AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. Apr 17, 2025 at 11:58 AM
    Twitch57
    Twitch57 Well-Known Member
    N AZ
    2021 DCSB SR 4x4
    jayavilak5[QUOTED] likes this.
  2. Apr 17, 2025 at 11:58 AM
    Atl-atl
    Atl-atl Well-Known Member
    Phoenix+Flagstaff
    2024 Ram Power Wagon
    Fox, Thuren, 40s, other stuff
    Anybody know about residential solar panel systems? I need to clean mine and I want to shut them off. Here is a picture of the equipment where it ties into the house. There are two different disconnects. One on the first plastic box, the black rotary switch. Then the one on the smaller grey metal box that is a big lever. They both seem like they will completely disconnect the system. Does it matter which one I shut off? Also can I simply shut one(or both) off and then right back on when Im done cleaning the panels on the roof?
  3. Apr 17, 2025 at 12:21 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Poke it with a flathead screwdriver until you see God.
    Then it's probably off.:burp:
    BillW, AZ_TJ, Bikinaz and 5 others like this.
  4. Apr 17, 2025 at 3:17 PM
    Yacob_D
    Yacob_D It's Fine, Leave It.
    Jacob
    The J
    08 Red, AC
    Couple nuts and bolts 4x converted
    I have/had a sport! Converted to A 4x with some Frankenstein parts from an Fj, 4R and another Tacoma:sawzall::welder:. I enjoy the hood scope and took the plastic bullshit out of it and get some forced air to help cool the engine bay..
  5. Apr 17, 2025 at 3:25 PM
    Rudimentality
    Rudimentality Well-Known Member
    Brad
    Mesa, AZ
    3rd Gen DCSB TRD Off-Road
    Stuff that costs more than my wife thinks.
    Not being a jackass for once. Genuine curiosity, wouldn't opening the scoop be a bit irrelevant with the intake as it is? I get keeping temps lower in the bay, but I suppose I wouldn't think we'd be moving fast enough when that matters as much. :mudding:
    Edit to add: I suppose even just having it as an escape route for some of the heat makes it useful enough.
  6. Apr 17, 2025 at 3:30 PM
    Yacob_D
    Jacob
    The J
    08 Red, AC
    The scoop isnt hooked up to my intake but just thought the forced air into the bay would help with a little heat? I have no info to prove/disprove its "working", but seems to be a little different. The scoop is just for looks and originally remove the plastic insert to add a small light bar in place. I never purchased the light and left it open.
    Adding the bumper, and a secondary trans cooler, and two electric fan it seems to block a little more breathing room from the front. Was hopping the scoop would add a little more movement to the bay?
  7. Apr 17, 2025 at 3:41 PM
    Rudimentality
    Brad
    Mesa, AZ
    No hate here! It napkin-math's for my simple mind lol, especially at speed.
    Yacob_D[QUOTED] likes this.
  8. Apr 17, 2025 at 5:56 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Yeah i don't hate it but damn Toyota could have at least made it functional from the start that's what really bothered me
  9. Apr 17, 2025 at 6:17 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    With the bumper and open wheel wells you're probably getting more air from below than up top, which would mean putting louvers in the hood would extract air more rapidly than a scoop.
    Rudimentality and unstpible like this.
  10. Apr 17, 2025 at 6:25 PM
    unstpible
    Derek
    Cedar City, Utah
    Louvers excite me. Turbo heat made it more necessary too I just haven't found the exact ones I want yet
  11. Apr 17, 2025 at 6:27 PM
    unstpible
    Derek
    Cedar City, Utah
    Different kind of scoop but I notice a trickle of smoke from the vented oil catch can streaming out of my snorkel from time to time so I know it's pulling heat out of the engine bay
  12. Apr 17, 2025 at 6:30 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    Don't forget the gurney flap to disrupt the boundary layer over the hood, It's often as simple as just bending the first slot up almost perpendicular.
    Cutting the Miata's hood open was a pucker moment for sure but they came out so well, it looked so frickn badass!
  13. Apr 17, 2025 at 6:33 PM
    unstpible
    Derek
    Cedar City, Utah
    :drool:
  14. Apr 17, 2025 at 9:15 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    You need to shut both.
    The white box rotary is your solar panel DC switch. That stops the PV voltage from the panels to the inverter that converts to AC which then goes to the Solar meter.
    The grey disconnect is your connection from the Solar meter to your main electrical panel and meter.
    You want to kill that to eliminate any possibility of voltage back feed from APS main to the solar system.
    Disconnect/shut off both. Lock out, Tag out both. Double check with a meter to be safe.
    You can also call or text me. You have my number
  15. Apr 18, 2025 at 6:05 AM
    prise
    prise AZ's Toaster Strudel Low T Andrew
    Prise
    Rally Runner 04 GX470
  16. Apr 18, 2025 at 6:19 AM
    4runnersr569
    4runnersr569 Well-Known Member
    West Valley, AZ
    4Runner
    KingOfTheNorth likes this.
  17. Apr 18, 2025 at 7:11 AM
    KingOfTheNorth
    KingOfTheNorth Kum and Go King
    97 4runner
    All the mods
    :eek: hmmmm I am driving down the hill after work today too. Is this another project I want to add to my list tho. Well yes it is but when would I complete it..........
    Rudimentality and 4runnersr569 like this.
  18. Apr 18, 2025 at 7:11 AM
    KingOfTheNorth
    97 4runner
    All the mods
    right!
  19. Apr 18, 2025 at 7:13 AM
    4runnersr569
    West Valley, AZ
    4Runner
    It’s in verrado which looks to be 30 minutes from my house
  20. Apr 18, 2025 at 7:19 AM
    KingOfTheNorth
    97 4runner
    All the mods
    Yeah It is not terribly far for already coming down to the valley.
