OE filter, and a Blackstone analysis is cheap peace of mind.
    Catch can: YES...I have the J&L OSC (fka JLT) on mine, but there are other options out there.
    Rear crossover pipe: Prone to leaking on '16-'17, revised part in '18...definitely inspect for the dreaded pink crusties. ETA: if it ever does leak in the future, easy to replace when doing the next clutch.
    Just my $0.02...YMMV
  18. Feb 20, 2025 at 5:55 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    I agree with all of this.
  19. Feb 20, 2025 at 6:10 AM
    TailHook
    Alan
    Southern UT
    Couple additions...
    You *could* replace the spark plugs with new Denso FK20HBR8, although probably not needed. At the very least, pull the coils and check torque (13 ft/lbs)...
    Only use Toyota SLLC pink coolant...no reason to use something that says "compatible" or worse, another color.
    PilotBoy352 and Supr4Lo like this.
  20. Feb 20, 2025 at 6:45 AM
    BillW
    BillW Well-Known Member
    N. Phoenix
    2018 DCSB TRD OR MT
    Or they simply need the work. Reading r/JustRolledIntoTheShop people are slow af right now.
    PilotBoy352 likes this.
