AZ BS Thread 4²0
Discussion in 'Arizona' started by Brian007Taco, May 12, 2016.
  1. May 11, 2025 at 9:30 AM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
  2. May 11, 2025 at 10:48 AM
    PilotBoy352
    PilotBoy352 Well-Known Member
    Tim
    Mesa, AZ
    2015 MGM DCSB (rip) now 2018 white DCSB TRDOR 6MT
    Man, my old truck would have been great for that. The magnetic gray just shows all the stripes
    AZTaco2sDay likes this.
  3. May 11, 2025 at 10:54 AM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    How’s the new rig running? You get the starter/flexplate and all that other nonsense worked out?
    PilotBoy352[QUOTED] likes this.
  4. May 11, 2025 at 11:15 AM
    PilotBoy352
    Tim
    Mesa, AZ
    Nope. I haven't had the truck in seven weeks. I've been ranting about it in my build thread, but there is a check engine light that they have been unable to solve for the whole time. The hard start issue is also still there, despite a new flywheel. Theoretically they will have it put back together tuesday from resealing the injector ports in the cylinders, and have a new flywheel spacer from Toyota. I have little faith that this will solve it, as the dozen or so other fixes haven't done anything. I commission into the Air Force on tuesday, so I need my damn truck done
  5. May 11, 2025 at 11:36 AM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Probably won't really be able to drive it for a few months through the different trainings you'll be getting into so hopefully they can get that figured by then. I think I went close to 9 months without a personal vehicle but I'm sure the airforce may be a little different
    :notsure:
    :oldglory:
  6. May 11, 2025 at 11:44 AM
    PilotBoy352
    Tim
    Mesa, AZ
    I will be doing pilot training, I've already done all my other trainings through AFROTC. I will be basically just a normal officer, my job will just be to learn to fly, so I will still need a vehicle to get to and from base and everything. I also need a truck to PCS to Texas, so things might get fun here if they don't finish up before I leave in early June.
  7. May 11, 2025 at 11:54 AM
    unstpible
    Derek
    Cedar City, Utah
    The military has contractors that will move all your belongings for you during a pcs. You'll get a specific amount of weight allowance determined by rank (or they will pay you 80-90% of what they would pay the moving company if you do it yourself so you can rent a moving truck and still come out ahead)
    Airforce is wildly different
  8. May 11, 2025 at 1:49 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
  9. May 11, 2025 at 1:59 PM
    Nitori
    Maricopa AZ
    2021 T4R SR5
    Anybody have access to a press brake? I have an idea for a relatively simple quick detach for my pelican case, but I would have to make the brackets myself. The pre baked pelican solution does not work because I have an older revision that has no handle on the "wheels" end of the case.
    So on the front side I'd just use one of the standard Pelican provided mounts that clamp the handle down:
    But then since the back side of mine has only the wheels, I could drift the pins for the wheels out, and throw in one of these guys:
    I'd need a U-shaped bracket to go inside the "wheel well" of the case with holes to mount to the roof rack, and holes that would like up with the axle holes of the wheel. Then you could just throw those 2 pins through both sides and have a "quick release" roof rack storage.
  10. May 11, 2025 at 2:09 PM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
  11. May 11, 2025 at 4:28 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    "Where do you get a belt-fed weapon? At the end of the world everything is free." :rofl::rofl::infantry::infantry:
    Twitch57[QUOTED] likes this.
  12. May 11, 2025 at 7:38 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What if you took some 1” square tube and cut off an appropriate width of it, wheel width (or whatever size tubing to get the height right)
    Then drilled holes on three sides. Two holes are there to pass the pin through and the third is there to bolt to the prinsu. Or four holes so you can get a screwdriver down inside of it, depending on the bolting down solution.
    Assuming the height necessary isn’t too small.
    Nitori[QUOTED] likes this.
  13. May 11, 2025 at 8:03 PM
    unstpible
    Derek
    Cedar City, Utah
    We crossed off Ouray last year. Stopped for burgers at Maggie's after doing Imogene pass so that's a double sticker day
  14. May 11, 2025 at 8:10 PM
    unstpible
    Derek
    Cedar City, Utah
    I had a rubber ducky on the dash of my civic in high school. It migrated through all my vehicles, Got it at the nickel arcade for probably $50 worth of tickets. I thought it was cool back then because it was wearing the dress blue uniform. Each time I got promoted I'd add a stripe to his wings to make sure it out ranked me. He flew away when I totaled my 09 back in 2018 and now that everyone has damn ducks it's not fun anymore
  15. May 11, 2025 at 9:16 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I came across someone with a pet duck in Safeway this afternoon. That was a first for me.
    BillW, llibrm, Nitori and 5 others like this.
  16. May 11, 2025 at 9:35 PM
    unstpible
    Derek
    Cedar City, Utah
    I'd rather not have that thing where I put my groceries, live animals do not belong in shopping carts.
  17. May 12, 2025 at 1:35 AM
    Brian007Taco
    Brian007Taco [OP] 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    Might have to enter this. Just got back from Moab. Some new pnstripes and some nice paint striping of the undercarriage armor.
    05tacomabro likes this.
  18. May 12, 2025 at 6:01 AM
    TailHook
    Alan
    Southern UT
    Jeepers ruin everything, man :facepalm:
  19. May 12, 2025 at 7:06 AM
    Twitch57
    Twitch57 Well-Known Member
    N AZ
    2021 DCSB SR 4x4
    There is a lady who walks her pet duck in a stroller to the duck pond in flagstaff
    Thats flagstaff for you
    EatSleepTacos[QUOTED] likes this.
  20. May 12, 2025 at 7:08 AM
    Twitch57
    N AZ
    2021 DCSB SR 4x4
    Agreed. Usually its the dogs that annoy me but thats ridiculous
    Only reason that thing should be in a shopping cart is after its been butchered
